Go Back   Diesel Forum - The Diesel Stop.com > TheDieselStop News & Polls > TheDieselStop News
TheDieselStop News News related to Ford Diesels as well as site news. Only Administrators may create new threads in this section.
Old 08-31-2009, 02:35 PM   #1 (permalink)
Administrator's Avatar
Report: 2011 Ford Super Duty to Get New 6.7-Liter Power Stroke V8
Ford is set to release a revolutionary new 6.7-liter Power Stroke turbo-diesel engine for its line of Super Duty F-Series trucks in 2011. The all-new engine promises a, “significant improvement in torque, horsepower and fuel economy,” says Ford in a press release, stating that this new F-Series Super Duty would continue to be a class leader in both payload and towing.
Numerous high-tech innovations have been employed in building this new engine, starting with a compacted graphite iron (CGI) engine block that Ford says is twice as strong as standard iron blocks. This was deemed necessary due to the increases in power output.
The new engine makes use of a Honeywell single variable turbine turbo (similar to the one found on the Porsche 911 Turbo), but takes turbo technology a step further still. Instead of one, there are two compressor wheels driven off a single turbine impeller, working like a bi-turbo setup that gives the engine a fast response time with little lag as well as the power of a larger turbo.
Visually, the new engine looks remarkably different, due to the fact that the intake and exhaust systems are the reverse of a conventional engine. The exhaust manifolds sit in the valley of the big V8 engine, while the intake manifold is on the outside. This means the cylinder heads are essentially flipped around.
By significantly reducing the amount of exhaust piping, lag is reduced considerably. Additionally, this new packaging moves the hotter elements of the engine (like the turbocharger and exhaust pipes) away from the intake areas, ensuring a constant supply of cool air to the engine. And as for that turbo, it sits in the valley between the cylinder banks. Due to its location, spool up is considerably faster and the engine's overall balance is improved. Another major benefit of this setup is that that cab no longer has to be removed from the frame if work needs to be done on the turbo. The fuel-pump, EGR (exhaust gas recirculation) components and the thermostats are also easily accessible from the front of the vehicle.
Ford hasn't released any specifics on the new engine but if out scientific and sophisticated brains have understood all this talk of a sequential variable turbine geometry turbo correctly, our power-loving neanderthal brains are in for a real treat when this new package makes it to market.
More: Report: 2011 Ford Super Duty to Get New 6.7-Liter Power Stroke V8 on AutoGuide.com
Administrator is offline
Old 09-01-2009, 10:35 PM   #2 (permalink)
massbadass's Avatar
Send a message via Yahoo to massbadass
Sweet.
Iraq vet and back home for good!
95 F250 SC 7.3PSD 4x4
84 Bronco II project truck will be turning 37's
when im done with it.
massbadass is offline
Old 09-03-2009, 07:57 PM   #3 (permalink)
isnt this new diesel a urea dependent design for elimination of NoX? so then we will all need to keep an eye on our urea tanks.
09 F350 Lar. CC. LB. 6.4L PSD- 9'2" Boss V
02 K2500HD LS. Ext. Cab, SB, 6.0L- Meyer C8
98 C3500 Dump, 5.7L- Blizzard 810PP
ProTouch Groundscapes LLC.
Full Service Comm./Res. Property Maint.
Frndinalowplace is offline
Old 09-04-2009, 11:37 AM   #4 (permalink)
If it gets better diesel fuel mileage but also has to have the urea then the effective mpg which I figure as $$$$ per mile could remain the same or even be higher. If something doubles my mileage but itself costs me 6 times per gallon more then I have not saved any money.
GOD BLESS OUR TROOPS!! - GOD BLESS AMERICA!!
Rick M is offline
Old 09-06-2009, 06:40 PM   #5 (permalink)
NEVERSWEAT7's Avatar
I have been rattling cages at two local dealerships with not a word on release of this beast. In the BlueOval pages Engineers are chatting up about how it will start production in as soon as Nov this year and could be Job build #1 as soon as Feb. details are cloudy as to exact confirmation as just in Ca. alone emmisions will have to be met.
Over 400 HP and 720 ft lbs. and better fuel mileage screams buy me but the urea issue( which really isn't much of an issue if F takes the lead and treats it with oil changes) is something to keep in the recesses of your mind.
This is an all F built product as the connection with Navistar has been severed on Powerstrokes. That being said, the Powerstrioke title will remain in place.. according to sources in BlueOval.. but the name Scorpion is stamped on it. There is a whole fact sheet on that engine which is pretty awesome even to me.. a non-mechanic.
I have been following this project in depth as I just ordered a 2010 F-450 King ranch. I was considering holding off on the build-out to wait for the 6.7L beast however trips are planned for next summer and the 2010 is a beast in its own right. The salesreps get visits by Engineers who talk of upcoming projects with dates that do not seem to ever get met...according to a few I spoke with.
Six months for the 2011 would be fine but I cannot get anyone to confirm Job #1 so I may own this 2010 F-450 4x4 King Ranch for a year and lose it for a new one...maybe. Yes, I will eat a few bucks and pay more but I want one more truck to take me until the end of days. I am a F man.. enough said. Plus the incentives to move the last of the 09s and last in line 10s which are just starting production ( just got confirmation yesterday mine is starting build-out) is a phenom not to miss.
And the stock is in the low 7's!
New Ordered: 2010 F-450 4x4 King Ranch "loaded"
Old 2002 F-350 4x4 LB CC SRW 7.3
SET-UP:
Banks Six Gun Tuner, Power Pack, Triple "A" post gauge set, TC, Banks Exhaust Brake , 4" exhaust/5" tip, RideRites, Schaeffer Premium fluids through-out, K&N, 6.0 tranny cooler
NEVERSWEAT7 is offline
Old 09-07-2009, 12:08 PM   #6 (permalink)
Yes, they said some/most trucks will only need a refill at oil change. I expect they sized the tank with that design goal.
Refilling the tank is fine with me if the engine meets the rumored specs.
dzzz is offline
Old 09-07-2009, 07:14 PM   #7 (permalink)
guardrail22's Avatar
Scorpion needs Urea injection, Maxxforce 7 does NOT
you know the Maxxforce 7 as the 6.4L Powerstroke. I had a chnage to drive a International 4400 hauler last week and have been researching their upcoming offerings.
Low and behold the Maxxforce website shares the tidbit that the Maxxforce engines meet 2010 emissions with no SCR.
Imagine that. Did we just get stung by a Scorpion?
New Truck
2008 F450 CC Lariat White/Gold, JAD Solutions Lights, 62 Gal Titan, B&W Hitch, Ford Gold Remote Start, TruckTrunk box, Viair 550+2x2.5gal receiver
Traded In Nov 07:
2003 F250 CC LB XLT 4x2 PowerStroke, Captains Chairs, White/Parchment, Torqshift, Heated Mirrors, Trailer hitch, Adv Security Group, Clearance Lights, Adj Pedals, Privacy Glass, Sliding RW
Delivered 11/27/2002
7100# with full fuel and no occupants
towing a 2005 Pilgrim 306RL-SS w/Hensly Arrow
guardrail22 is offline
Old 09-08-2009, 08:53 PM   #8 (permalink)
The maxxforce 7 is hardly a successful engine. The "heavy burden" of urea should be less than the "nightmare" of replacing washer fluid. I'm up for the extra work.
It's not like ford is the only company going to urea.
Ford wouldn't be doing the change without a loss of confidence in the maxxforce line. In the current economy it's the last thing their senior management would want.
I hope the new engine leads to a new 4 litter diesel design. But I suppose it could be another problem engine and a dead end.
dzzz is offline
Old 09-09-2009, 01:39 PM   #9 (permalink)
Wolley's Avatar
Aluminum heads huh? Well don't that beat all.
And inboard exhaust? Seems like Ford is copying the the General. Too bad GM put their minimax on hold now they don't have the bragging rights for the first production diesel with inboard exhaust.
Was just another Whiny Chevy driver
Since this is my second Ford in two years I guess I may be convert.
99 PSD CC Long Box 4WD 6spd
Southbend Con-O clutch. DVB Boost regulator, Gutted EBPV, Bilsteins all around, DIY Tymar, ATS housing, muff delete
Wildman four position chip.
Gauges of course!
Towing 2001 National Sea Breeze Fiver. 13K #
Wolley is online now
HTML code is On
