2004 6.0 blew up I need help no boost pressure - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 06-14-2005, 06:55 AM Thread Starter
Can anyone point me in the right direction please. I have a 2004 F350 6.0 dually. Upgrades are Banks big hos bundle and airaid intake. The vehicle has 11,000 miles. I was coming home last night, made a left hand turn and gave it a little power. Then, What sounded like the turbo spooling way to high and then a enormous bang and huge clouds of some. I made it home, with no power or boost whatsoever, again a ton of smoke. I thought I spone a bearing in the turbo, I pulled the hose off and the impleller spins smoothly and easily. So I thought it was a intercooler hose. All were fine. I just replaced the transmission after loosing a pinion gear. Luckily the dealership relpaced it under warrenty. Though they did comment on the aftermarket upgrades. If any one has any suggestions or can point me in the right direction so I do not have to go to the dealership, I would be greatly appreciative.
tyssenb is offline
post #2 of 3 (permalink) Old 06-14-2005, 04:15 PM
Re: 2004 6.0 blew up I need help no boost pressure
if you were running modded and it blew, you better pull out your wallet [img]/ubbthreads/images/graemlins/sick.gif[/img] I doubt they will cover you this time around. [img]/ubbthreads/images/graemlins/frown.gif[/img]
2005 3500 Cummins HO NV-5600, 3.73 LSD....One box, two turbos, 2 pumps and 6 big sticks
871 HP #2 only
Co-President Mason-Dixon TDC
maximumstroke is offline
post #3 of 3 (permalink) Old 06-14-2005, 04:23 PM
tyssenb
Check pressure side of intake after turbo. It is common for the hose to blow off after turbo. Also, a few guys have had the seem on the intercooler come apart, not sure if you have the banks intercooler as they are supposed to be better and no seems but hoses may have came off.
Good Luck
TasMan
2004/04 Engine,King Ranch,F-250,4x4,SWB,3.73 LS, Adjustable pedals,Reverse sensor,Moon roof,clearance lights, Power rear window,Heated seats,Bedliner, DPPI T-409 Turbo Back, AFE Pro-Guard7, C-Bet'r mirror, Fumoto drain valve, AIC, Extange Tonneu, Lund SS Interceptor, Siver Star Bulbs, Harpooned tank, SUV double wiring harness, Bright Box, Clifford RS 3.5 alarm, 3" Edge Plush Ride, Bilstein Shocks, Westin Sportsman CPS Grille Guard, XM Commander wired in with a PIE Adapter, Eagle 137 series rims and Bridgestone Revos 285/75-16, Husky Liner Mud Flaps.
UpDated 27 October 2005
Retired Chief Warrant Officer 4
tasman is offline
