Upgrades and Aftermarket - 6.0L EngineUpgrading or adding OEM or aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
I did the blue spring upgrade and now I'm at about 72psi at idle. I know its been said that 70psi is the max, but will 72psi hurt anything? I figure the spring will eventually loosen up and the 72 will drop to around 70. Is this just wishful thinking? I don't want to have to pull the spring out and grind it down if it isn't necessary. Let me know what you guys think.
I would leave it alone. It will probably "break in" over time. I wouldn't be too worried over a mere 2 psi anyway.
Thats my guess anyway, for whatever its worth.
Thats what I was thinkin'. I guess a little to high is better than a little to low. If the GDS spring brings the pressure up to 90-100psi, 72psi can't be that horrible.
You also have to question the accuracy of the gauge. I don't know what kind of accuracy they guarantee but it wouldn't surprise me if they're off by 1 or 2 psi, thats a relatively small percentage and its not like we calibrate them against anything when we install them. I'd think a reading of 72 is safe, but I'm no expert.
06 F350XL rc,lb,manual 4x4, 6.0 PSD, 6 speed
Upfitter Switches
BCP Idle Control
55 watt halogen back up lights (4)
200 psi 5 gallon air system
Diesel Site Coolant Filter
HELLA FF50 Fog Lights
Custom Headache Rack
Custom Shovel Rack
Weatherguard Saddle Box
Weathergaurd Wheel Well Box
Herculiner wheel wells and rocker panels
Edge Insight with EGT and Fuel Pressure
"70psi is in spec. give the gauge 2-3 +/- psi. he is close enugh. being the spring is new it may settle a little bit as well." Posted by a ford master tech on another site. I have the same spring and the same pressure. I would not worry about it. Does your pressure drop while driving? at wot?
2004 f250 lariat fx4 sc/lb auto
egr block plate
fumoto
high idle mod
ISSPRO EV2 fuel pressure gauge
Blue spring upgrade
EDGE Insite
SCT sf3
dfuser coolant filter
ELC
Normal driving I'm at 70psi and at WOT the lowest I've seen is about 63psi. I think I'm gonna leave it. Now had it been 75-80psi I would've pulled the spring and trimmed it a little.
Over 70 is scary to me, I wouldnt run it.
If 45psi is the point where you would have injector starvation and failure, would you run 43psi??
C'mon Its only a meezly 2psi!!
No thanks!!
Over 70 is where trouble starts, expensive trouble.
IF the 45 psi is the low point where injector damage occurs, I wouldn't run my truck with less than 50psi, not even 49.
However, after reading about more than a few guys running the GDS spring for a long term (which boosts it to 100psi), a MERE 2 psi above the intended target of 70psi would tend to not bother me much, if at all. Especially since it is a Ford part manufactured for the intended use.
72 PSI is fine as others stated. I would bet that a reading from the back of the head (after fuel has been past the injectors) would be about 65 PSI. Wish it was easy to access the plug for a test.
If you read the post you'll see that the blue spring pushes the fuel pressure up to acceptable levels. Anything below 45psi is too low and will cause damage to injectors and anything above 70 psi will cause damage to injector o-rings. The GDS spring pushes pressure up to around 100psi. People run the GDS spring all the time without problems, so thats part of the reason why I'm leaving my blue spring in. If 100psi isn't blowing the o-rings out then 72psi shouldn't have any ill effects (hopefully). The blue spring is a part made and sold by Ford as a replacement part for your stock spring. Thats another reason that I'm not too worried.
Mines at about 69-70psi normal driving and wont go below 65-66psi at WOT, but mines is not tuned right now.
When my glow plugs are on Im at 60-61. Have you noticed that?
