6.0 powerstroke upgrades - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 03-20-2005, 08:48 PM Thread Starter
I have been searching the site for ideas about power upgrades for the 6.0 powerstroke. I find alot of stuff talking about Edge and T.S. but I can only find stuff for the 7.3L on the T.S. site.I was thinking about the Banks kit for the 6.0L but from what I have read on this site it sucks. This is the Banks kit I was thinking about getting. Six-Gun Kit But for $1900 i am sure there are better and cheaper routes to go.
I plan on getting a excursion with the 6.0L in it for towing. I will be towing a 2 and 4 horse trailer with it. I will be towing between 2k and 6k with this rig. I with 2 kids and a dog I need the room of the third row seat in the excursion.
Can anyone give me link and advice of good mods to do to the 6.0L. I would like to get about 300hp and 550lbs+ if I can.
Thanks for the help.
Danny
AQHACowboy is offline
post #2 of 6 (permalink) Old 03-20-2005, 10:10 PM
Brian_C's Avatar
Re: 6.0 powerstroke upgrades
AQHACowboy,
If you're only towing 6K and you have any concern about your warranty, don't bother with any upgrades. Most 6.0s dyno at about 280HP stock. So I don't think it's wise to risk your warranty just for an extra 20HP.
If you don't care about your warranty and want more than an extra 20HP, then you'll want a new exhaust and intake. Then you'll need guages to keep an eye on things (tranny, exhaust, & turbo). Now your ready for some serious extra power.
Last but not least you'll want a programmer or module for the added power. Try innovativediesel.com for a programmer, and edgeproducts.com or quadzillapower.com for a module. Whether you choose a programmer or a tuner is kind of a personal preference. Just stay at or below a 100HP increase and you should be fine.
Brian
2004 F250 SC Shortbed 6.0 (03 Engine) Auto 4X2 Lariat, John Wood tuned SCT, AFE Proguard7, STC Performance 4" Turbo back exhaust with cat, Bedrug, Snugtop, Boze Fatal Eight 20x10 Wheels, Toyo Proxes ST 305/50-20 Tires
SOLD - Stroked Lightning - 2004 F250 6.0 Reg Cab Shortbed (longbed frame shortened 16"), Lowered 3"/5", 22" wheels, SCT tuned by John Woods, John Woods built 5R110, straight pipe with exit in bed, custom 4 link rear end, custom injectors by Full Force Diesel, Nitrous, Spearco IC, custom built 76mm turbo by Turbonetics, fuel system, batteries relocated to bed. All work done by Gene (weweld), driven by Gene.
Brian_C is offline
post #3 of 6 (permalink) Old 03-20-2005, 11:07 PM Thread Starter
I was thinking about getting the Edge Juice and there Attitude in-cab controller. Do I need a programmer with this combo?
Danny
post #4 of 6 (permalink) Old 03-20-2005, 11:19 PM
teamroper60's Avatar
Not if you use common sense............... Some are using the SCT to control the tranny with the Juice/Attitude combo and having good success. The Juice/Attitude has been attributed to several tranny failures, but unless you are running a lift/oversized tires or racing or towing over the manufacturers GCWR, doing WOT takeoffs and dusting ricers, that combo will work just fine too.......... Bottom line is, it is totally up to the nut behind the wheel (you).
#43
President and Webmaster
teamroper60 is offline
post #5 of 6 (permalink) Old 03-21-2005, 12:23 AM
Brian_C's Avatar
If you get the Edge with Attitude monitor you need to stay at level 3 at most. If you go above level 3 you will need the SCT programmer to make the tranny shift properly and not destroy itself. The SCT progammer will raise the line pressure so the clutches will hold. Without it your clutches will slip causing them to burn and warp.
Brian
Brian_C is offline
post #6 of 6 (permalink) Old 03-21-2005, 11:04 PM
william_04_X's Avatar
my 6.0 X pulls my 10,000 lb trailer fine while stock(65-70 mph up 6% grades)...i'm putting other stuff on cause i can...the third row seat is great...
04 EB X w/03 PSD
william_04_X is offline
