LongATVRamps.com Product Review - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > TheDieselStop News & Polls > The Diesel Stop News
The Diesel Stop News News related to Ford Trucks and the TheDieselStop Web Site. Only Administrators may create new threads in this section.
Old 11-17-2009, 12:28 PM   #1 (permalink)
Administrator's Avatar
The great folks over at Long ATV Ramps have sent our Super Moderator Dick Cutting a free pair of ATV ramps so he could test them out for all of us here at TheDieselstop.com. The ones they sent him are the 9.5 ft long ramps. Here is a Pic of the Ramps from their site:
Here are the specs for the ramps:
Our 9.5' ATV Ramps will support up to 1000 lbs per ramp or 2000 lbs per set.
Size
9.5 ft. x 15 in. wide
114 in. extended
Folds To 64 in.
Weight
Approx. 28 lbs per ramp.
Dick wrote about his personal experience with the product and took some pics of his own:
"The 9.5 ft. Long ATV/UTV Ramps are very useful items to enable a person to safely load an ATV or UTV into a higher level pickup truck. The Truck shown is a standard F350 but sits higher than lighter versions of the same truck brand.
Using the bit longer ramps helps out when loading or unloading spots someone needs to use are not fully on level ground. Being a bit longer helps reduce the steepness that the ATV is required go up into the vehicle or when backing down out of the vehicle.
The ramps are easy to place in position for their use. The attachment of a strap on each one to hold it in place so it won’t slide off the tailgate is easily done also. They are strong ramps and their design provides an ATV or UTV with excellent traction capability and are also very stable while using them.
A Customer’s purchase of a set of Long ATV/UTV Ramps would result in their being very pleased with their performance."
Pictures of the Ramps In Action on Dick's Truck:
Following up with Dick about the ramps a couple of times myself, he said he was very satisfied with them and their ease of use. The length of the ramps was a great help when loading the machine by giving the rider a good angle that is not too steep of an approach. This especially helped Dick as his truck is a little higher than average. Also, he said the quality of the ramps is top-notch and they look slick as well. Thanks again to Long ATV Ramps for sending our mod the ramps and so the members know, these ramps are TheDieselstop approved! Take a moment to check out Long ATV Ramps VENDOR FORUM and their company website LongATVRamps.com is the only place to buy high quality aluminum long ramps for your ATV or UTV. Thanks again to a great site sponsor!
Nadeem
LongATVRamps.com Product Review-atvramps1.jpg   LongATVRamps.com Product Review-loaded_in_truck.jpg   LongATVRamps.com Product Review-tailgate.jpg   LongATVRamps.com Product Review-longrampslogo.jpg   LongATVRamps.com Product Review-dickatv.jpg
Last edited by klhansen; 11-22-2009 at 01:47 AM. Reason: fixed screen width problem
Administrator is offline
HTML code is On
