V10 not a cold weather engine?? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Gas Engines
Old 12-21-2000, 11:18 AM   #1 (permalink)
My gas mileage has dropped from 12 all around to about 9 since it has gotten really cold here. ( Single Digits, sub-30 below windchill) Aybody else having this problem?? Recently had 15,000 mile service done and it has not improved?? any ideas??
Shawn Harstad
2000 F250 SuperDuty Lariat V10, LS, 4.30 gears, SuperCab, Short Box, PTTTM, UWS Toolbox
Shawn Harstad
2005 King Ranch Crew Cab 4x4
6.0L PSD
harstad is offline
Old 12-21-2000, 02:58 PM   #2 (permalink)
Re: V10 not a cold weather engine??
Yep all the above:
- longer warmups
- oxygenated fuel
- the cooler air has more oxygen so the computer has to compensate for this by adding more fuel to keep the fuel/air mixture right.
- also when you run the defroster, it kicks on the A/C compressor.
I bet there are other factors too.
00 F250 XLT SC 4x2 5.4L 5sp 4.10LS
KXHauler is offline
Old 12-21-2000, 03:34 PM   #3 (permalink)
It's like KXHauler said. All of our vehicles are getting worse mileage... it's not just the V10.
NoMo's website
NoMo is offline
Old 12-21-2000, 04:04 PM   #4 (permalink)
Might want to check the defroster and A/C item... The A/C normally runs in the defrost mode, but not if the outside temp is below 40 degrees F.
Correction -- my owners manual says the compressor will run only if the outside temp is 10C / 50F or higher. Cold morning operation seems to confirm this.
Nonetheless, my winter mileage is suffering as well...
[This message has been edited by crewzer (edited 12-22-2000).]
crewzer -- Y2K F250 SD 4X2 CC SB XLT 5.4LV8 AT 4.10LS
crewzer is offline
Old 12-21-2000, 06:27 PM   #5 (permalink)
RBM
Lost about 1 mpg since the cold weather. I am now averaging 11 mpg. Still can not complain V10 is awesome.
2001 F-250 SD V10 5 Speed 4:30 LS EC SB Lariat
Harvest Gold Tinted Windows Banks Stinger System
Harvest Gold Tinted Windows Banks Power Pack System
BBK 65mm Throttle Body Diablo Delta Chip Custom 1 inch Spacer
RBM is offline
Old 12-21-2000, 06:51 PM   #6 (permalink)
I can honestly say living here in the midwest that I have neveer had a car or truck get the same gas mileage as it does in the warmer weather.
1999 F250 4x4 Supercab, V10, Lariat, 4.30ls 6 National Spring Lift, Dual Shocks, 16.5 x 9.75 Weld Typhoons, 36x14.50 TSL Radials, K&N Gen. II, Magnaflow Dual Exhaust, Billet Grill, Line-X
My Truck
SDV10 is offline
Old 12-22-2000, 12:02 AM   #7 (permalink)
Are you idling more now to keep the truck warm. I know even in Houston when it gets in the low 30's I'll let the truck run for 5-10 minutes to warm it up before everyone gets in.
Just a thought,
Rob
robsd is offline
Old 12-22-2000, 12:28 AM   #8 (permalink)
If the engine never warms up, that would for sure be bad for mileage. Something else to think about is if you are getting oxygenated fuel, that can cost a couple of MPG also.
Fritzmaster is offline
Old 12-23-2000, 11:36 AM   #9 (permalink)
Yep.. the mileage goes down, but it tows stronger. I noticed this even in the summer. On cool days, the truck feels much snappier pulling my 5th wheel, while on blistering hot and humid days it looses that sensation.
snomoman is offline
