Upgrades and Aftermarket - 6.0L EngineUpgrading and adding aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
will the AIC off a 7.3 stroke work on my 03 6.0 [img]/ubbthreads/images/graemlins/shrug.gif[/img]
91 F-350 rollback car hauler, 7.3, 5spd, 159,000 miles, stock,stock,stock/SOLD,SOLD,SOLD
96 F-250 ex-cab swb,powerstroke,tymar,stock"for now"sold sold
05 F-250 sold
03 F-350 single wheel, 4wd, stock, 258,000 miles!!sold
06 F-350 4 door,4wd,tow command,tow boss,lariat,everything you could get sold
00 excursion diesel 4wd limited sold
02 E-350 Traveler powerstroke sold
search on here, the wires are there, you can add a switch that will take the Rpm's to 1200 when you turn the switch on. Its was first started on here by a member named Skweeker
2004 F-250 Crew Cab XLT, Auto, Short Bed, Arizona Beige, Fx4/Camper Pkg., 265's, Built 4/23/04, Delivered 4/27/04
Retrax Bed Cover,Crimestopper Alarm/ Keyless Entry/ Remote Start/ Skweeker Idle Up Mod/ Marinco Built in Heater Plug/ My Truck [/b]
i read the post about using the upfitter switches on the 05's...i was thinkin i could use the factory aic box off an older tow truck.....are the wires there on my 03 to wire a switch to do the same thing as the upfitter switches on the 05's
05 F-250 sold
Yes, you can use an AIC from a 7.3 on your '03 6.0. The wiring harness for a factory AIC is already there. It is hidden behind the removable panel under your steering wheel. The plug in where the AIC harness attaches to the factory harness is alongside the steering column and facing toward the firewall. It's literally a minute install.
__________________ 2003 Toreador Red/Arizona Beige CC, DRW, Lariat, FX4, 6.0 PSD, Torqshift, born early Feb. 03, (still running the original flash!), AIC, MBRP turbo-back exhaust, Tuning by Total Diesel Performance, AFE PG7, Fumoto valve, B&W hitch, Di-Pricol gauges, Voyager brake controller, DIESELSITE Coolant filter, Timbrens, Rancho RSXs, Michelin XPS Traction's, a whole bunch of "bling", Connex 4300hp, JL Audio 275w amp w/ 12" sub, Alpine door and rear seat speakers. 376hp
