Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - 6.0L Engine
Upgrades and Aftermarket - 6.0L Engine Upgrading and adding aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
Old 08-21-2008, 11:07 PM   #1 (permalink)
Amsoil Filter?
Does any use the Amsoil filter for their 6.0 other than the motorcraft oem? Just wondering if it fits correctly, since some after market filters don't fit right for the 6.0 truck.
Legend41 is offline
Old 08-22-2008, 08:58 AM   #2 (permalink)
I use AMSOIL full flow filter withour any problems see sig
2006 Lariat Chrome Edtion Red F350 CC 4X4 Dually w/4:10 Gears Born 04/26/06 w/ color matching speedliner, PCM Reprogramed to Level "L",@ 24,535 miles AMSOIL Front to Back, AMSOIL By Pass Filter BMK-11, Amsoil Coolant Nitrogen in all 6 tires @ 75 PSI W/ 34.2 x 102" wide Coachman Royal TT.
Gone but not forgotten 2001 “X” 7 years / 218K w7.3
Ken1 is offline
Old 08-22-2008, 11:35 AM   #3 (permalink)
InnovativeDiesel's Avatar
We use all AMSOIL oil and filters in our trucks. It's great stuff, that's why we only deal in their product.
Innovative Diesel Performance
410-620-3020
http://www.innovativediesel.com
The Original SCT Custom Tuning Dealer!
We are the first and most experienced custom tuner for the 6.0L truck!
*No gimmick's and no marketing ploys.*
Only the best custom tuning, from stock to highly modified trucks. We have a proven track record and tune the fastest and most powerful Ford vehicles in the industry.
IDP thrives on carrying only the best parts and great customer service. Over 5000 parts ready to ship for your diesel truck!
InnovativeDiesel is offline
Old 08-22-2008, 01:56 PM   #4 (permalink)
I have'nt been able to compare the two side by side yet, so just wondering if they are the same length and fit. If it's too short then I'm told the oil will just bypass the filter at the base and not get filtered.
I'm going to put amsoil 15w40 diesel/marine oil full synthetic,is this the proper one for the 6.0? It doesnt say cj-4 on the bottle, just ci-4 and other stuff!
Legend41 is offline
Old 08-22-2008, 07:58 PM   #5 (permalink)
RAVOwner's Avatar
I tried the Amsoil synthetic filter once. I noticed a delay in the oil pressure coming up at start up. I was told this was due to the filter being different in size compared to the OEM one. It is my understanding this would cause the oil to dump out of the filter housing after engine shutoff. Maybe they have fixed the issue as this was a little over 2 years ago when the filter first came out.
As far as their oil, it is okay in shear resistance, but not as good as Schaeffer's synthetic.
05 F350 SRW CC LB FX4 Lariat
6 Inch Procomp Lift / Superlift Stainless Steel Brake Lines (Front and Back)
20 Inch Weld Racing X-Lander Chrome Wheels with 35x13.50x20 Procomp Tires
Oilguard Bypass Oil Filteration System
Dieselsite Coolant Filter and External Transmisson Filter
4 Inch MBRP SS Turbo Back Exhaust with Muffler Delete Pipe (The Kitty is Safe)
Roll Lock Bed Cover
Quadzilla Recon XZT gauge (Boost, Trans, EGT)
RAVOwner is offline
Old 08-22-2008, 08:35 PM   #6 (permalink)
I just put the amsoil filter and oem side by side, and the amsoil filter is shorter, therefore I don't think it will seat right?
Legend41 is offline
Old 08-23-2008, 08:25 AM   #7 (permalink)
RAVOwner's Avatar
I guess they haven't changed the design as this was the same thing I noticed the last time I used one. There was a definate lag in the oil pressure coming up that wasn't there before when I was using the OEM filter. As soon as I switched back to the OEM filter the lag went away. I am not a certified mechanic, but any delay in getting oil pressure at startup can not be good in terms of engine wear.
Roll Lock Bed Cover
RAVOwner is offline
Old 08-24-2008, 03:33 PM   #8 (permalink)
bombout800's Avatar
then just make sure you get a wix filter. Same part # of course.
2003 f-250 White/tan. D's with 33's!, Skyjacker leveling kit, Mbrp 5" turbo back with 6" tip, SCT with tunes from Innovative. HID headlights and foglights. Diprocol Pyro,boost, and tranny gauges. Built trans. Edge juice w/ att. 5% tint. Smoke switch, and high idle mod. For SALE! Pm me for details.
bombout800 is offline
Old 08-24-2008, 04:47 PM   #9 (permalink)
HeavyAssault's Avatar
My Photos: (6)
I tried the Amzoil filter and oil. Wasn't happy with the cold weather starts and their 25k OIC doesn't apply to diesel motors. If you don't use their filter with their oil then the warranty doesn't apply to either product. You are required to change the filter at the OEM interval and top off the oil.
There are other oils that are full syntheic and found easier around town for me. Pep Boys 2 for $7 Fram OEM filters are a cost saver and fit just fine.
2006 F-350 CC PSD Lariat 4X4 LB 3.73 LS
Some stock stuff, some modded stuff, some "deleted" stuff.....
HeavyAssault is offline
Old 08-24-2008, 06:07 PM   #10 (permalink)
Why not just use the motorcraft,then you know you have the right one that fits?
When you change the oem at factory recommendations, do you just unscrew the cap and lift the filter out? Do you need to add any oil?
Legend41 is offline
Old 08-24-2008, 08:32 PM   #11 (permalink)
I have oil samples to show how well Amsoil oil and filters work in the 6.0
22,000 mile oil sample that was still good for continued use after 1 year and 6 months.
the filter is no different in size, the problem may be in the screw on cap, some older 6.0 have a spring loaded adaptor in the cap that has to be removed or you will bend down the four tabs on the top of the filter, and that will cause oil pressure issues.
to buy Amsoil please contact TDS Amsoil site Sponsor DieselManor,Dieselsite,
sootieoil is offline
Old 08-24-2008, 08:35 PM   #12 (permalink)
I would love to see the oil samples you took to come up with your conclusion.
Old 08-24-2008, 10:09 PM   #13 (permalink)
Sootie, the amsoil is definitly shorter than the motorcraft filter side by side!
Legend41 is offline
Old 08-25-2008, 07:06 AM   #14 (permalink)
My Photos: (6)
Use the search function here for OIC or OA. You'll have plenty of reading.
Old 08-25-2008, 01:44 PM   #15 (permalink)
I don't think they can fix that issue, since Racor holds a patent on the size of the filter...
watch this
YouTube - Motorcraft Powerstroke Diesel Filter Comparison
alexb is offline
