Upgrades and Aftermarket - 6.0L EngineUpgrading and adding aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
Guys, I just bought a 2005 F-350 6.0 torqshift dually and the ride is great but it can use some help, according to my kids. I talked to a dealership about installing an air suspension system in the rear. He said that I could install just airbags on top of the springs or a system that would replace the leaf springs. He said that both would help but that the best was the full replacement. I do not know much about trucks, I only bought the truck because it looked great. So, does any of you recommend doing this and if so, does it help the ride a lot?
You may be stuck with your ride. You bought a 1 ton and it was made for hauling and towing. I put air bags on my 250 because I tow a 5er. With the air bags it softens my ride and keeps it from bottoming on my stop spring when I tow. Keep the ice cream cones out of the truck and the kids will get use to it [img]/ubbthreads/images/graemlins/cool.gif[/img]
04,F250,PSD,Built 01/04,4X4,CC,LWB,Dipricol Gauges, Muffler Delete,A.I.C. Mod,Etrex Legend GPS,Sirius Satellite Radio ,Firestone Airbags,,Prodigy controller,16k Power All 5th Wheel
What are you hauling that the suspension needs help?
__________________ Y2K,F350,DRW,CC,6-spd,3.73,4x4,LariatDI4 pos,homemadeTymar,
Autometer boost & EGT,CCV bipass,DIY Xbrake,HXmod,PS2000,WalkerBTM,LUK clutch,
IH Jasper reman.w/forged rods,ATScomp.shroud W/W
Psycho Pump on order, or maybe not
----------------------------------- New 05 is here, and im luvin it!
05 F350,DRW,CC,FX4,Lariat,4:10 gears,Torqueshift,4x4,
AutoMeter Cobalts,pyro/trans above the r/v mirror
popup g/n hitch,CCV reroute,MotorGuard M30 bypass filter,Muffler delete,Sirius,
Not a single engine perf. mod,i dont think it needs any!
I used the Firestone Airbags. I installed them myself and cost was around $250.00 from www.truckspring.com <font color="blue"> </font> <font color="blue"> </font>
If you install the air bags on top of your springs you will only be riding on the air bags if you have them pumped up enough to take the load off the spings. Doing that would raise the ride height of the rear. If you go full bags and get rid of the springs then you will be riding on the bags only. You will have height adjustability and it should be a better ride than the stiff leaf springs.
Jason
'04 CC SWB, 34' Toy box, '90 Toyota 4runner rock crawler
ECV 711, TLCA, CSFA, Nor Cal Marauders
if you air the bags up to lift a little weight off the leaf springs...it will ride STIFFER than the leaf spring alone. yup yup.
Air ride is smoother.
Kelderman has a pretty nice set up, but it's $$$$.
_T
The Kelderman kit is kick a$s for ride qaulity but adds no capacity to you rig. They offer a full air ride conversion that will do both but the $ is allot more.
Check your tire pressure in the rear. When I got my truck, the ride was very stiff and sent jolts through my spine when going over the various road bumps. I checked the tire pressure in the rear tires and they were at 80psi. (from the factory) I lowered them to 60psi and it made a big difference in ride. If after checking your tire pressure the ride is still too stiff, then you may want to look into some after market products to help you out.
I agree totaly! The Kelderman products are frigin awesome! [img]/ubbthreads/images/graemlins/smokin.gif[/img]
Early 99 F250 SD CrewCab, PSD, 285 BFG Muds, AFE Stage II,Rancho 5000 SS, Smitybuilt S/S Bars, PIAA 959 fogs, Jordan 2020, a DI and a Tadd 6 stage chip, Triple a-piller w/ Pricol gauges (Trans, Boost, EGT), XM Radio, 1000 Watt HR 2510 CB/Ham, Bearcat BCT7 (Modified) <font color="purple"> Stage IV ATS Tranny and TripleLok </font> ATS Dual 4" Exhaust, Swamped, Custom turbo (time for HPOP upgrade)
Anyone have Kelderman bags installed? Front, rear, or both?
