I have a 1997 7.3 powerstroke that is still leaking. I replaced the lift pump that was leaking. Now I found a leak that is leaking from the sensor (??) that gauges if there is water in the fuel, on the fuel cannister. Can I just fix that or just replace the whole cannister??? Thx!!
You will get more and faster help if you post down in the regular forums. As far as the leak yes you can replace the sensor or if you would like just remove it and put a pipe plug in its place. If you plug it off just remember to drain the housing every now and then to keep water out of the injectors.
Mine just started leaking the other day in the same area, just looked at valley and don't see any puddling ..... is it still the bowl drain "O" rings??
Mark
2011 F250 6.7L Lariat 4x4 Crew/Shortbox - Vermillion Red
My 95 Ps 7.3 is leaking bad!! It began stalling now and then. Then I noticed stains on the driveway, thought tranny was leaking, it was diesel fuel. Its deep enuff in the block valley to splash with you fingers.... A mech has removed all but the filer housing and can't find the leak yet... what do you think, could this post be about what is wrong ???
yess i have the same problem if you figure it out please let me know i just replaced all the hose lines. and it seems it only leaks when it wants to
NEW BABY- 2005 Chevy Duramax Diesel CCSB.... 8 inch fabtech lift 37 inch mickey Ts on 18inch flat black pro comp Rims. Edge Insight EFI!, straight exhaust. AFE intake and turbo inlet. EGR blocker plate Fully loaded Pioneer DVD double in deck. 2 12 inch shallow fosgates... sorry i switches guys but this thing is Bad To The Bone.
f-350 4 door long bed. 6 speed. 5 inch stacks. 9 inch lift. 40 inch Ground Hogs. custom Front and rear bumpers with 10,000 Warn WincheSSSSSS.K&N TW chip, stage 1s, IDM mod, exhaust brake. limo tint. peterbilt cab lights. dvd screen 2 shallow fosgate 12s (sick!!) and everything else you can think of. damn ive spent way to much money on this truck.- newest smartest and awesome edition is a set of custom built track bars. should have gotten these from the get go
I got a 96 F250 4X4 7.3 with same leak....pooling by the turbo...it started when the filter was changed...I called a shop I use and the 2 fixes he gave was replacing/reseating the filter about $100 and lift pump about $750....
I found the culprit/leak called the Fuel Restriction Sensor. Search this website. One post said prior to 97, it's located on the bottom of the fuel bowl. My 97 is on the top. On my way now to H Cheapo for the plug
Reason: pic
Trying to replace my fuel filter on a truck I bought this weekend. "Water in Fuel" light is on. My drain valve does not seem to want to open. Is there a trick to it? I am afraid to force it and break something...
My valve is black/grey and located in front passenger side of bowl.
Yesterday I went to replace the fuel filter, old one quite dirty, couldn't open valve so I sopped all fuel up in bowl with very clean rags. It will left about a 1/4 inch of liquid in the bottom. (Stuff in the way preventing getting rags all the way down there.) I put in new fuel filter. Now light goes off and on (mostly on) so I must have gotten some water out. Assuming I can get valve open, can I now just open it and let rest of water out?
Hey. I have a 1996 Ford F350 7.3 Power-Stroke. I have diesel puddled on top of my engine and disel dripping down on the trans and starter. Is this what you are referring to? HELP...
jtownes14
I have the same problem I replaced the o ring and the hoses it still leaks Helpppp. Bozo 442
For what it's worth, my fuel leak was from the left fuel return hose, which had rubbed on the hpop for 14 yrs. and got a wear spot. I wrapped it(leak area)with some hi perf tape made for leaks, then put the id tag over the tape, and used a small hose clamp over the
tag, just to hold until I could get a new hose. I have the new hose, however, it will take a
crowfoot 12pt to loosen the 9/16 swivel fitting from the head, which I don't have, yet. I had a tuff time finding that leak.......
My 95 f350 7.3 required the fuel filter housing to be replaced. The canister was rotted through at the bottom. The guy who sold it to me had cobbled iT up with some kind of epoxy I think... and it went bad after a few months. Was over $300 to replace. I guess It pays to blow the water out thru the valve once in a while. There's at least a couple hose connects under the bottom that I thought must be leaking.....turns out pinhole leaks in the most expensive component,
I have a 97 F-250. Mechanic says fuel bowl and drain valve are bad. Quoted $700 to fix and replace both. Is this a really complicated fix or something a mechanically inclined person do? Any help would be greatly appreciated.
