V10 Engine Ticking - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Gas Engines
Old 06-16-2009, 10:00 AM   #1 (permalink)
V10 Engine Ticking
I have a 99 V10 with only 64000 miles, under acceleration, pulling a 3000lb trailer, there is a slight ticking sound at times, but not always. It is not fuel related. It also does not seem to effect the power.
I did add a can of Seafoam to the fuel a couple tanks ago and that seemed to help some.
Any ideas would be appreciated.
2012 F350 XLT 6.2 4X4 CC 4.30 with 285's, Bakflip cover with Rhino Bedliner so far.
6757 is offline
Old 06-16-2009, 08:31 PM   #2 (permalink)
MikeMcCasland's Avatar
This is most likely an exhaust leak at the exhaust manifold. Check to ensure that none of the studs holding it on have snapped off. If they have, you will likely need to replace the exhaust manifold and studs. (The manifold has likely warped if it's been going on for a long time.)
This is a common problem with V10's. It would be the first thing I would check.
MikeMcCasland is offline
Old 06-17-2009, 10:49 AM   #3 (permalink)
Pappy19's Avatar
My Photos: (6)
True, the exhaust stud issue was fairly common in the early V-10's but snce 2006, there were major changes in the V-10 exhaust system and the manifold studs are no longer a problem. In fact, at my last oil change at the dealer, I asked him to pull all of the V-10 TSB's, and he couldn't find a single one. That was from almost 2 years this coming September, and no reflash, no problems period with the V-10.
2002 F-350 SRW Lariat,4X4, PSD with too many goodies to list. 182k and a very strong 7.3. SOLD
2008 F-250, SC Lariat, 4X4,Shortbed, Pueblo Gold/black, V-10, 4.10, auto, Delivered on 9/7/07, great looking rig. South Texas bumpers front/rear, Air Raid Intake System, Diablosport Predator, Magnaflow, Husky's, JJ's, Ford alarm/remote start, Marathon seat covers, Sirius, PIAA, Access cover, Weatherguard tool box, Rhino liner, Michelins, Duraflap mud flaps, Escort 9500i, MagHytec rear dif cover.
2007 Lincoln LT (wifer's grocery getter),Superchip,Magnaflow duels, K&N dropin, Leer Browning Special
1996 Ford Bronco EB; almost stock
2007 Kubota 900 RTV diesel with goodies.
pappy's truck
Pappy19 is offline
Old 06-17-2009, 12:14 PM   #4 (permalink)
akrewat's Avatar
Ditto on the exhaust leak. A ticking that is only on acceleration is exhaust. A ticking that happens all the time, no matter what, is usually valve-train.
Pappy, the 3-valve V10's use a different style of exhaust manifold. The 2-valve V10 uses a log-style, like the old FE's did, so when it heats up and cools off, it expands and contracts a LOT. This drags the studs around with it, especially when the nuts rust to the manifold, and eventually fatigues the studs. Ford did come out with copper-plated nuts that seem to not rot to the manifold, which may help on the 2-valvers.
The 3-valvers use a manifold that is more like a header, with individual flanges for each exhaust port. This allows the manifold to expand and contract without all the tugging on the studs. Whether by design or by accident, it seems to have eliminated the stud-breaking issue
'01 F250SD V10 auto 4x4 SC SB Volant CAI, ebay headers/y-pipe
'74 F250HD FE390 4-speed 4x4 LB - heavily modified 390 (deceased)
akrewat is offline
Old 06-24-2009, 03:29 PM   #5 (permalink)
Thanks for the replies....would it also cause some moisture leaking down on the exhaust on the right side (seems to be the side where the ticking is coming from), started Saturday, small amount, 15 minute run time or so, then stops when truck is turned off.
6757 is offline
