6.0 EGT - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Old 07-11-2003, 07:52 PM   #1 (permalink)
6.0 EGT
Whats the highest safe EGT to run the 6.0 at? What's the up most limit before meltdown?
underpsi is offline
Old 07-12-2003, 12:32 AM   #2 (permalink)
Re: 6.0 EGT
I just got my pyrometer hooked up tonight and took the truck out for a test drive, on a warmed up engine WOT accel empty the gauge went as high as 1100 F, most of the time it was between 400-800. No engine or exhaust modifications yet. The Probe is installed in the drivers side exhaust manifold before the turbo inlet pipe.
2003 6.0l, 6 speed, Born 4/23/03, Delivered 6/3/03,Black, Lariat ,FX4, CC, Sunroof, TT Mirrors, Stull Grille, Westin Bull Barr, PIAA Driving Lights, APC Taillights, PIAA Super White Headlight & Foglight Bulbs, Rancho 4/2 Lift, Dual Front Shocks, RSX Shocks, Fender Flares, Aluminum Diff Covers, Sony Xplod MP3 Player, 10" Sub, 600W and 1000W Amps, Pioneer Door Speakers and Dash Mounted Tweeters, Dual Guage Pod, Autometer Ultralite Pyrometer and Boost, Reflexxion Steel Cowl Hood, Painted Handles, Tinted Windows, Airaide Intake System, Centerline Wheels, 35x12.50R16.5 BFGoodrich Mud Terrains
2000 Excursion Limited 7.3l - Centerlines, Painted Lower Body Panels, BFgoodrich All Terrains
fmellor is offline
Old 07-13-2003, 01:54 AM   #3 (permalink)
Re: 6.0 EGT
Other members have posted a 1200 degree limit. I have not seen my stock temp go above 1100 unloaded. I haven't towed a good load yet.
Delivered 4/7/03 (Bobby Williams-Sunrise Ford), Silver, CC XLT 156, 4x4, 6.0/TorqShift, RVAS, Adv. Sec., ESOF, Power Mirrors, Lim. Slip, Captains, Privacy, Al Wheels, and Adj. Pedals (for the lady). Luckily only minor problems thus far.
MODS: Donahoe 6", 35" BFG ATKO's, 17X9 ProComp 9089's (knight chrome), Russell brake lines, Line-X, triple pod (Lunar Pyro, TT, Boost), 750W sound w/Sirius and iPod, zoodad. Not much else,....yet.
brody is offline
Old 07-13-2003, 03:05 AM   #4 (permalink)
Banned
Re: 6.0 EGT
I am not going to give an exact number, but "the up most limit before melt down" is way higher than anyone has mentioned. We only have been to extreme temperatures for very short amounts of time, but no problems yet. WE have towed at 1250 for extended periods of time with no problems. It also depends on your gauge and probe. We use a high intensity probe so we see temps that most people never do because they can't respond as fast.
QuadBoenker is offline
Old 07-13-2003, 01:51 PM   #5 (permalink)
Re: 6.0 EGT
I'm a little new to stepping up a turbo deisel, have been running turbos on cars for years. I know I can take a car to 1450-1500 with out fear of meltdown, just curious to how a 6.0 would compare.
underpsi is offline
Old 07-13-2003, 03:51 PM   #6 (permalink)
GWA
Re: 6.0 EGT
I know I can take a car to 1450-1500 with out fear of meltdown,.....
But for how long?
[img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/confused.gif[/img]
'03.25 F-250 SC SWB 2WD 6.0w/TorqShift, Sport Pkge., Sonic Blue, plus-
16x8 Eagle alloy wheels
Snugtop XV and Bedrug
DPPI turbo-back 4" "sound system" w/cat
The Heartbreak of "The Heartbeat"!
GWA is offline
Old 07-13-2003, 04:49 PM   #7 (permalink)
Re: 6.0 EGT
Drag racing I've seen guys run up to 1650 and never have a problem, road racing I wouldn't go over 1400.
underpsi is offline
Old 07-14-2003, 09:34 AM   #8 (permalink)
George C's Avatar
Re: 6.0 EGT
The real problem with the 6.0L isn't EGTs, but cooldown.
A 7.3L will cool down below 300 degrees in a minute or two.
Due to the vaned turbo, it takes FOREVER to get this thing under 400 degrees.
Plan on giving the engine at least a solid two minutes to cool if you have the time.
My 2008 F-350
KEM 345 tuned
2011 Chevy Silverado
2010 Chevy Tahoe
http://community.webshots.com/user/GeorgeC1959
George C is offline
Old 07-14-2003, 01:54 PM   #9 (permalink)
Re: 6.0 EGT
I understand the cool down, but how hot can I run the egt's? We are playing with my freinds truck, would like to keep it from dieing.
underpsi is offline
Old 07-14-2003, 02:01 PM   #10 (permalink)
Re: 6.0 EGT
I remember a post that supposedly came from Navistar on the 7.3 saying do not exceed 1300 degrees F. As the other poster said he wouldn't run over 1400.
F4DU2PLT is offline
Old 07-14-2003, 03:52 PM   #11 (permalink)
George C's Avatar
Re: 6.0 EGT
I'm sure the trubo can stand some serious temps, but if you want to make sure that no damage will ever happen, respect the 1,300 red line.
My 2008 F-350
KEM 345 tuned
2010 Chevy Tahoe
George C is offline
Old 07-14-2003, 06:02 PM   #12 (permalink)
Re: 6.0 EGT
1300 is it, I would have thought they could go a little higher, around 1450-1500. Guess not. Is that a temp reading before the turbo?
underpsi is offline
Old 07-14-2003, 07:31 PM   #13 (permalink)
Re: 6.0 EGT
Be careful what you're guessing about. comparing temps of Diesels and gassers is like comparing apples to oranges. Gas motors will run quite a bit hotter (WRC cars run way hotter that what you mention above) than Diesels. Probably not a good idea to push temps past the red zone, as you might encounter some problems.
(Turbocharger) turbine housing and center housing materials are selected for specific temperature applications, and if you go much above the recommended limits, you might be asking for trouble. True, you might be able to get there for a while, but long term durability may suffer.
Mike
1993 E250 Clubwagon XLT 15 pass
5.8L E40D
racecar tow & service vehicle
Need van seats? I've got 'em! contact me for more info...
2literturbo is offline
Old 07-14-2003, 10:11 PM   #14 (permalink)
Re: 6.0 EGT
The housing and cartridge are made out of cast iron, while the turbine wheel and shaft are made of Inconel. They both can withstand a lot more than a piston can. Were is the red zone?
underpsi is offline
Old 07-15-2003, 06:42 AM   #15 (permalink)
George C's Avatar
Re: 6.0 EGT
It's not the turbo that will fail, it's the pistons.
My 2008 F-350
KEM 345 tuned
2010 Chevy Tahoe
George C is offline
