2004 6.0 Fuel Economy Tune or not - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 02-29-2012, 09:33 PM Thread Starter
I've got a 2004 6.0 Supercrew Lariat Stock 2WD. I'm getting 15-16mpg. I've heard bad stories about custom tunes. What about an economy tune to improve fuel mileage. Will this stress the engine or warp the heads ? With a good economy tune what kind of gas mileage increase could I expect to get ?
amxgilligan is offline
post #2 of 7 (permalink) Old 03-02-2012, 08:33 PM
15-16 doesn't sound too bad in my opinion.
Do a search on tuners. Give one of the custom tuners a call. A reputable tuner is not going to give you a tune that will hurt your truck if you drive reasonable. There are, however, quite a few things you could/should do before going with a tuner. There are a lot of knowledgeable guys here that can give some insight as to what you need to do to keep your 6.0 healthy. Then you might consider some tunes.
Good luck!
Mike
2015 F350 CCSB FX4 Oxford White
SOLD
'07 Dark Stone F-250 Lariat CC SB FX4 6.0 Auto, LS, power sliding rear window, power moon roof,
20" Nittos
PMM coolant bypass filter
4" turbo back Diamond Eye
CCV reroute
Edge CTS
SCT LoOnEy TuNeS
Vision Diesel stage 1 turbo
Blue spring upgrade
6.4 banjos
Lineman is offline
post #3 of 7 (permalink) Old 03-03-2012, 12:40 AM
Feedback Score: 2 reviews
15-16mpg where, city-highway-mix of both need a little more info, i get 18.4 Hwy doing 62 and 9 pulling my 14k 5er. If you tune you may need to have some deep pockets because the 6.0 is maxed out on hp. You need to get some gauges like Edge Insight CTS or ScanGaugeII first to see the health of the motor get a coolant filter to remove the casting sand a fuel pressure gauge pressure under 45lbs kills injectors. Then if you feel lucky get something like SCT Xcallibrator3 W/ Custom Tunes By Innovative Diesel or Matt at Gearhead and tune it for head bolts that way you will have a boost gauge because max boost is 28lbs mine will only do 25lbs solo but pulling 14,000lbs i can hit 28+ so i back out of it some.
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS with Expandable pyro
AutoMeter Fuel Pressure Gauge 0-100
Sinister Fuel Pressure Adapter
Updated Fuel Reg. Kit 3C3Z-9T517-AG
WOT 58lbs Idle 62-64lbs Just Right
HFCM Water Separator Drain Plug Upgrade
Ford Cetane boost every fillup
Amsoil By-Pass(Amsoil 5w40)
Fumoto Oil Drain Valve
Dieselsite Coolant Filtration System
Dieselsite Boots
Delo ELC Coolant
Tow Command
Upfitter Switches
Pulling a 14,000 lb Alpenlite 5er
Roll-N-Lock bed cover
97 F350 4x4 PSD CC LB (sold it)
1700 Super Chip
PacBrake&ATS converter lockup
3" dp-4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A pillar EGT,Boost,Trans
2 Stroker is offline
post #4 of 7 (permalink) Old 03-03-2012, 07:56 PM
lubbockguy1979's Avatar
Send a message via Yahoo to lubbockguy1979
dont get a tuner for mpg. you will be dissapointed. get it for power only.
2006 f250 4x4
crewcab short bed
lariat 6.0psd
auto, electric tcase
soon to have isspro
fire/air/trans/fuel
stock suspension and
pretty much everything
else
lubbockguy1979 is offline
post #5 of 7 (permalink) Old 03-03-2012, 09:54 PM
Derkperk's Avatar
Exactly what Lub says. Not even an option. Tune for power not economy. I get my best mileage with innovative's x-street tune vs the economy.
'05 F250 Lariat Crew Shorty Dark Stone FX4
AFE, MBRP single 304 4"w/ test pipe
ARP's w/ stock gaskets, Air Dog II 165
Driven Diesel Reg Ret fuel Kit
RCD Delete, 180/75's, 68mm VG Blow Jobby
Innovative Diesel Tuned SCT X3
Diesel Site coolant filter, Insight CTS
Overhead Auto Meters, Leveled
Homebrew traction bars
35x12.50x20 ATZ's on Ultra Mako's
Derkperk is offline
post #6 of 7 (permalink) Old 03-04-2012, 06:49 AM
CAMPINGTOM's Avatar
Agreed 100%.
2005 F-250 6.0
4" Straight Pipe, CCV Reroute, Coolant Filter, Sinister EGR, Insight Monitor, SCT X3 (Tuned by Innovative)
Blue Spring, Atlas 40 FICM Tune
CAMPINGTOM is offline
post #7 of 7 (permalink) Old 03-05-2012, 12:42 PM
X3 My truck gets the best fuel econo on the max power setting on my tuner. BTW, I have stock head bolts.
wyorever is offline
