New England Meet - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > General Discussion > Events and Rallies
Events and Rallies Discussion of past and upcoming events involving Ford trucks and diesels.
Old 08-30-2009, 11:23 PM   #1 (permalink)
kolo's Avatar
New England Meet
Well as promised Dan put on the beginning of a good meet, Turn out was low however, I'm sure a lot of food and beer, Yes beer had to be taken home. And when I say food , I mean a wide variety as well. The weather might have kept some of you away, If Dan does this again don't let the weather keep you away as the setting is perfect rain or shine. The park is large enough to provide multiple covered pavillions. This one even had a fire place which Dan had put to use. The setting is fairly private under the trees and bathrooms are also close by. There is ample room to spread out and play ball or whatever in the fiels as well. quite a few nice trucks and custom Mods as well. Thanks for the effort Dan, hope to do it again next year, with a larger turn out this could be quite and event and well worth traveling a couple of hours for if needed.
1993 F450 Superduty 2 whl drive,7.3 IDI, E4OD auto, non Turbo, reg. cab flat bed, mostly stock I believe.
1997 F350 crew cab 4x4, PSD, open air intake, 3"down pipe,MBRP, sonnax valve in auto, gutted EBPV, 130,000 miles, 4.10 limited slip,fifth whl. hitch, now Dually with 96 Axle, International water pump w/coolant filter, 57 gals. w Bronco rear/ 24 plastic front, electric fan on tranny cooler.
kolo is offline
Old 08-31-2009, 09:38 AM   #2 (permalink)
jdc753's Avatar
My Photos: (31)
Send a message via AIM to jdc753
I agree, was a good time and worth the 2 hour drive, gotta try and get more people for next time and it would be perfect. Pavillion worked great and food was great too.
86 Ford F250 4x4 with 4in Rough Country lift and poly bushings all around converted from 351W to 6.9L Diesel (rolling chassis at the moment)
05 F350
jdc753 is offline
