Why am I running rough at idle and stalling?? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > 1999-2007 Gas Engines
Old 06-07-2007, 02:31 PM   #1 (permalink)
doczenith1's Avatar
My Photos: (11)
My engine light came on (and stayed on) early this week while my sister had my truck. I drove it today (engine light still on) and it likes to stall at idle. It also seems like it is 'missing' while accelerating. Last weekend we got some heavy rain and I splashed through many deep puddles. Could something be wet? There is about 72000 miles on the truck and it has the original plugs.
Thanks,
Al
2011 F350 Lariat, SC, SWB, 6.7L, 4x4, 3.55ELD, FX4, Lariat Int Pkg, 20's
Ordered 10/27/2010
Delivered 12/13
2003 Mustang SVT Cobra, black convertible. - 6/2007
2002 F250 Lariat, V10, 4x4, auto, 3.73LS, SC/SB, camper & off-road pkg. 12/2001 - 12/2010 - SOLD
Link: Differential Cover Spreadsheet
Link: Fuel Mileage Spreadsheet
Link: Rapid-Heat Sup Cab Heater Test Graphs
doczenith1 is offline
Old 06-07-2007, 02:33 PM   #2 (permalink)
Snake Eyes's Avatar
Re: Why am I running rough at idle and stalling??
Bad coil?
2008 F-350 CC SRW FX4 156"
Black/Black, 5.4L/6 Speed, Manual transfer case/hubs, 4:10LS, 20's, Custom dual exhaust with straight pipes, Line-X, and Royal Purple in the pan.
Planned modifications:
8" Fabtech lift, 40s, 4:56's, balanced and blue-printed 528 Super Cobra Jet transplant.
NRA Life Member
Snake Eyes is offline
Old 06-07-2007, 02:39 PM   #3 (permalink)
Before attempting to just throw parts at it and hoping to fix it, I would find out what code is tripping the SES lamp. That should give you a direction to start in troubleshooting.
Buddy
Former Ford Diesel Tech
ASE Certified Parts Counterperson, Automotive, Medium, & Heavy Truck Technician
1999 F250 XLT 4x4, Red, 7.3 6spd AWA5, 3.73LS rear, CCV Mod, APC Headlamps, Autometer C2 Gauges, (Boost,Pyro,Trans), 4" Turbo-back exhaust, XM Radio, AIS, ITP Regulated return, fuel feed lines, Airdog, & 4pos. chip.
My Truck
2001 Ford Escort ZX2 - Black- 4cyl 2.0DOHC, 5spd.
1999 F350 4x4 XLT, CC/LB PSD, 6spd, Aluminum service bed, York Compressor Onboard air, CCV, Custom Intake & Exhaust, Strobes and a few other goodies
RIP Steph F. & Trista J., 4/27/07, you will be missed by many.
budman451 is offline
Old 06-12-2007, 08:54 AM   #4 (permalink)
doczenith1's Avatar
My Photos: (11)
I took my truck to a parts store and they hooked up their scanner to it and these are the results.
Vehicle Scanned
Global OBDII
Vehicle
DTC (Codes)
P0720
Output Speed Sensor
Circuit Malfunction
DTC Pending (Codes)
No Faults Detected
So, I still don't no for sure why it is missing. The guy at the parts store tried to tell me the tranny was not functioning properly causing the truck to stall at idle. I told him it did it in park and he said that the tranny was not releasing the torque converter properly and gave me a business card for his friend who owns a transmission shop. I smile and said thank you, walked out the door and threw the card away when I got home.
From the other related post in this forum it looks like I need to take it to a mechanic that can hook up a more advanced diagnostics tool. Can any mechanic do this or do I need to go to the Ford dealer?
Thanks,
Al
P.S. Good thing I just bought a 2003 Cobra last week. Perfect timing [img]/ubbthreads/images/graemlins/smile.gif[/img]
Ordered 10/27/2010
Delivered 12/13
Old 06-12-2007, 02:47 PM   #5 (permalink)
Vehicle Scanned
Global OBDII
Vehicle
DTC (Codes)
P0720
Output Speed Sensor
Circuit Malfunction
DTC Pending (Codes)
No Faults Detected
Thanks,
Al
I could be wrong here, but every time I've had an issue with the speed sensors, the ABS light would come on, not the SES light. Any good mechanic would probably have a better scan tool; I don't think you need to take it to a dealer.
-Jason
2008 F250 Lariat, 4X4 Off Road, Snowplow Package, Nav System, Tow Command
1995 F150 5spd 4x4
jss304 is offline
Old 06-13-2007, 01:25 AM   #6 (permalink)
Send a message via ICQ to BASSAGE
Could be the IAC motor is sticking.....the 90 degree elbow that goes into the back of the intake from the pvc valve could also be leaking.
Just some things to look at.
Good luck.......Dan
BASSAGE is offline
Old 06-13-2007, 11:14 PM   #7 (permalink)
EGR sticking open would be my guess. Get the codes pulled and see what comes up. IAC would not cause the engine to mis while accelerating.
2000 Black Excursion,PFC 2 piece rotors,Tipton tuned,BDP stage 2 singles, BDP H2E, AFE stage 2, Spearco 7.3, ITP Reg. return fuel system, Evans, BTS, 186,000 miles....And still goin' strong! Thanks Beansdieselperformance.com and Puredieselpower.com for all your help
BBBxcursion is offline
Old 06-14-2007, 01:48 AM   #8 (permalink)
No the IAC won't make it miss, but it will let the engine stall like the first part of the post said........is this not true?
Dan
99.5 Build Date 3/99 Red Crew Cab 4x4 DRW Lariat..... Gages and SCMT,6.0cooler,muffler delete and home made Tymar intake, Gutted EBV, Wicked Wheel,Non EBV turbo Base,manual locking TC with LEDs
BASSAGE is offline
Old 06-14-2007, 01:44 PM   #9 (permalink)
doczenith1's Avatar
My Photos: (11)
I drove it for the first time in a few days and it is running fine which leads me to believe something got a little wet and is now dry. The SES light is still on and I dropped it off at the dealer this morning. Will post the results when I get them. Thanks for all the input!
Al
Ordered 10/27/2010
Delivered 12/13
Old 06-14-2007, 06:34 PM   #10 (permalink)
Good luck Doc!!
Have a good one....Dan
BASSAGE is offline
Old 06-19-2007, 03:01 PM   #11 (permalink)
doczenith1's Avatar
My Photos: (11)
Took the truck in to the dealer and here are the results:
"Scanned vehicle. Found miss on cylinders #2 and 4, found coolant in cylinders then removed coils from 1 and 3, also found coolant in them, cleaned 1 and 3 then replaced coil and plug on cylinder #2 and a plug in #4."
Before I took the truck in I removed my heater core mod (see pics) and some coolant spilled on the engine. I did this the day before I took the truck in. The truck ran fine on the way to the dealer. I did spill some coolant when I installed the mod a few years ago. Perhaps this caused the coil to malfunction over time.
Total cost was $241.00 which included $160 in labor, $58 coil, two $3 spark plugs and tax.
Ordered 10/27/2010
Delivered 12/13
Old 06-20-2007, 03:54 AM   #12 (permalink)
You a city boy? lol That was about the most apparent sounding thing in the world, any time you have stalling missing, and worsening on hills, etc. My first thought it check plug wires, plugs, coil. Easiest but most "shocking" is leave vehicle running, and listen to the motor, one by one take off a spark plug wire, if the wire is working well, it should miss bad, and sound like [censored], if it is bad there should be little or no difference, if you ever do this dont be surprised to get a little shock. But if you change the wire, and it doesn't fix the problem, replace your coil pack. Thanks fordguy09
1993 F-250 5-speed 4x4 7.3L Non-turbo Silver/White Standard cab longbed, American Raching 16.5" wheels, brush guard,Loud duals.
fordguy09 is offline
Old 06-20-2007, 01:22 PM   #13 (permalink)
Snake Eyes's Avatar
Hmmm, my first post to this thread read...
"Bad coil?"
NRA Life Member
Old 06-20-2007, 02:39 PM   #14 (permalink)
doczenith1's Avatar
My Photos: (11)
Did I grow up living in a city..yes. Am I a "city boy" no. I grew up working on a farm and also working on cars and tractors. Have done all sorts of engine work including an engine swap in my 1978 Ford Fairmont (they were so good they quit making them, nobody was buying new cars) [img]/ubbthreads/images/graemlins/laugh.gif[/img] . I figured it was either a bad coil or spark plug but when I got around to checking which one the engine was running fine. I took it to the dealer because the SES light was still on and I wanted to have them hook up the diagnostics equipment and make sure everything was right. I will be towing the boat a lot this summer and don't want to breakdown on the side of the road.
You a diesel boy? lol I don't think they have made gas automobile engines with spark plug wires for quite a while. It is all coil-on-plug now.
And yes, I've felt the shock from a spark plug more than once [img]/ubbthreads/images/graemlins/smile.gif[/img]
Ordered 10/27/2010
Delivered 12/13
Old 06-20-2007, 04:09 PM   #15 (permalink)
Snake Eyes's Avatar
That's one nice civil reply there "City Boy"! [img]/ubbthreads/images/graemlins/laugh.gif[/img]
NRA Life Member
