Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - 6.0L Engine
Upgrades and Aftermarket - 6.0L Engine Upgrading and adding aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
Old 08-27-2009, 11:56 AM   #16 (permalink)
My Photos: (6)
Send a message via AIM to blizzardwarrior7
Stock ! The only difference with the intake is slightly more turbo whistle, no power gain, and no mileage gain .
2006 F250 Lariat CC/SB
Hypertech hyperpac, Studs, rough country 4-link 8" Lift, 38"x15.5" Dick Cepeks, 20x12 Rockstars, 4" Dual Exhaust, Ranch hand bumpers Front & Rear
2002 F350 XL RC/LB
Pro Comp 6.5" Lift, 37"x13.5" SuperSwamper M16s, Stage II's, GTP38 turbo, DP Tuner, AFE intake, 5" exhaust, JW Slush Box, AIH Delete, CCV Mod, Zoodad mod, 5.6k mod, FPR Shim, ATS Flex Plate, ATS Torque Converter, AirDog FP-150, Fluidampr.
blizzardwarrior7 is offline
Old 08-27-2009, 05:59 PM   #17 (permalink)
william_04_X's Avatar
don't forget the money you waste when you buy an AM setup either.. Whooopee!!
04 EB X w/03 PSD
william_04_X is offline
Old 09-10-2009, 02:08 PM   #18 (permalink)
thanks for all of the input.
mike04 is offline
Old 09-11-2009, 09:20 PM   #19 (permalink)
Matt0987's Avatar
I, too, have been considering a cold air intake system for my '04 F-350 6.0L. I want to allow it to breath better.
Why do you recommend the stock one up to 500 hp?
It would seem to me that a more efficient filter and a straighter pipe w/out the bellows and the various connections to cause turbulance, and an open box to make the air flow easier and smoother would be a huge advantage.
'03 Excursion, 7.3L, 4X4, 4" MBRP exhaust, TS performance chip, K&N FIPK w/ an Amsoil EA filter, Hellwig anti-sway bar, drilled/slotted front & rear rotors. Bilstein shocks, Rancho steering damper. Airlift 5000. This baby surprises a lot of, so called, performance cars.
'04 F 350, extended cab, 6.0L, FX4, manual tranny, 4" MBRP exhaust, Bully Dog Triple Dog downloader w/ Outlook moniter, 2m-70cm Yaesu ft-8500.
Matt0987 is online now
Old 09-11-2009, 09:31 PM   #20 (permalink)
HeavyAssault's Avatar
My Photos: (6)
Using the data from the S&B website their filter will hold like 170 grams of dirt/dust during the ISO flow test before it reaches a point of low air flow. The OEM filter will hold 1304 grams of dirt/dust before it reaches the same point during the ISO flow test.
It isn't me trying to make a profit so read for yourself but don't let that fancy graph fool you. They fail to show the amount of dirt added to reach those points.
This is an updated test as well from April 2007.
http://www.sbfilters.com/pdf/iso_501...2075-5032D.pdf
2006 F-350 CC PSD Lariat 4X4 LB 3.73 LS
Some stock stuff, some modded stuff, some deleted stuff.....
HeavyAssault is offline
Old 09-12-2009, 07:33 PM   #21 (permalink)
Originally Posted by mike04 View Post
I'm planning on throwing an air intake and intake manifold into my '04 f350. I've been talking to a shop in Edmonton, AB, and he's pushing the S&B line, with that said the S&B intake elbow is cool as it already has ports for injection mods (meth/water, propane, etc). But my question is for the air intake itself, what is the best bang for my buck when it comes to an air intake?
thanks in advance.
Ive , found that the s&b is other than stock the best one for my 05, plus the sight glass is real pretty,pain in the ass to fit though, for me anyway
05 6.0 350 6wheel. cfm elbow,reg fuel return,egr delete,4 inch turbo back. 4 custom IDP tuned sct flash,c2 gauges,snow meth injection,lifted 6 inches,rolling 37's,black center caps, fox daul nitrogen stabs,recon black out.
bootstrap1002 is offline
Old 09-13-2009, 01:50 AM   #22 (permalink)
My Photos: (6)
Is it just me, or is the stock air filter a PITA to replace? I think the only benefit of an aftermarket one is how easy they are to change ! Probably the only reason I got one, oh, and aso because I kicked and jumped on my stock one after one of the alignment tabs broke off while removing.
2002 F350 XL RC/LB
Old 09-13-2009, 10:23 AM   #23 (permalink)
Strokin' 6.0's Avatar
The only reason you could halfway justify going with S&B would be that you buy it and you're done, whereas with the stock unit, you have to replace it and drop anywhere from $57 (cheapest I've found) to $85 (stealership cost) each time. Of course, how long does a stock filter last? Well, my truck is an '04 and I still have the original filter on it, going on 98,000 miles. I guess if you do a lot of off-roading, replacing the OEM setup would be a PITA to your wallet, but the facts are facts....OEM is made by Donaldson, one of the leading filter manufacturers out there, and their unit flows just as good as S&B.
My opinion, stick with OEM, even though the S&B looks cooler! I think that's what bugs a lot of folks, is that the OEM setup looks restrictive, even though it's not.
SFC Fred Lynes
2004 F-350 CC DRW LB FX4 4x4
Oxford White/Arizona Beige
King Ranch Package
Herrin Hauler Package
5R110 Torqshift
4.10:1 Dana 80 Trac-Lok
9,200lbs GVW
Reman'd 6.0L @43,956 miles
Reman'd Turbo @54,814 miles
Wishin' I still had my '05 2500HD CTD Ram
Strokin' 6.0 is offline
Old 09-13-2009, 11:37 AM   #24 (permalink)
the air is going into the compressor wheel turbulence don't matter much, your filter minder will let you know when you need to upgrade intakes. intakes do make the engine compartment look nice, my friend installed an xdi intake and it looks good
halerazor is offline
Old 09-13-2009, 04:13 PM   #25 (permalink)
FamilyRide's Avatar
I can't believe this question is still coming up after all the years the 6.0 has been out.
And the answer is still the same, as seen by the majority of the answers. It's a TD truck, not your old ricer. Trust those that were smart enough to figure it out and keep the $$$ in their pockets or those that weren't and tried for them selves and spent those 100's of $$ for a lesson.
2004 EB Excursion, 4x4, 6.0, everything but step tubes and 2nd row chairs, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto sitting on V Codes and Revo 285's.
FamilyRide is offline
Old 09-29-2009, 12:46 AM   #26 (permalink)
Against the advice of pretty much evryone, I used the K&N. I have to drive down 15 miles of dirt road and back everyday that I go to work. I got dang tired of buying replacement filters. The K&N is cheaper than most, been around for a while, and is available pretty much anywhere. People have stated that K&N lets dirt through but I haven't had that happen with mine. If you drive in normal conditions, stay with stock. If you like good looks and never having to replace a filter again, then change it.
04' 250 FX4 CC, DrPerformance 1oo hp chip, Flo-Pro 4" turbo back exhaust, K&N intake kit, Husky liners.
ducklodge is offline
Old 09-29-2009, 09:17 AM   #27 (permalink)
If you want the best filter and want long life from your engine leave the stock filter alone. Stock filter will hold more dirt than any aftermarket filter..ya never will see a K&N or any aftermarket filter on a big rig , construction or mining rig...for a reason
caryt is offline
Old 10-04-2009, 11:34 PM   #28 (permalink)
Location: Sheldon/Crosby, Texas just outside of Houston to the East.
Any ideas where can I get a stock unit to replace the K&N unit that I bought my truck with?
03 F-350 LWB 6.0 PSD 4X4 Lariat
TXDRAKE is offline
Old 10-05-2009, 01:28 AM   #29 (permalink)
Matt0987's Avatar
Junk yard(s)???
Old 11-04-2009, 09:46 PM   #30 (permalink)
keep the stock one. It filters better than the aftermarket ones and breathes good enough to support up to 500 hp
2005 F-250 King Ranch Crew Cab 6.0 SRW, 35,000 miles, westin brush guard, 4'' straight pipe, high idle switch, zoodad mod, coolant filter
KBennett is offline
