Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - 6.0L Engine
Upgrades and Aftermarket - 6.0L Engine Upgrading and adding aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
Old 05-16-2004, 08:18 AM   #1 (permalink)
Anyone added a water temp guage to 6.0...
and if so, where did you place the sending unit???? Have guage installed and can't figure this one out. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
2004 F350 CC DRW 6.0/torqshift Lariat PSD
1996 Landcrusher, ARB, Sleed
Mirage 29CC/Volvo D6350DP
www.tunersportfishing.com
Wahoo is offline
Old 05-16-2004, 10:18 AM   #2 (permalink)
Re: Anyone added a water temp guage to 6.0...
I've got one in transit and I also need to know the best place to install the sending unit.
<font color="purple">Jon, keeper of Myocastor Coypus. Better known as </font><font color="blue">Boudreaux DaNutria.</font> [img]/ubbthreads/images/graemlins/crazy.gif[/img]
Stripping her Down to be Sold
<font color="blue">03 Black over AZ Beige CC LWB FX4 DRW Lariat</font>
DPPI T304 Turbo Back Exhaust*Edge Mini Spring Pack*New A/T Revo's*Hellwig Front & Rear Anti Sway Bars*Bilstein Shocks*VelvetRide Shackles*ProFlaps*Line-X'd*HarleyPedals*Chrome Tow Hooks*DashMat*VentShades*SilverStars
TubularSteps w/Aux Mkr Lights*LED Cup Holders*24" Silicone's*BrownBread*Wilson 5K Hard Mount CB & Cell Antenna*Rancho 5406 Stabilizer*Rear Eclipse 6x9's*Juice with Attitude
<font color="blue">Volvo VNL770</font>
500 HP Series 60 Detroit*AutoShift*231" WB w/Air Ride Cab*Heated AR Seats*Heated Power Mirrors*Power Windows & Locks*Garmin 2610*Alpine In Dash XM Stereo w/Dual DVD Changers*Dual Bunks w/Work Station*Fridge/Freezer Combo
Microwave*15" LCD TV w/DVD in Sleeper*BrakeSmart*Backup Cameras*Pressure Pro Tire Pressure Monitoring System
Crapper
huch1212 is offline
Old 05-17-2004, 12:29 PM   #3 (permalink)
My Photos: (5)
Try the heater supply tube (black-painted metal tube, passenger side front top of the engine). I would not recommend using a T-fitting at the existing ECT sensor location. Coolant sensors must be in a stream of coolant to operate properly, and putting them on a T-fitting takes the sensor nose out of the coolant stream.
Even with a core bypass valve, there will be constant flow in that heater tube.
AutoJim
Cooling Guy
'99.5 F350 Lariat CC SRW 4x2, 7.3L 4R100
'99 Mustang Cobra, SCCA Solo2 E Street Prepared
AutoJim is offline
Old 05-17-2004, 05:00 PM   #4 (permalink)
If you want to cut one of your Rad hoses you can install a coupler with a pre taped hole for the sensor. Sorry I dont have any links for it. I have a coupler on my Rx7 with a tap. Think I paid around 20 bucks for it. Came in a bunch of size's and is made of Alum.
03/04 F350 CC 4x4 Manual, 74 710k Pinzgauer, 95 Rx7
WonderChoad is offline
Old 05-17-2004, 07:27 PM   #5 (permalink)
Tginz apparently did it.
<font color="red"> Tginz's guages </font>
<font color="red"> Tginz's post </font>
Maybe shoot him a PM. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Mine: 2003.25 F-350 Lariat CC, SRW,8' bed, 6.0, Torqshift, Toreador Red, Tan Leather, Trailer Tow, Rhino-Liner, Dee-Zee Platinum Box, Adjustable Pedals, Heated Seats, 6 Disk Changer, DVD, 04 Keypad, AIC, 20% Tint, Escort 8500 X-50, Magellan Meridian Color Gps, Goodyear Wrangler 285 MTR’s. DPPI Dual SS Turbo Back Exhaust,"X" Springs,Issopro EV Pyro,Trans,Boost Guages, Under Dash Pod, Viair 550C AC, 26" & 29" Hadleys, 2006 Front End, Chrome Tow Hooks, Warn 16.5ti, Billet Cummins Killer Badges, Int. VT-365 Badges.
Diesel_Mom's: (Redhead): Goodbye 2001 EX, Thanks for 4 years. Brand Spanky New 2005 Eddie Bauer Excursion, DVD, Toreador Red</font> , 6.0L Powerstroke, all options including (3) children, (1) 95# Golden Retriever, Goodyear Wrangler 285 MTRs.
babacraig is offline
Old 05-17-2004, 09:04 PM   #6 (permalink)
Barrett, the 6.0L and the 7.3L are two completely different animules.
Unfortunately the 6.0L isn't very friendly when it comes to adding aftermarket water temperature and oil temperature gauges.
Crapper
huch1212 is offline
Old 05-17-2004, 09:39 PM   #7 (permalink)
wonderchoad, you have an rx7 also! what kind? any goodies?
glenb
05 F-250 SC, LB, 6.0L FX4 4.10s
23,500 miles, 03'turbo, 3.5" down pipe to 5" straight through with 6" tip, SCT by I.D. and DJ, autometer phantom II gauges, 18x10 INCUBUS recoils with 33/13.5/18 baja ATZ's, Donehoe 2.5" leaveling kit, ECLIPSE head unit, MB Quart's in the doors, JL stealth box, JL 400/4
glenboyesen is offline
Old 05-17-2004, 11:14 PM   #8 (permalink)
OK, my bad,,,,,again.
Sorry.
Barrett
Old 05-18-2004, 08:50 AM   #9 (permalink)
Thanks, those are two good suggestions. Now all I need to do is choose exhaust and chip....
Wahoo is offline
Old 05-18-2004, 10:52 AM   #10 (permalink)
My Photos: (5)
The difficulty with putting the temp sender in the upper rad hose is that, until the thermostat opens, it's not going to see accurate temperature.
AutoJim
Cooling Guy
AutoJim is offline
Old 05-18-2004, 10:56 AM   #11 (permalink)
it may not be the best spot, but i took the driver side block drain, and brazed an adapter to it and mounted my mechanical deal there.
short of that i was going to remove the front cover and weld a bung up there on return side.
1997 F-350 4x4 cc 5spd dually
1999 F-350 4x4 cc 6spd dually
2003 F-550 2x4 cc 6spd dually
<font color="red">My Trucks</font>
BOOB MAN
beddins is offline
Old 05-18-2004, 11:10 AM   #12 (permalink)
You've got the right idea, have a look at the 6.0 bible, page 29, it shows the direction of water flow. The sensor would need to be before the heater control valve as there isn't flow on the other side of the valve when Max A/C is selected. Even with the sensor in this location(prior to the valve), the readings won't be accurate when Max A/C is selected because coolant won't be flowing. I'm using this location to tap in for a coolant filter, using a 4 way pipe union, with the 4th position being the temp sensor. With the coolant always flowing to the filter, my temp readings should be pretty good even when the heater valve is closed.
Ken
<font color="blue"> F350 SWR 4x2 SWB King Ranch Build Week 10/13/03</font>
White, Dual Alternators, Camper Cert., Adjustable Pedals, Backup Sensor
Bilsteins, Velvet Ride, Oil Guard By-pass Filter, Coolant Filter, AIC,
Line-X, Peragon Bed Cover, Husky Mud Flaps
KenLewis is offline
