Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Gas Engines
Gas Engines Discussion of the gas engines available in the 1999-2007 Super Duty trucks
Old 05-01-2003, 11:44 PM   #1 (permalink)
V-10 Y-pipe
Has anyone tried to change the Y-pipe on their V10? I have a 99 and the P/S snakes all around before it goes rearward. The later one's look just as bad because the P/S points directly into the D/S at a 90 degree angle. It looks pretty easy to have a muffler shop (or the do-it-yourselfer) cut that junk off and make a nicer set-up.
The banks and probably other headers kits have a lot nicer y-pipe. It looks like an easy way to get a bunch of power w/o spending $1200 on a header kit.
99 f250 V10 4x4 c/c lb
dadomin8r is offline
Old 05-02-2003, 05:56 AM   #2 (permalink)
HeavyAssault's Avatar
My Photos: (6)
Re: V-10 Y-pipe
You have to remember your stock headers will still be a choke point for the exhaust. You nmay see some gain from the new y-pipe. Any exhaust shop should be able to set up a new pipe for you. If you watch EBAY you can find the headers cheap.
2006 F-350 CC PSD Lariat 4X4 LB 3.73 LS
Some stock stuff, some modded stuff, some "deleted" stuff.....
HeavyAssault is online now
Old 05-05-2003, 07:40 PM   #3 (permalink)
Re: V-10 Y-pipe
flowmaster has a y-pipe for our trucks...
2000 F250 SD CC 4x4 PSD Lifted, AFE, 4" Exhaust, DI oil cross-over, SCMT, Garmin GPS V, Line-X'd RanchHand front/rear bumpers, Isspro gauges, EBPV deleted, Air intake heater deleted, Coolant by-pass filter, Pre-pump mod., Fuel tank harpooned
1999 F250 SD 4x4 '04 Cummins engine, '06 axles and suspension, BTS Trans.
Aggie007 is offline
Old 05-06-2003, 12:58 PM   #4 (permalink)
Re: V-10 Y-pipe
I modified mine by cutting the stock Y pipe off just below the O2 sensors. I ran dual 2.5 inch pipes back to where the cat use to be, Yes I deleted the cat. The exhaust shop fabricated a custom Y where the two 2.5's combined into one 3, the custom Y then ran into a Flowmaster 70 series muffler. The throttle response was much quicker, the RPM spooled up real quick. A slight increase in Hp was also noticed, but the low end torque shifted up the RPM band. Not good for towing. Now the bad part, the thing was so loud you could not ride in it. After 15 minutes I had a headache so bad my eyes were crossed. I went back and re-installed the cat which quitened it down quite a bit. Now it has a V-6 on steroids sound. [img]/ubbthreads/images/graemlins/frown.gif[/img] The throttle response is still btter than stock, the low end torque is up in the RPM band, and it sounds horible. MPG's may have increased slightly, maybe .3 or .4 MPG. I'm at the point now of not knowing what to do. Since I already have the dual pipes back to the cat I may go ahead and run duals all the way to the back. I know a guy over at FTE who is running this set up with dual Magnaflow's, with a "H" pipe, and he is getting good results. -OR- Go with Banks or Borla headers with the Flowmaster cat back system made for diesels. This would allow me to do away with the 3 inch pipe and go with 3.5 or 4.0 inch pipe. If you don't tow you may want to accomplish this mod, if you tow this mod is not good because your low end torque is really moved up in the RPM band.
Mark
2000 F-250 Super Duty XLT V-10 4x4 Ext Cab SWB. Ram Air Mod with K &N filter, Sonnax Valve-Tricumulator Springs. Hayden 679 Tranny Cooler with Imperial fan. Trans. Temp. gauge, BFG 285-75R16 All Terrain T/A's
GAV10 is offline
Old 05-06-2003, 02:02 PM   #5 (permalink)
Re: V-10 Y-pipe
DO you have any pictures of the exhaust? I would really like to see them.
Old 05-07-2003, 11:36 AM   #6 (permalink)
Re: V-10 Y-pipe
I currently do not have any pictures. I will try to dig out the digital camera and take some. I'll send you a PM when I have them available.
Mark
GAV10 is offline
Old 05-07-2003, 06:04 PM   #7 (permalink)
spoon's Avatar
Re: V-10 Y-pipe
Really? Do you have the part number? It would really save a lot of us here the headache of fabbing our own. [img]/ubbthreads/images/graemlins/grin.gif[/img]
2001 F251 SRW Lariat CC 156 4x4, V10, 4R100 Auto (#3!), 3.73 LS, ESOF, BU sensors
OffRoad, Camper Pkg. Born, KTP: 08-01-00, Delivered: 8-29-00
SCMT, Volant intake, Gibson stainless cat-back exhaust, PML ALu trans pan and diff cover, Snuglid, 285x75R Geolandar AT II+, Edelbrock IAS shocks.
Doing my part to consume petroleum.
spoon is offline
Old 05-08-2003, 08:06 AM   #8 (permalink)
Re: V-10 Y-pipe
FLO-Y250300A Summit Racing has them for $38
2005 V10, AT, Fx4 Dark Stone Metalic, Crewcab F350, 4.10LS, shortbed, towcomand, Extang tonno **SOLD**
2007 Dodge 3500 Quadcab, 4x2, 6.7L Cummins, a/t, longbed, 4x2
Silence is golden. Duct tape is silver.
V10 man is offline
Old 05-08-2003, 11:24 AM   #9 (permalink)
Re: V-10 Y-pipe
Does it help eliminate flutter?
sethmark is offline
Old 05-13-2003, 05:04 PM   #10 (permalink)
spoon's Avatar
Re: V-10 Y-pipe
Thanks V10 man, but there are two problems with that part.
1. It is a generic part (16" long), not designed for the V10, thus would require additional pipe/joints welds or clamps. A real PIA in that space. [img]/ubbthreads/images/graemlins/crazy.gif[/img]
2. It's fabbed from aluminized steel, not stainless.
I've seen quotes of $250-$350 for a custom stainless y-pipe locally. On the other hand, I can buy a Borla bolt-on header/y-pipe combo for about $700. Now: how to rationalize/justify it to the purchasing department. [img]/ubbthreads/images/graemlins/smirk.gif[/img]
Any suggestions on the best place to buy these? The going rate seems to be @ $720 at the places I've checked.
spoon is offline
Old 05-13-2003, 06:41 PM   #11 (permalink)
Re: V-10 Y-pipe
Let me just say I don't support the Y-pipe mod. Just seems like your messing with stuff you shouldn't. I just posted the part # for those interested. I fully support the Banks/Borla header route. [img]/ubbthreads/images/graemlins/grin.gif[/img]
V10 man is offline
