Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Gas Engines
Gas Engines Discussion of the gas engines available in the 1999-2007 Super Duty trucks
Old 06-10-2009, 10:36 PM   #1 (permalink)
v8 intake hose help
i rebuilt the engine and i need some help with the hoses. if anyone has a diagram of all that would help. but coming off the air filter housing there are two hoses. i have one going to the valve cover. can someone tell me where the other one goes or show me a picture. thanks in advance
hco4x4 is offline
Old 06-11-2009, 06:29 AM   #2 (permalink)
MikeMcCasland's Avatar
I know exactly what tube you're talking about. The Ford DVD calls it the "Idle Air Control Fresh Air Tube". This hose that I am talking about is the larger one that is above the crank case ventilation hose which does run to the valve cover. Both of these connect to the intake tube.
Edit: I just ran outside and took at aook at my V10 which should be the same as yours. It kind of u's around and connects into a large canister and then u's back into the top of the upper intake. This is tucked away pretty far back up under there. I just tried to take a picture but my damn camera ran out of batteries.
I'm charging it and will get you a pic asap.
MikeMcCasland is offline
Old 06-11-2009, 06:42 AM   #3 (permalink)
Old 06-11-2009, 06:45 AM   #4 (permalink)
Edit2: Please ignore my obvious leak from the throttle body/upper intake. Now I'm going to OCD about that until it's fixed.
Old 06-11-2009, 10:51 AM   #5 (permalink)
that was it! thanks a lot i owe ya. she runs great now
hco4x4 is offline
Old 07-02-2009, 07:10 PM   #6 (permalink)
so the hose on the passenger side valve cover goes to the bottom of the throttle body, correct?
hco4x4 is offline
