2006 Head gasket replaced @ 28,000 - Page 4 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Old 11-10-2006, 10:02 AM   #46 (permalink)
Re: 2006 Head gasket replaced @ 28,000
The Build date on my truck was 12/05. So maybe that was part of the problem [img]/ubbthreads/images/graemlins/wink.gif[/img]
This space intentionally left blank.
365turbodiesel is offline
Old 11-11-2006, 11:12 AM   #47 (permalink)
Where can one find the build date? Is it on the sticker on the valve cover?
10 F-350 Lariat FX4
02 X 7.3l Ultimate Limited - SOLD
06 KR 250 4x4 - SOLD
a94cobra is offline
Old 11-11-2006, 11:37 AM   #48 (permalink)
Call a dealer service department and give them the seriel number and they can tell you the build date.
2003 F350 6.0L Lariet 4X4 CC DRW White/Arizona Beige FX4 Moonroof, 4.10 L/S 6 Disc CD, Dual Alternators Bedrug PPM Diesel Filter Kit 61,000 miles
2004 Ranger Edge 3.0L White Bedrug Century Bed Lid 41,000 miles
Edited 2-1-12
Tennesseepowerstroke is online now
Old 11-11-2006, 04:25 PM   #49 (permalink)
Ask your self one question. Am I doing something that is causing these problems, i.e., driving, payload or hauling habits? If the answer is, yes then figure out what and why, then do something about it.
If the answer is no. then find a new dealer.
Unless you are causing the problems you should not have a daisy-chain series of problems. If you do, you should be talking to the dealer about a new engine or replacement truck.
Key wording is daisy chain series of problems.
When you get your truck back or before you take it to the dealer again; take it to reputable outside mechanic. Ask that person to diagnose the problem or evaluate the engine. It just may be the best $20 to $40 bucks you ever spent. Don’t tell the dealer what you did or what you found. Dealer do not have to acknowledge any diagnoses’ from anyone other then another like dealer. All you will do is piss them off.
However, you will know if they are jerking you around, weather or not they are competent, and if you need to find a new dealer or not.
Before you start anything. Make sure you have written documentation from the dealer on what problems you brought your truck in for, what they found and what did on each visit. If you don’t nicely request it.
Good luck [img]/ubbthreads/images/graemlins/confused.gif[/img]
05 F350 S/D Crew Cab 6.6'bed. Blk on Blk fX4, Up-fitter Switch Tow Command, Tow haul, Backup Sensors, Tow package upgrade, Crews Control, Keyless entry, & Base alarm. Dual Alternators/ Batteries, Sunroof, Electric Rear Window, 6-CD player, Full Electric Seats. 4inch lift, 18-inch polished aluminum wheels. Spray on bed liner & rubber bed matt.
Remote Start & Alarm, Entertainment Center, GPS & XM. External 12-volt power, Customized TracRac system with Yakama Road Warrior Rack and 520watts roof mounted off road lights. Adjustable tie down mounts on both side of the bed.
Extra 12-volt power in the cab, 3-gauge mirror mount, Trans temp, fuel & oil pressure. Rear air bags with onboard air compressor-in cab gauge & controller, plus more.
diegojimc is offline
