Re: 05 F-550 surge under load
Mine did the same thing- only under a load and only at low rpm such as 1500-about 1800. I think this engine does not like it much under 2000 rpm, especially when towing. Mine sounded like it was having multiple "turbo farts" too. I thought it was a wastegate, but I'm told these engines do not have a wastegate. I believe it is due to too much boost for the amount of boost needed by the engine at that particular rpm. I got the computer update that makes that "noise" for about 20 seconds after shut down. That took care of the problem and I noticed a less amount of boost in the same load situation. But with my programmer on the middle setting it still does it (when towing), so I just never let the rpm go down less than 1800rpm and it doesn't occur.
2005 Arizona Beige F250 6.0PS automatic, MBRP 4" turbo back, AFE stage I, EGR delete, ARP studs, SCTx3, B&W turnover ball gooseneck with 5th wheel companion, Firestone airbags, Dipricol gauges, B&D exhaust brake, Bedrug and Snugtop SL tonneau cover, Zoodad mod, Blue spring upgrade, Sinister coolant filter.
