12V fuel transfer pump - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Old 03-17-2013, 09:14 PM   #1 (permalink)
We just bought an '04 F550 we're turning into a farm service truck. I've done a few upgrades and some maintenace already like blue fuel spring, egr delete, bypass oil filter, coolant filter, gauges, alternator gone through, new batteries, etc. If we're going to run a 12v fuel pump off the battery, do you think I should come up with a way to turn the idle speed up or just get a bigger alternator? I don't know what kind of pump we're going to get yet but I've seen pumps listed from a 20 amp draw to a 35 amp draw depending on how fast you want to pump or how much you want to spend.
'94 F250xlt ext. cab. ZF5-speed 4x4. EBPV delete. DPP downpipe. Tymar intake. Tymar coolant filter. Type 31 batteries. LF9691 primary filter. Electric fans. 10k mod. 1.0 turbo housing. Boost blanket. Over-axle exhaust eliminated. Electric fuel pressure gauge. Heim joint clutch linkage. Adrenaline HPOP. BDP modded IDM. LUK SMFW. DIY Elec Fuel. FS1282, FF5320 fuel filters. SD starter. Dieselsite T-stat. DP 80hp tuned PCM.
'04 F550XL reg. cab. ZF-6 speed. EGR delete. Coolant filter. Cat EC-1 coolant. LF777 bypass oil filter. Blue-spring fuel pressure regulator. ScanGauge II. Glowshift fuel pressure gauge.
sdan27 is offline   Reply With Quote
Old 03-18-2013, 10:07 AM   #2 (permalink)
HeavyAssault's Avatar
My Photos: (6)
What if the intended use of the pump??
2006 F-350 CC PSD Lariat 4X4 LB 3.73 LS
Some stock stuff, some modded stuff, some deleted stuff.....
HeavyAssault is offline   Reply With Quote
Old 03-18-2013, 12:05 PM   #3 (permalink)
You should be able to do the high idle mod that idles the truck up for PTO use. I did it on my F250 back in 06 when I got it. I don't know if the F550 was any different. It is just a matter of connecting a couple of wires to a switch. I used one of my upfitter switches. Unfortunately it was so long ago i cannot remember which wires are which, but the truck should already be wired for it.
A bigger alternator is a got change even without the pump. I have a 200 amp Quickstart large frame alternator. The older style large frame alternators will bolt on without any changes to the truck.
2006 F250 Lariat Supercrew, ESOF 4x4, 18" tires, FX 4, HD Alt., block heater, Integrated Trailer Brake Controller, Upfitters, power rear window, cab lights - delivered 10/25/05
Ford Remote Start; High idle mod; Timbren load levelers, Scangauge II, Blue Spring upgrade, Quick Start 200 amp large frame alternator replacement, 2 batteries; GPCM replace October 2011; 2 EGR valves; EGR Cooler replaced 12/30/11; Performance Machine & Mfg. coolant filter added 1/2/12; Rotella T6 5W40 oil; turned rotors and replaced brake pads for 1st time 1/7/12 101K miles; GPCM, both subharnesses and all 8 glowplugs replaced 1/5/13 at 118,000 miles; 2 Ford batteries replaced under battery warranty.
Ford06 is offline   Reply With Quote
