Re: The Buck and See Photos
David nice pictures. I was the green dodge that was pulling. Just wanted to say thank you as that is the first photo that I have of the truck in action. I will be at the mud bogs this weekend. I also wanted to invite everyone to the pulls at the buck on Aug the 12. Mike Hoff the track president came to me and asked if I could put torether a class for the pull on the 12. As of now it lookes like a go.
Tom Petrick
96 2500 club cab 4x4 dodge. 2.5 skyjacker 3body lift 36 12.5 16 swampers JRE 400hp plate afc apring kit 16 housing on hx35 turbo 5" exhaust turbo to tail Auto Works custom injectors governor spring kit. No more 3000 rpm goes to 4200 pump timed open k&n filter McCloud clutch for now.
[This message has been edited by Tom96 (edited 08-05-2000).]
96 2500 club cab 4x4 dodge. 2.5 skyjacker 3body lift 36 12.5 16 swampers JRE 400hp plate afc apring kit 16 housing on hx35 turbo 5 exhaust turbo to tail Auto Works custom injectors governor spring kit. No more 3000 rpm goes to 4200 pump timed open k&n filter McCloud clutch for now.McCloud has been toasted and broke into little pieces along with the first input shaft. I now have Mitchell's dual disk race clutch. Dynoed 410.4 hp on 1/20/01
