Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - 6.0L Engine
Upgrades and Aftermarket - 6.0L Engine Upgrading and adding aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
Old 08-15-2008, 03:04 PM   #1 (permalink)
pegleg's Avatar
4.10 gear change to 4.30- Anyone done this?
I'm towing a fairly heavy 5th wheel with my 2007 F-350 CC DRW with a 4.10 rear end.
Has anyone changed their 4.10 gear to a 4.30 gear to help pulling heavy loads?
If so, were you happy with the results? If you had it to do over again, would you?
Thanks!
Rich
2008 F450SD PSD 4X4 CC DRW Lariat King Ranch White/ Pueblo Gold, Chrome Pkg, Torqshift, 4.30, Job#3, Camper pkg, Reflex spray bed liner, Extang Trifecta Tonneau.
pegleg is offline
Old 08-15-2008, 03:57 PM   #2 (permalink)
What is your truck lacking? 4.1 to 4.3 is not much of a difference, I wouldnt think it would be worth the $.
Chillinthemost is offline
Old 08-15-2008, 04:32 PM   #3 (permalink)
pegleg's Avatar
I'm pulling a 40' Toyhauler and it gets pretty heavy when pulling through the mountains of TN on I-75.
I'm pushing the limits of the specs of the truck with the 4.10 when I've got the harleys in the box. The 4.30 would put me (on paper) back to within the limits.
Just wondering if 4.30 gear is really going to make a big difference pulling the long hills.
Coming back from Daytona in March, I blew the lower turbo boost boot on the truck. Could have just been a faulty part, but...
Rich
pegleg is offline
Old 08-15-2008, 11:19 PM   #4 (permalink)
MikeL46's Avatar
It's only a 5% change in gearing.
You could get the same by going from a 33" to a 31.3" tire - and for a lot less money.
Mike
125W solar panel. Sportsmobile off-road trailer.
54,311 miles. 16.47 mpg average
From Cal to Alaska and Key West and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires. 46 Gal tank - harpooned pump vent tube.
Scangauge
162 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, Turbo hose fitting, Block Heater, Door lock - all under warranty. AC hose, not under warranty.
MikeL46 is offline
Old 08-17-2008, 05:33 PM   #5 (permalink)
pegleg's Avatar
The towing guide indicates that a tow boss (4.30 rear end) will tow a 5er up to 18,100 pounds vs. 15,600 pounds with the 4.10 or a difference of 2500 lbs.
Just wondered if anyone had actually made the change and if it made a significant difference when towing heavy... especially in Mountain areas like TN.
Rich
pegleg is offline
Old 08-17-2008, 07:08 PM   #6 (permalink)
PStroked444's Avatar
Your sig doesnt show any But, Try an exhaust and intake first. Then maybe a tuner. Gears will help but fuel milage will go down too. I suggest this cause intake and exhaust "in a way" pay for them selves. JMHO
99.5PSD, F250, 4x4, wht. CC, SB, Line-X, 200K+ , 6spd,LUK Ceramic Clutch, Warn Premium hubs, DP Tuner F5 stock/high idle/40T/60T/80E, DIY TYMAR, No EBPV, 08 Diff Cover, 4"MBRP S/S, Banks wheel*traded for stock wheel*, ATS Housing, HXLine, Zoodad Mod, CCV Mod, AIH removed, Shimmed fuel, Isspro Boost Guage & Pyro Guage, 2" Level Kit, Firestone Air Support Springs, BFG AT k/o, CB Galaxy DX949, DUAL Antennas, Lead Foot came stock
1998-F150 4x4, LB, K&N, No Kitty, 24LB inj, CB...Wifes ride.
94 Mustang GT, Red, Black Saleen rims, T-5, intake, exhaust, cam, 24LB squirts, tuned, last of the 302...
PStroked444 is offline
Old 08-19-2008, 09:24 AM   #7 (permalink)
pegleg's Avatar
I have a 21 point warranty on the truck. Trying not to void the warranty. The Stealership indicates that if I change the gearing, I would only void the gear change, not everthing else. From what I've heard, intake exhaust and tuners will pretty much void everthing...
pegleg is offline
Old 08-19-2008, 11:02 AM   #8 (permalink)
pegleg,
I have a 2007 F-350 CC DRW PSD and it came with the 4:10 limited-slip. I converted mine to 4.30 and am pleased with the results, I get better fuel economy both towing and bobtail. last year I towed a 10k 5th wheel from Virginia to NM and back and averaged about 10 mpg with the 4.10 gears. This year I did the same trip pulling a 14k 5th wheel and averaged over 10.5 mpg with the 4.30 gears.
Before converting to the 4.30's I tried getting more torque by mounting 245/70-17 vice stock 245/75-17 to see if that would help and it did but now my speedo and odo were not accurate so I bought a Hypertech programmer to fix the speedo and odo and it did but I blew my head gaskets trying to tow the 14k 5th wheel over Skyland Drive, Virginia. That little experiment cost me about $2,000 (7 tires, mounting, and programmer). I converted back to the stock tires and decided to change the gears and that cost me about $3000, wish I would have gone directly to the gear conversion.
Hope this helps.
m3nschmeyer is offline
Old 08-21-2008, 09:36 AM   #9 (permalink)
pegleg's Avatar
m3nschmeyer,
Sure does help! Did you find that the 4.30's gave you more pulling power in the hills too, or did it just help your fuel mileage overall?
Thanks much!
Rich
pegleg is offline
