Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Gas Engines
Gas Engines Discussion of the gas engines available in the 1999-2007 Super Duty trucks
Old 01-23-2003, 10:15 PM   #1 (permalink)
What if I DON'T get the 4.3?
After reading just about everything in all the forums, I was psyched to buy myself a F350 DIESEL truck. (I'm planning on pulling a 10,000 lb 5th wheel for an entire year.)
I took one out for a spin, heard the racket it made and went, "you mean people actually LIKE to ride in these things?" Reply: "C'mon! You're a GUY! ...BEER! ...SPORTS! WHAT noise?
I think I'll enjoy listening to NPR and having a quite converstion with my girlfriend in my BIG, HONKIN' V10 TRUCK!! GGRRRR!!!! (sorry, got carried away there) :-)
Anyhoo...I found an 1999 F350 4WD V10 that I'm in love with. (Way low mileage!) It has the stock 3.7 axle. I'm planning on pulling a 10,000 lb + 5th wheel all over America with this (possible) truck. You guys convinced me I want the 4.3 axles, but what if I DON'T find a truck with 4.3's and go with this one?
* Just how horrible will towing a fairly heavy 5th wheel be?
* Will it be more strain on the engine if I have 3.7's? (I thought the engine revs faster with the 4.3...doesn't THAT wear out the engine sooner? (Note the ignorance in that question.)
* What's the worst peformance I should expect? (Example: "Oooh, you'll be sorry when you hit the Rockies pal...YOU'LL BE SORRY!!")
* What if I'm not a lead foot? I drove a 29' Class C motor home half way up the east coast and I didn't go over 60. I don't mind if anyone passes me with a Chevy...I won't take it personally. :-)
Biks is offline
Old 01-23-2003, 10:54 PM   #2 (permalink)
Re: What if I DON'T get the 4.3?
Just some info.
GCWR 3.73 is 17,000
GCWR 4.30 is 20,000
Trailer wts
3.73 10,600-11,100 depending on cab
4.30 13,500-14,100 depending on cab
2005 V10, AT, Fx4 Dark Stone Metalic, Crewcab F350, 4.10LS, shortbed, towcomand, Extang tonno **SOLD**
2007 Dodge 3500 Quadcab, 4x2, 6.7L Cummins, a/t, longbed, 4x2
Silence is golden. Duct tape is silver.
V10 man is offline
Old 01-24-2003, 09:26 AM   #3 (permalink)
The 3.73 will pull that trailer just fine as long as you stay at 10k (of course you're gonna be one of the slower folks out of the gates). Your fuel milage will probably run between 6-8 mpg if you keep the speed down (more speed = more fuel). I recently pulled a 9000lb travel trailer through the foothills of the Smokeys for about 300 miles. Very tall trailer in a headwind (Thanksgiving weekend 30+ mph wind), and averaged about 5.5 mpg. Note that I run 285/75/16s which reduce my ratio to about 3.55s.
You also have the option of changing the gear ratio. If the deal is sweet enough on the 99, it may be well worth it.
JMHO
Robb [img]/ubbthreads/images/graemlins/grin.gif[/img]
Robb Wing from Cincinnati,Ohio FOKISD Charter Member/Founding President
99.5 F250SD XLT,4X4,CC,SB,SRW,V10,Auto,3.73LS,ESOF,Deep Wedgewood Blue,Swiss Cab-high Cap,Pioneer DEH-P7300,Alpine Amps,Infinity Sub,Street Scene Grill Inserts,full-chrome grill,Fumoto,SPA Gauges,Rancho 9000s w/remote & stabilizer,Heated/Lighted TT mirrors, Jordan Ultima 2020,TYC Elegante Tail Lights,Great Covers Endura Seat Covers,Auto Lock Underseat Drawer,Hella Micro DE Fogs,Full Chrome Front Bumper,PML Diff Cover, JAD Solutions LED running lights below doors,18" Harley Wheels,keypad,chrome tow hooks,leather steering wheel, PF 2-piece Rotors and "Z" pads in front - PS Cryo and Hawk LTS in rear,BANKS Stinger Plus,Banks TransCommand,GMT Transmission My Pics
todlake is offline
Old 01-24-2003, 10:05 AM   #4 (permalink)
DirtFarmer's Avatar
Hi Biks-
I've pulled trailers all over with big gassers. Last gasser was 460 with 3.55 rear end. It really did well - at lower elevations. The only time I hated that truck was when we'd head to the mountains. Its power dropped noticably at 6000 ft, and at 9000+ feet, it was wheezing up the hills in a low gear.
I'd guess that the 6.8 with 3.73 would be a good puller for a 10K trailer unless you plan to spend lots of time in the mountains and then a turbo (diesel) would really be a better option.
Best,
Mark
2001 Cab and Chassis F350 SuperCab DRW 4x4. 7.3L. 6spd & manual xfer. snow plow pkg.
Home built flatbed featured on thedieselstop.com
DirtFarmer is offline
Old 01-27-2003, 03:11 PM   #5 (permalink)
F-250 and F-350 SD trucks equipped with the PSD or V-10 and 4R100 AT and built before February 6, 2000 were equipped with a single ATF cooler, an oil-to-air (OTA) model located low and between the main radiator and the A/C condenser.
It seems that the single cooler architecture used on the early trucks just wasn't enough to properly manage the ATF temperature. Excessively high ATF temps apparently led to many early AT failures, and Ford issued a TSB to retrofit the additional cooler into early trucks. [img]/ubbthreads/images/graemlins/mad.gif[/img]
F-250 and F-350 SD trucks equipped with the PSD or V-10 and 4R100 AT and built after February 5, 2000 are equipped with two coolers. In addition to the OTA cooler, there's an oil-to-water (OTW) cooler located inside the cold bottom tank of the main radiator. These two coolers are plumbed in series. [img]/ubbthreads/images/graemlins/cool.gif[/img]
Nonetheless, low forward speeds and heavy use of reverse gear, such as summer stop-and-go traffic or jockeying a trailer into a campsite, can elevate ATF temp in a hurry, even with the two cooler system. [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
If you decide to go ahead and buy the ’99, you may wish to install at least an ATF temperature guage, and perhaps an additional cooler as well.
HTH,
crewzer
Article No.
00-24-4 TRANSMISSION - 4R100 - FLUID OVERHEATS DURING SEVERE DUTY - AVAILABILITY OF UPDATED FLUID COOLER/FILTER KIT - VEHICLES PRODUCED BEFORE 2/6/2000
Publication Date: NOVEMBER 14, 2000
FORD: 1999-2000 SUPER DUTY F SERIES
2000 EXCURSION
This article applies only to 1999-2000 Super Duty F-Series vehicles equipped with a 6.8L or 7.3L engine built 1/5/1998 through 2/6/2000, and 2000 model Excursion vehicles equipped with a 6.8L or 7.3L engine built 7/1/1999 through 2/6/2000.
ISSUE:
Some vehicles, equipped with 4R100 transmissions, built prior to 2/6/2000 may benefit from additional cooling during heavy duty use conditions (i.e., snow plowing, towing, carrying heavy loads.) A revised transmission Fluid Filter/Cooling Kit has been developed to aid in fluid cooling.
ACTION:
Replace radiator, cooler lines, and hoses for transmission fluid cooling system with current level parts on vehicles built prior to 2/6/2000, ONLY WHEN transmission hardware confirms customer condition of inadequate transmission cooling. Refer to the following Service Procedure for details.
SERVICE PROCEDURE
If vehicle requires service, repair any transmission damage as required.
If inadequate transmission cooling is suspect:
Replace radiator, cooler lines, and hoses with current level parts. The radiator has an internal transmission fluid cooler.
For removal, refer to appropriate model/year Workshop Manual.
For installation, follow procedures listed in the appropriate model 2001 Workshop Manual.
Once the transmission fluid cooling system has been updated, install the Transmission In-Line Filter Kit (XC3Z-7B155-AA) per TSB 00-23-10. Follow the instructions included with the filter service kit.
PART NUMBER PART NAME
YC3Z-7N291-AA Clip - Transmission Oil Cooler
YC3Z-7R081-AA Hose Assembly
YC3Z-7A031-AA Tube Assembly
YC3Z-7A031-CA Tube Assembly
YC3Z-8005-BA Radiator Assembly
XC3Z-7B155-AA Filter Kit - Transmission In-Line
OTHER APPLICABLE ARTICLES:
00-23-10
WARRANTY STATUS:
INFORMATION ONLY
OASIS CODES:
504000, 510000
crewzer -- Y2K F250 SD 4X2 CC SB XLT 5.4LV8 AT 4.10LS
crewzer is offline
