v10 crew cab weight - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Gas Engines
Old 05-14-2003, 10:22 AM   #1 (permalink)
v10 crew cab weight
Does anyone know the weight on the front axle and rear axle of a v10 crew cab long bed, or short bed. I need to tell national for my springs.
99 f250 V10 4x4 c/c lb
dadomin8r is offline
Old 05-14-2003, 01:45 PM   #2 (permalink)
My Photos: (15)
Re: v10 crew cab weight
I don't have individual axle weights, but total for my V10 CC 2WD full of fuel but otherwise empty = 6300 lbs.
'03 CC SWB 2WD Lariat
Solo2puller is offline
Old 05-14-2003, 03:58 PM   #3 (permalink)
When you get this info please post it here. I am interested in what you find out.
Junior
2003 F250 6.0 PSD CC SB 4X4 Auto
1994 F350 5.8 Gas CC LB 4x4 Auto
1987 Ranger Prerunner 350 Chevy V8 TH400
<font color="red">EJR RACING </font>
<font color="blue">SUPER DUTY HEADQUARTERS
PlayaBum is offline
Old 05-14-2003, 04:03 PM   #4 (permalink)
The tag says 8800 dry, so I figure wet with 4 guys in it should be about 10000 and 60% on the front axle = 6000 ft and 4000 rr. Maybe it's 65% on the front.
Old 05-14-2003, 04:28 PM   #5 (permalink)
My Photos: (15)
On a 250, 8800 lbs should be the GVWR - what it can be max when loaded, not what it weighs empty. I suspect it's a bit less than 8800 lbs empty, otherwise you wouldn't have any cargo capacity.
The only real way to know for sure is to go weigh it. Gravel yards, truckstops and some feed stores have scales that can give you the individual axle weights. When I weighed mine I didn't do each axle individually, just drove the whole truck on the scale. If your truck is torn apart waiting new springs (sounds like it is) you'll have to find someone with a similar configuration to give you thier weight. Mine is 2WD and SWB, but otherwise similar to yours. Figure about 400 lbs for the 4WD, and another 200(?) for the LWB and you're still below 7000 lbs. empty.
Poke around at you local gravel yard - mine will let you weigh for free if you don't need the number certified. Otherwise it's $5.
Here's a link with some similar configurations and their weights, but no one has weighed individual axles that I've seen.
Link about weights
Old 05-15-2003, 10:13 AM   #6 (permalink)
2WD CC short V10:
Truck had me, luggage for 4 for the weekend and 3/4 tank gas.
Scales:
Front-Scale #1 = 3840
Rear-Scale #2 = 2980
Total Gross = 6820
I figure fill-up, add wife and 2 teenages = 7200 total. [img]/ubbthreads/images/graemlins/cool.gif[/img]
2001 TRed F250 Lariat CC 156 in.,4x2, Camper Pkg., V10, Auto, 3.73LS, Heated seats, Bed X-tender,Ford Flaps,Catch-all,RollNLock. 7200# Me, Wife, 2 teens, gas and gear for weekend.
Benr0 is offline
Old 05-18-2003, 08:04 AM   #7 (permalink)
Not sure if it helps but my 03 CC DRW 6.0 diesel weighed in at 7660 at the local CAT scales. The fuek tank was a few gallons shy of full.
03 F-350 Lariat CC 4x4 Long bed DRW 5 speed auto, 36,504 Miles, white/silver, Built 11/02, engine build 11/19/02. RC8 - B28.0.9 flash, Adj pedals, Off road pkg, Camper pkg, Adv security pkg, Michelin LTX, Firestone Ride-Rite air bags, TT heated mirrors, Home Depot Gutter Guard grill.
pwolf is offline
Old 05-31-2003, 04:14 AM   #8 (permalink)
crew cab dually, v10, lariat, full of fuel (1125 lbs) (150 gal)-tank located in bed, right behind cab. Driver included (160 lbs)
front axle: 4150lbs
rear axle: 4300lbs
2003 Dodge 3500 Quad Cab Dually (new 7/18/03)
All stock
85,000 miles and counting 13,500 per month!)
UPDATE 5/06...400k MILES, STILL STOCK!
1999 Ford Crew Cab Dually
V10 with K&N Filter Kit
4R100 with Gear Vendors Under/Overdrive;5:13Gears
230K Miles(Blown head gasket)Installing a Cummins!
UPDATE 5/06...INSTALLED A NEW V10, DRIVER SIDE HEAD LEAKS COOLANT AT 85k MILES, NOW I NEED A CUMMINS!
Future Plans:
19.5 inch Wheels
Complete Air Ride Suspension
new girlfriend
UPDATE 5/06...MARRIED NOW AND HAPPY!!!
EMIEVEL is offline
