Pull N Power LLC is proud to present Blackford County Truck & Tractor Pulls June 20. This is the same pulling association that put on the FASS Diesel Nationals this year at ORP.
Weight
Class
Purse
6200
Small Block
$500
6800
Big Block
$500
Pull N Power LLC Diesel Points Pull
8000
Work Stock
$500
8000
2.8 Super Street
$1,000
8000
Pro Mod
$1,500
American Big Block Modified Rails Members Only
Big Block Modified rail Tractors
$300
Hook Fee is $30 for all classes
Tech in is at 4:00
Pulls Start at 5:00
Rules for the Diesel Classes are the same as at ORP this year except no 2.6 class and no open class.
Big & Small Block Gas Rules
- No exhaust Through hood
- Open headers allowed, must exit under cab
- No tunnel rams
- Only single carb or O.E.M. Port injection
- 1 ton or less diff. no planetary’s
- No trick hitches. Must hook to clevis 3” or larger opening. No ball type
- Valid drivers license, registration, and insurance required
- Full interior required and Head – Tail light assemblies
- O.E.M Seat Belts worn
- O.E.M Fire wall in tact with no openings larger than 1sq in
- D.O.T tires no dual’s
- No hanging weights with no weights in cab. Weights allowed in bed securely fastened
- Pump gas only
- No Nitrous / No Drugs
- Zero Tolerance in effect: No speeding on track or while exiting track and pit area
- If driver is under the influence of alcohol or drugs, they forfeit all fees and will be escorted of fairgrounds.
- All participants must sign Pull-N-Power insurance waiver
- Hook fee $30 non refundable
- Tech officials have the right to disqualify and or remove any individuals that do not comply
Sponsors: Dave’s Diesel Angola, I69 Trailer Center, and Pull-N-Power
