Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - 6.0L Engine
Upgrades and Aftermarket - 6.0L Engine Upgrading and adding aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
Old 10-14-2009, 03:27 PM   #1 (permalink)
2005 6.0 Upgrades? mpg and horsepower?
I'm new to the diesel world and I have a stock 2005 f-250 6.0 extended cab lariet 4x4 with around 100k miles on it. I am looking to do some upgrades to it. I want to get good gas mileage and more power out of it. I want to do an exhuast (turbo-back but not sure what size?), intake (k&N???), and programmer(superchip or sct?) to start but I'm open to any other upgrades. Anyone have suggestions?
emhowi0104 is offline
Old 10-14-2009, 04:21 PM   #2 (permalink)
Congrats on the purchase....
Exhaust - Most people go for a 4inch turbo-back, MBRP makes some great units.
Intake - Stay away from them. The stock unit flows more than enough air than you will need unless going to serious HP. Plus the filtration of the stock unit is top notch.
Programmer - They put out tons of power but can easily cost you tons in repairs. If you go with a programmer be prepared to do head studs since the stock TTY bolts tend to stretch under the increased HP.
I am sure others will be more knowledgeable than me and give more advice....
One last thing, I recommend a good set of gauges. I personally use the Edge Insight and love it.
RC
2007 F250 6.0L Lariat
87,000 Miles
90% Highway Driving
Dieselsite Coolant Filter
PIAA Driving lights installed in Stock foglight spot
Edge Insight Monitor with Dash Pod
Sirius Satellite Radio
CB Radio w/ Firestik Antenna w/ Hood Mount
06 Harley V-Rod Street Rod Yellow
Rccarps2 is offline
Old 10-14-2009, 11:50 PM   #3 (permalink)
Send a message via Yahoo to lubbockguy1979
For mpgs good luck. I have heard that ficm tuning will give you about 30hp and better mpgs. If you want to gain mpgs the best way to do that is to work with the skinny pedal. Tuning might help but gains will be very minimal. I will stress this if you want a tuner for mpgs don't you will be dissapointed. If you want more power then you will be pleased.
For power... I'd choose the sct x3 with custom tunes only. Stay far away from the edge, banks, bullydog and any other generic tuner. They don't offer the ability to tune you specific truck based on the strategy (computer calibrations) or properly tune the tcm or tranny. Shift on the fly specifically means no tranny tuning which equates to tranny problems.
The stock airfilter is good for up to 550rwhp. To acheive that kind of hp though you will need a lot of mods so save the money spent on the a/m intake.
As for the exaust I would pick the mbrp or magnaflow 4" turbo back or straight pipe it. the 5" exhaust I would avoid unless you are looking to go for high hp later on because the 5" exhaust will effectively raise the power band of your truck.
Now for montoring I would strongly suggest you either run a set of analog or digita gauges to keep an eye on egts specifically. Also other items to watch are the tranny ( the dash display is a dummy light and not accurate) next is the eot engine oil temp and the ect engine coolant temp. The reason to watch these two temps is to help diagnose egr problems. They should be with in 15* after the truck is a operating temps.
Everyone is different and so are the trucks. I run fairly hot tunes and am still using the stock egr system and tty bolts. I drive my truck reasonably and have had very few issues.
2004 f250 4x4
crewcab short bed
lariat 6.0psd
auto, electric tcase
sct x2 with custom tunes
315/75/r16 bfg km
stock suspension and
pretty much everything
else
lubbockguy1979 is offline
Old 10-26-2009, 01:48 PM   #4 (permalink)
thanks
Thanks for the helps guys. I think i am going to stick with the stock intake. I am prob going to order the mbrp 4inch turbo back exhaust and do the sct programmer. Any suggestions for livewire or x3? i thought with the livewire i would not have to get gauges also....... appreciate the help!!!
Old 10-26-2009, 01:49 PM   #5 (permalink)
custom tunes
Oh and where can i find someone to do the best custom tunes?
Old 10-26-2009, 11:26 PM   #6 (permalink)
The popular choices are innovative diesel performance (eric's tunes), or brians truck shop aka bts (cale's). Other options are dfuser, rivercity diesel (rcd) elite, to name a few. Who is the best? That is up to you. Each has their style. If it were me I would talk to them and tell them what you are looking for.
2004 f250 4x4
crewcab short bed
lariat 6.0psd
315/75/r16 bfg km
else
Old 10-27-2009, 12:24 AM   #7 (permalink)
AFE makes some really nice intakes, anytime you open the exhaust you should open the intake IMO. Eric at innovative makes some good tunes from what I've experienced.
2009 RCLB 4X4 XL F-350, bone stock for now
06 Ram 2500 RCLB SLT ATS stage VI trans, ATS twin pumps, ATS A5K, ED External Gate, Haisley studs, Houge valve springs/rocker studs, caped rail, F1 Flux 3.5 sticks, aeromotive/GDP fuel system, NOS nitrous kit, Crazy larry/ez stack, lots of gauges, lots of power. 11.93@115.98 (old time)
alcook59 is offline
Old 10-27-2009, 09:59 PM   #8 (permalink)
when the intake does not flow enough this is true. by removing the stock air intake and filter you are actually reducing the filtration. the advertised gains on most if not all aftermarket intakes is in the 3700rpm range. so you will get a boost in power there which is beyond what a stock truck is going to see typically. so to sum it up if you are looking for the asthetics of the a/m filter and want to reduce the amount of dirt that will be filtered get one. there is alot that could/can be done to further improve the stock intake with out reducing the filtration of the unit if you are seeking power. there is very little gain to be had for the $300+ price tag
2004 f250 4x4
crewcab short bed
lariat 6.0psd
315/75/r16 bfg km
else
Old 10-28-2009, 10:39 AM   #9 (permalink)
HeavyAssault's Avatar
My Photos: (6)
For the $300+ you would spend on an intake system buying gauges is a better choice.
2006 F-350 CC PSD Lariat 4X4 LB 3.73 LS
Some stock stuff, some modded stuff, some deleted stuff.....
HeavyAssault is offline
Old 11-04-2009, 09:22 PM   #10 (permalink)
I also suggest getting a coolant filter. Thedieselsite.com has a nice set up this is where I got mine. A good set of gauges is also a good idea. As far as mpg your best bet is to keep a light foot staying under 2000rpm. Some say a 4" exhaust will help mpg and some say it won't. Also I suggest keeping the factory filter it flows good enough for 500hp and filters better than any of the aftermarket ones (but they do look better!)
2005 F-250 King Ranch Crew Cab 6.0 SRW, 35,000 miles, westin brush guard, 4'' straight pipe, high idle switch, zoodad mod, coolant filter
KBennett is offline
