Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - 6.0L Engine
Upgrades and Aftermarket - 6.0L Engine Upgrading and adding aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
Old 03-21-2008, 11:05 AM   #16 (permalink)
What size is the hydraulic hoses since I will copy your style of installation? Pipe and hose sizes have always been confusing to me
Ken
2006 Lariat Chrome Edtion Red F350 CC 4X4 Dually w/4:10 Gears Born 04/26/06 w/ color matching speedliner, PCM Reprogramed to Level "L",@ 24,535 miles AMSOIL Front to Back, AMSOIL By Pass Filter BMK-11, Amsoil Coolant Nitrogen in all 6 tires @ 75 PSI W/ 34.2 x 102" wide Coachman Royal TT.
Gone but not forgotten 2001 “X” 7 years / 218K w7.3
Ken1 is offline
Old 03-21-2008, 12:27 PM   #17 (permalink)
jdc753's Avatar
My Photos: (31)
Send a message via AIM to jdc753
looks pretty sweet and sure is a clean install as well. What material is the blue oil filter cap made out of? Also how many miles are you putting on between changes?
86 Ford F250 4x4 with 4in Rough Country lift and poly bushings all around converted from 351W to 6.9L Diesel (rolling chassis at the moment)
05 F350
jdc753 is offline
Old 03-21-2008, 01:01 PM   #18 (permalink)
bnvcrows's Avatar
Originally Posted by jhamlin164 View Post
Gentlemen,
Thought I'd take some pictures of the Amsoil Bypass Filter system that I had installed a while back.......................sent off my first oil sample today after 18,000 miles. I really want to get a feel for whether or not this system works. Most of my driving has been highway miles (42 miles roundtrip every day) The hoses that come with the system are ridiculously inadequate, so I had to go to an hydraulic hoses store here in Southern Cal and have some braided stainless steel hoses made especially for this application. They really look good and are rated at 500 psi.:thumb: Prior to sending my oil sample off, I was running Amsoil 15W40 motor oil with the Amsoil EaO88 oil filter, and the Amsoil BMK-11 bypass oilf filter. They maintain that their bypass filter will work at 98% efficiency down to 2 microns particle size..........................we all know that over 60% of engine wear is caused by particles that are between 6-15 microns in size. Guess I'm about to find out (when the report comes back) if this system is all it's advertised to be. At any rate, here are some photos of the system in place. The bypass filter is mounted down under the truck on the framerail on the passenger side.
Your system install is super. Your concerns that the hoses are inadequate may be an over statement yet your lines look much better these hoses are a very good quality.
I have a 7.3 and the hoes are on my truck are what came with the kit.
[IMG]file:///C:/Users/Bill%20Crow/F-250%20Truck/Bmk-16a/Complete%20By-pass%20re%20sized.jpg[/IMG]I am very happy with Amsoil system. I did have to add some plumbing insulation to stop a vibration from the oil pump i could here in cab.
Bill
Bill
2003 F250 FX4 SUPERCAB SPORT XLT 7.3 PSD
SLAPS Member
Edge with Attitude & Bush Fender Flairs
Amsoil 3000 5w 30, Amsoil EaAU Air Filter, Amsoil Dual Remote By-pass BMK-16A,At 38,000 miles on oil Had to change I went long enough still was ok to run.
Amsoil ATF Transmission & Transfer case, Amsoil 75w-140 fluid front & rear end , Amsoils Antifreeze, Transmission Magnefine filter, 4" Turbo Back Exhaust
Sportman Tonneau Cover
bnvcrows is offline
Old 03-25-2008, 01:39 AM   #19 (permalink)
jhamlin164's Avatar
AMSOIL: The Jury Has Returned With A Verdict.......
Gentlemen,
As per my promise, the results are back from the oil analysis...........after 18,000 miles, I'm told that the OIL WAS STILL GOOD.
As I said earlier in the post, I've already changed the oil, but man does it feel good to know that I could've run it even longer!
I've included a scanned image of both sides of the Oil Analysis report. You guys can now scrutinize the hell out of these results and make decisions accordingly on your own rigs.
I found it rather interesting that the anti-wear additives and dispersant-detergent additives (magnesium, calcium, phosphorus, & zinc) were still pretty good after 18,000 miles......
Also of note was the fact that the iron numbers were within normal limits (29); don't know what the normal range is, but my oil analysis did not say that it was high.
I have to say, in all honesty, that I'll feel a lot better when I take the next oil samples and send one to this lab (Amsoil affiliate) and the other one to Blackstone Labs. I'd like to compare the two and see if they come to similar conclusions regarding the condition of the oil.
2006 F-350, King Ranch, 6.0L PSD CC, DRW, 4X4
Kenwood Head Unit / Navigation system
Audiovox LCD DVD player
Rancho RSX 9000 shocks
Line-X Bedliner
JL Audio ZR-570CSi speaker system
JL Audio StealthBox Sub
2 JL Audio Amps
2 Odyssey PC 1500DT batteries
Amsoil By-Pass system
Future Mods:
ARP Head Studs
Banks Powerpack System
Mag Hytec Tranny pan
Autometer Phantom II gauges
Gear Vendors Aux Tranny
http://i7.tinypic.com/4hu7q78.jpg
jhamlin164 is offline
Old 03-25-2008, 01:04 PM   #20 (permalink)
bnvcrows's Avatar
I know you have a 6.0 but just so you can see other samples heres my sample with 29,982.
Bill
SLAPS Member
bnvcrows is offline
Old 03-25-2008, 04:13 PM   #21 (permalink)
Back 6+/- years ago Bob Rielly compared AMSOIL and BLACKSTONE test methods. I cannot find this information but at the end both test samples were good for service.
But Bob explained the different types of test done by the two companies. So my point is the two samples will not be apple to apple but in both cases you should continue to have good test results.
In my case when I had a 1999 Z71 I had a AMSOIL test come back with bad results and I should change oil if not already done with filter change. What a surprise but a little more research with Lab help I had a AIR Filter leak (gap) caused by your truly. Problem solved.
Maybe someone else will recall Bob R's comments and find.
Ken
PS: I would still like to know the size of your hoses?
Ken1 is offline
Old 03-25-2008, 05:15 PM   #22 (permalink)
bnvcrows's Avatar
Post Lab Report
With my very little experience in lab reports from Blackstone is they did not seem to completely recognize the extended oil drain concept. Meaning as your oil drain is extended your metals will increase as and your Additives will go down somewhat and you need a balance to continue extending your oil each time. This has to be in balance with knowing your by-pass system is filtering to at least 3 microns level knowing this any particles in your oil is not necessarily harmful with a few exceptions like silicon (this is like sand or carbon in your oil this is very harmful) which I to had a filter issue and the oil sample brought it to my attention. I change the filter and the silicon went down not enough for me I drained and started over.
Bill
Bill
SLAPS Member
bnvcrows is offline
Old 03-27-2008, 01:10 AM   #23 (permalink)
jhamlin164's Avatar
Man, That's A Beautiful Thing!
So for all intents and purposes, you have right at 30,000 miles on that oil sample, and it's STILL GOOD-TO-GO! I sure hope I can get those kinda numbers on my next sample.
Line-X Bedliner
2 JL Audio Amps
Future Mods:
ARP Head Studs
Old 03-27-2008, 01:24 AM   #24 (permalink)
jhamlin164's Avatar
I Had To Go & Dig It Up Again........
Ken
Hey Ken,
I FINALLY found the information on the hoses: I used two 8-ft pieces of Nos-4 braided steel hoses.............I had them specially made at a place called "The Hose Man" here in southern California
Line-X Bedliner
2 JL Audio Amps
Future Mods:
ARP Head Studs
Old 03-27-2008, 06:41 AM   #25 (permalink)
Thanks for the Hose information, I will have some made today. I was doing some pre-assembly of By Pass Kit yesterday and found the oil sampling Pea**** was not part of kit ( It was included with kit for 7.3) Order and should have everything nest week.
Thanks for sharing the Pix and information
Ken1 is offline
Old 03-27-2008, 10:32 AM   #26 (permalink)
advantages
So I'm guessing that the major advantages to this system is less wear and less money spent on changing oil? I'm not a motor head, so I need it spelled out! haha
captbrandon is offline
Old 03-27-2008, 11:30 AM   #27 (permalink)
bnvcrows's Avatar
You are real close the fact no mater what by-pass system you use is a improvement over the oem filter by reducing the size of the partials in your oil is how you reduce wear and extending oil drain.
I have had the fs-2500 and now have the Amsoil dual-by-pass and after having both I believe Amsoil out preforms all of the others. Remember removing the soot out of our oil is the most important additional filtering can never hurt IMO.
Bill
Bill
SLAPS Member
bnvcrows is offline
Old 03-27-2008, 11:14 PM   #28 (permalink)
Gentlemen,
The report does look good. Just watch the viscosity. In that report your oil had sheared down to the low end of a 30 weight oil. In that aspect I do not agree that the oil was good and you could go further...
'04 F-250 Harley-Davidson 6.0L CC SB
PowerStrokeHD is offline
Old 04-11-2008, 06:10 PM   #29 (permalink)
I copied yourr method of installation thanks for the idea
Ken1 is offline
Old 04-11-2008, 06:12 PM   #30 (permalink)
Just a few more Pix
Ken1 is offline
