Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - 6.0L Engine
Upgrades and Aftermarket - 6.0L Engine Upgrading and adding aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
Old 06-22-2004, 01:15 PM   #1 (permalink)
Any reason for a blowoff valve?
Or should I say, is there any reason not to put a blow off valve on my truck? I have experienced the barking of the motor when I have had to cut off the accelerator much faster than anticipated. I know why II need one, just don't know if there is a reason I shouldn't.
2008 F350 CrewCab Longbed, Black on Black, 12 inch Modified Rize Lift, King Coilovers in Front, King Reservoirs Front and Back, 40 inch Nittos, Amp Steps, 4.88 Gears
Doctorsmack03 is offline
Old 06-22-2004, 05:00 PM   #2 (permalink)
FamilyRide's Avatar
Re: Any reason for a blowoff valve?
That "burp" is the design of the VGT. That's how it blows off pressure.
2004 EB Excursion, 4x4, 6.0, everything but step tubes and 2nd row chairs, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto sitting on V Codes and Revo 285's.
FamilyRide is offline
Old 06-22-2004, 05:17 PM   #3 (permalink)
I have a steep driveway that I pull up daily. The first few times I pulled up it, I would floor it pretty hard and kill the accelerator at the top just before stopping. Twice now, I have blown off the little air filter flow gauge sender on the back of the filter. The dealer said it was due to diesel bark without a place for relief. He says if you run the accelerator too hard and cut it short, all of the pressure that should be run through the motor is forced backwards resulting in broken/bent Turbo shafts.
Old 06-22-2004, 06:38 PM   #4 (permalink)
ford, or well navistar designed this engine to be wastegateless- the vgt doesnt need one. ford wouldnt sell thousands of these 6.0s if they knew all were gonna come back with bent compressor wheels. and most chips seem to raise boost pressure minimally if any at all, so even if youre chipped, you still shouldnt have problems. i get the same response from a lot of people, they think something is broken. its just the way the turbo was designed...
2004 F250 fx4 cc sb lariat 6.0, gray/black, everything, 6" edge & 3" hangers, rear 5" deavers & 3" blocks, 5150s front, 5100s rear 39.5" irok radials, 16x10 black helo maxx, 4.88s, warn premium hubs, fabtech adj. trac bar, rancho stabilizer, SCT "bustin that ass" tune by PDP, powershot propane kit, 4" stainless turbo back straight pipe w/ 6" HOG tip, airaid intake, APC projectors, APC corners, rebased philips 4300k HIDs with denso ballasts, donahoe lightbar, 3 hella 4000s, 2 pairs of KC backup lights, train horn, 200psi vaiar 380c & 6 gallon tank, kenwood 915dvd head unit with 4100 nav, sirius satelite radio, kenwood music keg, rockford 1051x, rockford bd1000.1, mb quart qsd216 in front doors, mb quart qsd213 in rear panels, 2 10" kicker L7s , RG gun rack, husky floormats, rhino liner, uws toolbox, UWS 100g aux. L tank, 14" solid stock drop hitch, more comin... MY TRUCK
1985 nissan on 33" boggers, the real mud monster...
mikeym is offline
Old 06-22-2004, 06:43 PM   #5 (permalink)
My Photos: (21)
But it sure would make a man feel better knowing that a wastegate were sitting there set to about 26psi... hhhmmm, you could be onto something there?
O
6.0 PSD TSB's
02/03 built F350 6L, DRW, 05 Grille , 4" DPPI Exhaust, UltraLites on the A Pillar and Overhead Console, Firestone Bags & Compressor, Hadley Bully Airhorns , 50 Gallon Transfer Flow, Racho 9000's, Leveled 2.5/0, In-Dash PC , XM Commander.
Photos
ozhoo is offline
Old 06-22-2004, 07:03 PM   #6 (permalink)
I am looking for reasons not to do it. I think it would be awesome to hear 30 lbs of pressure come out of a blowoff and look up to see a 10,000 pound truck go by. Can anyone think of a reason not to do this?
Old 06-23-2004, 08:13 AM   #7 (permalink)
Ummmmm....a wastegate has nothing to do with a blow-off valve. Everything stated above is corret, but it doesn't exactly mention anything about the thread's questions. The noises you hear from the motor after quickly lifting throttle after being under good amounts of boost pressure, IS from a build up of pressure, not a goofy little turbo noise that's normal. It does cause a decent amount of pressure on the turbo. Think about it....the turbine wheel is still being spun from the exhaust gases, but the compressor side cannot send the pressure into the motor, so it has to get forced back out the turbo and into the intake. This is where in some applications, compressor wheels can get bent. BUT since I'm sure Navistar has tested these motors quite extensively, I wouldn't worry about it unless you find a way to let the stock turbo boost to 35+ psi. If you like to spend money, and you want a cool sound, consider getting the HKS Super Sequential BOV for diesels. Since diesels don't pull vacuum, there's no way to open them when lifting the throttle, so the diesel version uses an electronic solenoid to actuate the BOV. Check it out here... HKS Diesel Photo
-Robert-
-2004/2004 F-350 XLT Sport, True Blue, FX4, CC, LWB, 6.0 w/ Torqshift. Sold 8/13/04 :-(
Truck Photos
-2004 F-150 Lariat, Supercab, 4WD (Replaced the blue beast)
-1993 Mustang GT, 330ci stroker, naturally aspirated, 387 RWHP/385 RWTQ, 11.69@117.98MPH
-2001 Mustang GT Bullitt
-2004 Explorer Limited, 4.6 (Wife's car)
PSDRob is offline
Old 06-23-2004, 09:39 AM   #8 (permalink)
PSDRob,
So, based on their explanation of the part below this would be a benefit to the engine?? I have the "turbo fart" and it varies on its frequency (sometime with just a little pedal) and it is something I have to live with. But, after reading the excerpt below it makes me wonder if this would be a good investment for turbo longevity, performance and getting rid of that irritating noise(I only have minor mods and will NOT chip my truck). I am not a diesel guru and have had NO problems with my truck (only took it in once for speedo recal). What difference in sound is there compared to the "normal" turbo fart? Do you know of anyone who has this mod and their input? Sorry for the novice questions...just trying to increase my knowledge base [img]/ubbthreads/images/graemlins/smile.gif[/img]
"HKS compressor blowoff and bypass valves play a vital role in any turbo system because they not only improve the performance of your vehicle but they also increase the longevity of the turbocharger as well. The primary function of any blow-off or by-pass valve is to prevent compressor surge by relieving the compressed airflow that reverses direction as the throttle is closed. HKS blowoff and bypass valves reroute the pressurized air, that is normally forced backwards into the turbo compressor, into the intake stream or by venting it to the atmosphere. Subsequently, engine performance is then increased from quicker turbo spool up, as the compressor speed is not reduced by the backward airflow. The longevity of the turbo is also increased, as its bearings will not suffer from the impact that is also produced by compressor surge. Though many vehicles incorporate factory by-pass valves, they are often undersized and quickly are beyond their capable operating range as airflow levels are increased. HKS offers four types of compressor blowoff and bypass valves: Standard, Racing, Super Sequential Blow-Off Valve, and the Racing Blow-Off Valve Type II."
Brand Spankin' New 2004 F-350 CC Lariat SRW LB, Clifford Matrix RSX3.5 Alarm, Stull Skull Grill, Tork-Lift Superhitch, DPPI Turbo Back Exhaust, Afe ProGuard 7, Firestone Air-Bags, EDGE 2" w/Bilsteins, Road Armor Stealth Bumper, Milemarker Winch,Rickson 19.5" Wheels, GoodYear G-124 Tires.
**Mods to Complete**
DVD & PS2 system
**Vehicles**
1997 F250 7.3 Powerstroke - Sold and now Stolen from new owner!
2000 Jeep Wrangler ROCK Krawler
2003 Lance 1010
ATV's
daha is offline
Old 06-23-2004, 02:31 PM   #9 (permalink)
DaHaHAZMAT,
It's tough to say. On a gas application, I wouldn't run more than about 7 psi without a blow-off valve. The blow-off valve is well worth it on any high boost application, I just don't know how well the HKS diesel model will perform. As long as it opened at the right times to release the compressor surge, I suppose it would work and be worth owning. The problem is that they retail for around $500 for the diesel model, which I couldn't find listed on their site anymore, so they may have stopped selling it. The sound is a high pitched, whistle sounding flutter. It is much different than the turbo fart you are used to. You can get a weld-on flange and mount it on the hot pipe (pipe from turbo to intercooler). The actual HKS SSQV works great on gas applications...I have used them personally with great success.
Again, I doubt that these engines and turbo would be at any risk of damage due to 100k+ miles of compressor surge, unless it was overlooked in engineering. It may lead to turbo failure sooner, but I doubt in most people's normal ownership time frame.
Also to consider...
The 6.0L uses a MAF sensor, which MAY cause a problem with a BOV. The air being released from the BOV has already passed through the MAF sensor, therefore, it will cause a slight rich condition, unless you found a way to vent it back into the intake pipe between the MAF sensor and turbo. The HKS SSQV isn't designed to be vented back in due to the design, but they do have an optional fitting that would allow you to vent back into the intake with a section of hose.
-Robert-
Truck Photos
PSDRob is offline
Old 06-23-2004, 03:01 PM   #10 (permalink)
Thanks for the info! I called HKS to get some more info but, the item is no longer available (no plans for another either).
Thanks for replying!
Take Care,
David
DVD & PS2 system
**Vehicles**
2003 Lance 1010
ATV's
daha is offline
Old 06-23-2004, 06:53 PM   #11 (permalink)
I have been told that diesel engines do not have blow off valves because there is not a throttle body. Diesel just simply do not put fuel in when you let of the throttle instead of shutting off the air. Because of this, there is not a excessive pressure to hurt the turbo. I am not a expert just passing along the reason I was told.
04 F-350 Lariat CC SRW 4X4 F1 RED
bigmac40 is offline
Old 06-23-2004, 09:09 PM   #12 (permalink)
So... I should worry that my Attitude reads 37+psi once in a while? I have never had a turbo fart. I wonder if a blowoff valve is the same as a popoff valve? Can you help my ignorance since I can't?
Thanks [img]/ubbthreads/images/graemlins/shrug.gif[/img]
2004 Excursion Limited 6.0 (Reflashed PCM x2)(Reflashed TCM)
AFE Magnum Force intake
Amsoil 5w-30 Heavy Duty Diesel Oil
UncontrolledCopy is offline
Old 06-24-2004, 12:35 AM   #13 (permalink)
I'm not sure totally about this either but won't a BOV cause problems when going from gear to gear? A BOV vents the air everytime you shift also, wouldn't that cause a slight lag or skip in power since a diesel motor does not need to release this pressurized air between shifting?
04' F-350, Crew Cab, King Ranch, Dually, LOADED.. DPPI Turbo Back, gauges,SCT from kermit, air raid, coolant filter, amsoil bypass
CAN YOU KEEP UP
06' ZX-6R
Dad's rides...
99' 7.3L F-350 Custom flatbed, supercab, dually
96' 7.3L F-250
99' Expedition 5.4L
99' Contour
2 T300 bobcat
6 custom built trailers
03' BMW 330Ci
soccerstud19 is offline
Old 06-24-2004, 08:51 AM   #14 (permalink)
My Photos: (9)
Why would you want a BOV when these turbo's sound cool as hell the way they are stock??
Turbo fart included...
'05 F-250 Harley-Davidson, 4x4, 6.0L, True-Blue, completely loaded with every possible option.
Motorstuff: NONE
'04 F-350 CrewCab FX4 DRW 6.0 2-Tone Black/Silver
Motorstuff: NONE
***TRADED-IN***
koolkat812 is offline
Old 08-30-2004, 02:22 PM   #15 (permalink)
At BD Power we make a BOV for diesel trucks its called the turbo guard. Its primary appplication is for the Dodge Cummins but it has been installed on a PSD before.
The bark is actaully compressor surge, and no the turbo/engine was not desinged for it. On gassers this surge is caused by the throttle body cutting the engine flow rate down to zero which in turns casuses all the bosst pressure built up in the intact to stall the compressor wheel. In a desiel applilcation the surge is caused by removing all the driving energy from the turbine side of the turbocharger.
Overtime it will destroy the thrust washers on the turbo and eventially the compressor wheel will clip the housing resulting in major damage.
www.bd-power.com
BD-Power & Valley Fuel Injection
Best 4x4 ET 11.8 @ 118 mph
www.bd-power.com
Christian Roth is offline
