It sounds like you may be experiencing the exhaust "flutter" that many of us V10 owners are experiencing. There are many threads regarding this noise throughout this forum. It is due to a badly designed Y-Pipe.
Rich
[This message has been edited by RBM (edited 12-06-2000).]
2001 F-250 SD V10 5 Speed 4:30 LS EC SB Lariat
Harvest Gold Tinted Windows Banks Power Pack System
BBK 65mm Throttle Body Diablo Delta Chip Custom 1 inch Spacer
It "shouldn't" ping on 87, but I think mine does a little too. Run a tank of 91+ octane and see if the ping goes away. If it does, take it back to the dealer for diagnosis.
I'm no mechanic, but in my experience a knocking from low octane gas usually occurs at much lower RPM levels. Like some of the others have said, I would tend to lean more towards timing or something else. Good luck.
__________________ Gig 'Em!! Official Member of the NRA, Texas A&M Association of Former Students, Bass Angler Sportsman Society, and the Associated Bilge Rats of the Other Forum
When the engine starts to knock, do you feel any reduction in power from the engine? If it is engine "ping" (detonation) and it is that loud you will feel a power loss. If no power loss I would tend to believe it is not "ping" or a timing problem. Good Luck
Rich
With certain brands of gas, mine will knock in that RPM range when I press down the gas pedal fast, but only for a half-second until the knock sensor kicks in. I always burn regular 87 octane. Texaco gas does this, and chevron does not.
On my 2000 SD, the wire for the knock sensor is routed from near the front of the engine, under the intake manifold and then to a disconnect plug at the top back of the engine. Check to make that plug has not come loose.
These engines can knock at any RPM if the computer and sensors are not working correctly.
My V-10 knocked for the first time a few weeks ago on a cold day, climbing a steep hill. My guess was summer grade gas couldn't handle the 15 degree weather or I just got a bad load of fuel. Ran the tank dry and refilled and haven't heard a knock since.
Guys, you probably don't have CA emissions.
The knock sensors work well. The computer is set for 87 octane. You may have flutter, especially in 2000 to 3000 rpm range. Pay attention folks. "Flutter" is a real thing.
Is it exhaust noise? Piston slap? I don't know, but the noise sucks, doesn't it?! Do you like taking friends for a ride to share the excitement of Super Duty Truck ownership... And then have them notice the noise and ask... What the hell is that noise????????????????????????????????????
[This message has been edited by Knocker (edited 12-12-2000).]
2000 F350 XLT CC DRW V10, White, VERY , VERY Pretty!
I definitely have some pre/post-detonation which I describe in the "Knocking confirmed; not flutter" topic. basically through use of a computer to monitor the spark timing.
