V10 with higher gears??? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Gas Engines
Old 12-26-2000, 07:26 PM   #1 (permalink)
My Photos: (9)
I think it's a bit annoying that Ford does not offer 3.55 gears with the V10.
Is it even possible to special-order? I would expect much better mileage ratings that it currently gets with 3.73s. Has anyone even considered (gasp) changing over aftermarket?
Thanks.
2001 E350 PSD, Deep Emerald Green, 3.55 LS, Premium package, dual alts, rear A/C. Quigley 4x4, Transfer Flow rear tank (27+26), handicap mods, custom interior, Reunel tire carrier w/ Hi-Lift, Sportsmobile nerf bars (black), Amsoil lubes and Dual-Gard bypass oil filter, Amsoil air filters, Eclipse/JL Audio sound system w/ Sirius & 120GB Neo Car Jukebox (MP3 player), J&J stainless grill, Reunel Stainless bumper, 12000# Warn winch, PIAA lights, Bilstein shocks, Ultra Magnum wheels, Michelin tires (265/75-16), Correctrack rear wheel spacers, Bushwhacker flares (painted), Velvet-Ride spring shackles, p/s filter, external tranny and coolant filters, Autometer gauges(5), Optima Yellow Tops, Airdog.
msnunes is offline
Old 12-26-2000, 10:25 PM   #2 (permalink)
Re: V10 with higher gears???
I think "work" capacity took precedence over economy in the SD line of trucks... especially with the V10. Thus, gears higher than 3.73 aren't offered as an option.
The aftermarket industy builds some tremendous stuff. I've not seen any 3.55 ratio gears, though. Mostly, they seem to be building lower 4.56 ratios. Hopefully, they have more- I just haven't seen them.
If it makes you feel better, you can always compare mileage with me. Right now, with a lot of idling and running in 4WD, I'm getting around 9mpg. No complaints though.
2000 4x4 F250 XLT SuperCab SWB- V10, Automatic, 4.30LS, Offroad Pkg, Camper Pkg, OEM Hitch, Tape/CD Player, Remote Keyless Entry, Sliding Rear Window, Privacy Tint, Aluminum rims, 265/75R16 OWL tires, Line-X bedliner
NoMo's site
NoMo's website
NoMo is offline
Old 12-27-2000, 10:02 AM   #3 (permalink)
My Photos: (9)
Granted, they are work trucks first, however, 3.55 gears are offered with the diesel. This is one of the decisions that really has me stumped -- for that very reason, I'm leaning toward the diesel, for both power and better fuel economy over the long haul. But if I could get 3.55s with the V10, that expected mileage improvement might just sway me enough. I don't need or want 3.73 gears or lower. I'm tired of getting 12mpg!
Soon to buy: 4x4 Quigley E350 - V10 or PSD???
msnunes is offline
Old 12-27-2000, 11:19 AM   #4 (permalink)
Assuming both engines use the same rear diff., I'm sure you could buy FOMOCO parts to get the gears you want w/ either engine.
You may want to look at this thread as it may apply to the E-series as well:
http://forums.ford-diesel.com/ubb/Fo...ML/002779.html
NoMo's website
NoMo is offline
Old 12-27-2000, 11:36 AM   #5 (permalink)
Are you sure you can still get 3.55's with the PSD? I've never seen it listed anywhere since the Super Duty came out. I thought 3.73's was as low as they went anymore. Then 4.10's and 4.30's and don't the F-450 & 550 offer 5.13's? I actually wish I could have gotten something around 3.23's on my '96. I wanted to run 72 mph at 1800 rpm., right now I'm 68 mph at 2000 with 3.55's.
'96 F-250 4X4 5-sp POWERSTROKE
140,000 mile & NO Problems
Denny
'96 F-250 Reg. Cab 4X4 5-sp POWERSTROKE
298,500 mi & NO Problems, LUK Clutch
Dr.Evil is offline
Old 12-27-2000, 01:16 PM   #6 (permalink)
You can still get 3.55 in the Econoline vans. I was a bit stumped at first, too.
NoMo's website
NoMo is offline
Old 12-27-2000, 05:48 PM   #7 (permalink)
Just a note. I replaced the gears on my former PSD. I went from the stock 3:73 to 4:56. They take the gears from a 12.25 rear-end(old style ford truck). and then by using a shaved(for lack of a better word) pinion gear to fit the new 10.50 rear-ends found in the latest body style. The truck has since gone down the road and my new toy is hear.
Justin
2000 Excursion, 4:30 gears, Black on Grey. Tuff country lift w/add-a-leafs, 35x13.5x16 Micky Thompson Baja Claws on 16x9 Weld sidewinder rims. billet grill and lookn'good
Justin
2000 Excursion,V-10, Auto, 4:30 gears, Black on Grey. Fabtec lift, 36x14.5x16 Pranelli Jones Dirt Grips on Weld sidewinder rims. Fox Racing Shocks,billet grill,Ram-Air Hood, Wilderness Rack.
j-man is offline
Old 12-28-2000, 10:26 AM   #8 (permalink)
My Photos: (9)
Thanks... just wondering if something like that could be "special ordered" from Ford, or if I'm just on my own. I expect it would be $1000 or so (?) to have gears changed aftermarket... of course, with a Detroit Locker or something.
msnunes is offline
Old 12-28-2000, 11:20 AM   #9 (permalink)
I think you could get 3.08's in Econoline's back in the 80's & early 90's too. Nothing avail. even in aftermarket now. To many manufacturers of Overdrive gearboxes now.
Denny
Dr.Evil is offline
Old 12-28-2000, 07:10 PM   #10 (permalink)
There is only 5% difference going from 3.73 to a 3.55 Perhaps you could try a slightly larger tire....at least you could switch back if you wanted. personally, I doubt that anyone can even perceive a one size gear change.
John Z is offline
