Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - 6.0L Engine
Upgrades and Aftermarket - 6.0L Engine Upgrading and adding aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
Old 11-21-2005, 11:16 PM   #1 (permalink)
another coolant puking thread
I know there are lots of puking threads but wanted to see if anyone knows of my problem off hand. I have an 04 F250 with an early build date and I believe the 6.0 engine build date is even earlier, like in 03. Not sure if those build dates have anything to do with my problem or not. Anyways, I have dual 5" straight stacks coming out in front of each rear tire, SCT from ID and I am running on the tow tune, and also I have gauges(pyro and boost) to round out my mods. My question is that I have been getting a nice puddle of coolant on the driveway right behind the passenger's front wheel, it looks like the coolant is running down the seam between the engine and the tranny and dripping from there. It seems to me that when I run the truck for a short distance that it will puke the coolant however when I travel for an extended period of time (~3.5hrs) it doesnt puke. The temps here in PA are getting colder as we speak and it seems it pukes more often when the engine isnt totally warmed up. Was wondering if anyone else has problems like this. I have about 56k on it so the engine is still under warranty, as long as the dealership doesnt mind mods(but we dont need to get into that discussion here).
Thanks for any help!
darthmullet67 is offline
Old 11-22-2005, 09:55 AM   #2 (permalink)
Re: another coolant puking thread
Check the seam between your heads and the block. It sounds like you have a failure of the head gasket. When cold, the seal will be at its weakest. When hot, things expand and your leaking may not be noticeable. I would also check the coolant reservoir cap. Although it does not sound like that is the issue.
Write back after you check the block/head interface. I suspect you will find ytour source along that seam somewhere. Look for a white film; that is the color left behind by driad antifreeze. It may also be brownish due to decomposition while being in contact with the hot block. One easy experiment is a short drive, 5-10 minutes, not getting on it hard. If I am right, you'll leak and won't get it hot enough to decompose. Follow the white dust trail.
Let us know, RL
Black 2003 F350 DRW (almost nothing stock)
Other rides:
Black 2006 SRT8 300C (Mopar exhaust and CAI)
Black 2008 SRT8 Jeep (Mopar exhaust and CAI)
Black 2008 Mercedes E550 4MATIC
Pictures: http://community.webshots.com/user/ralphinnj
6L Shootout Report:
http://www.thedieselstop.com/downloa...toutReport.pdf
ralphinnj is offline
Old 11-22-2005, 10:57 AM   #3 (permalink)
darthmullet67
I had a similiar problem last winter. It would only leak when it got cold. It leaked on the passenger side above the starter and down the frame. It was a EGR cooler line somewhere back behind the turbo and should be covered under the engine warranty.
Good Luck
TasMan
2004/04 Engine,King Ranch,F-250,4x4,SWB,3.73 LS, Adjustable pedals,Reverse sensor,Moon roof,clearance lights, Power rear window,Heated seats,Bedliner, DPPI T-409 Turbo Back, AFE Pro-Guard7, C-Bet'r mirror, Fumoto drain valve, AIC, Extange Tonneu, Lund SS Interceptor, Siver Star Bulbs, Harpooned tank, SUV double wiring harness, Bright Box, Clifford RS 3.5 alarm, 3" Edge Plush Ride, Bilstein Shocks, Westin Sportsman CPS Grille Guard, XM Commander wired in with a PIE Adapter, Eagle 137 series rims and Bridgestone Revos 285/75-16, Husky Liner Mud Flaps.
http://community.webshots.com/user/tasman3721 UpDated 27 October 2005
Retired Chief Warrant Officer 4
tasman is offline
Old 11-22-2005, 11:27 AM   #4 (permalink)
I can 100% guarantee you it is caused by the timing being advanced too far. I feel like I have posted this 1,000 times. I have been working on these trucks since late 2002 and had product out since 2003 early.
The computer automatically will advance timing when the engine is cold. Add that plus your tuning and you have too much timing and a nice puddle.
Take the timing out and you are fine.
Quad
QuadBoenker is offline
Old 11-22-2005, 01:58 PM   #5 (permalink)
InnovativeDiesel's Avatar
We use stock timing on our tow tune's. However, most of the 03's have pretty aggressive timing stock.
Innovative Diesel Performance
410-620-3020
http://www.innovativediesel.com
The Original SCT Custom Tuning Dealer!
We are the first and most experienced custom tuner for the 6.0L truck!
*No gimmick's and no marketing ploys.*
Only the best custom tuning, from stock to highly modified trucks. We have a proven track record and tune the fastest and most powerful Ford vehicles in the industry.
IDP thrives on carrying only the best parts and great customer service. Over 5000 parts ready to ship for your diesel truck!
InnovativeDiesel is offline
Old 11-22-2005, 02:05 PM   #6 (permalink)
Quad
Quad
If it was puking, than you should get the puddle on the drivers side below the Degas bottle. If it only does it when it is cold, than the EGR line has been a big problem.
TasMan
tasman is offline
Old 11-22-2005, 02:14 PM   #7 (permalink)
Quad
Quad
TasMan
Could be a blown head gasket, which would be worse when cold.
RL
Other rides:
6L Shootout Report:
Old 11-22-2005, 02:24 PM   #8 (permalink)
RL
ralphinnj
Very true and could be what is wrong but I would bet against it. Especially if it gets worse with cold, I would look at a freeze plug to do that before a head gasket but have seen stranger things happen. The EGR cooler line has been a known problem, especially with his approx. built date and they only seem to leak when it gets cold; from what I understand, it is hard to get to or check with turbo installed.
TasMan
tasman is offline
Old 11-23-2005, 01:20 AM   #9 (permalink)
...Maybe its your heater core leaking?? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
06 F350 KING RANCH,4X4 Dually, Copper/Arizona Biege,loaded with all options including dual alternators & King Ranch chrome pkg, except moonroof..modes DONE: 3:73's replace 4:30's(yes, thats correct),Gear Vendors auxiliary overdrive, MBRP Dual Exhaust, SCT Xcal 2/Innovative Diesel Custom Tune Xtreme Race with full converter lockup,MSD Digital Propane Injection, 03 Turbo & pedestal,custom Intake, AFE Proguard 7. Running Cold Blend Veggie(DSE) now for 2 years!! Recent fuel sys upgrade: FASS Hi-Perf. 0-130psi fully adj. VEG oil specific lift pump & Racor 'NAUTILUS' Dual Heat primary Fuel/Water filter assy, & 5/8" "Draw Straw"(Fuel tank pickup tube)
Traded:2004 F350, 4X4, Super Cab,Sport pkg,True blue (I'll miss her,she was fast!)
BIGBLUE777 is offline
