Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - 6.0L Engine
Upgrades and Aftermarket - 6.0L Engine Upgrading and adding aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
Old 07-09-2008, 12:09 AM   #1 (permalink)
ANYONE Own: Gear Vendors <dbl over-drive> ?
Im giving serious consideration toward a double over drive unit...
I've called and talked to 'em...its an easy enough <DYI> install 'cept
cutting the rear 1/2 of the drive shaft (which most tranny/driveline
shops can do).
a 3.73 rear becomes an effective 2.90, which puts a highway running
speed of 2000 rpms around 1500 (which from my experiance would
provide an mpg 21 mpg or better.
Im curious if anyone heres got one or experianced the GV or other
brand Unit...
bushpilot is offline
Old 07-11-2008, 06:22 AM   #2 (permalink)
VegasDiesel's Avatar
No but I'd like to hear more about something like this. Would a high performance transmission have the ability to have a double overdrive system as well?
If you like my Avatar, check out my girlfriend at BriannaJordan.com!
03' F350, 6.0, Crew Cab, Six inch lift, Amp Power Steps, Jimmie Jammers. Looking for help and advise to safely upgrade.
86' 944 Turbo. 4cyl, pushin'600hp. Now Goin' for 700hp! 194mph top speed. New custom tranny on the way to get me sub 4 sec. 0-60, top speed of 215mph and about 40mpg all at the same time!
04' 760li. V12, 443hp, Matching 22' wheels on adjustable coilovers, suede headliner, fridge in between reare seats, over 750 functions. Still don't know them all yet. For Sale! Buyin' a diesel car.
VegasDiesel is offline
Old 07-11-2008, 03:53 PM   #3 (permalink)
my friend has one in his 2000 f550 i have a hard time keeping up with him in my 05 e350 6.0 the only ploblem hes had was a contol module went out. my dad put one on his motorhome with a 454 chevy and he get beter mpgs towing than i do going the same speed caravaning. i'm no expert but if i had the money i have taller gears and a gear vender.
mxgimp is offline
Old 08-20-2008, 02:32 AM   #4 (permalink)
Tweintz's Avatar
I have a GV OD in my work F550 with a 4.88 and for highway it is a must. Love that thing!
GV is awesome and the trans shop that installed it, did an awesome job. I paid like 3k for the unit and 1700 for the install.
What is a double overdrive?
2006/F250/4x4/SC/LB/XL/6.0/3.73 (60K)
Info: 7000# Front Springs, Airaid Intake
2007/F550/4x4/CC/6.0/4.88 (10K)
Info: 4" Turbo Back Exhaust, Gear Vendors Overdrive, Airaid Intake
Tweintz is offline
Old 08-20-2008, 10:51 AM   #5 (permalink)
Bushpilot, it depends on what truck you have now.
If you have a 2wd, then I would go for a US Gear Underdrive and change the rear to a real low number like 3.08 or 3.31 to give you the best hwy setup and the pulling gear when you need it.
If you have a 4x4, then you are more limited due to the lack of anything below 3.55 for the front diff (depending on year). This is my situation. If your truck is old enough your don't have the dana 50 or 60 front diff, you have maybe the 44? which allows for these lower gears.
Double overdrive is a term referring to the use of the factory OD and an aux OD like GV or USGear Dualrange. The drawback to this is the increased losses due to gearing up twice, then down in the differentials. This is why the dualrange in the underdrive version would be best for a truck that sees a lot of lightly loaded highspeed running, but needs to tow heavy occasionally.
Another consideration is your tire size. Again 2 or 4 wheel has impact here. If you have a solid axle front drive, then you cannot lower your truck and smaller tires look ridiculus (my opinion only). If you have a 2wd then you can lower your front down to accomidate the stock tire size and your ideal gear will be different.
Getting back to the double overdrive, I spoke to GV at length and they claim a much lower 'loss' going through their unit then a conventional gear. I'm not sure how that could but it could be true. If so, this somewhat negates the frictional increases due to double OD and may be the ticket for us 4x4 folks.
I could go on and on, but you should do a search on Gear vendor and Dual range or US Gear overdrive as there are plenty of threads on this subject going back years.
Here's a link from a guy that had both:Auxiliary transmissions
Good Luck and please report back on what you get and how it works for you.
02 CC 4x4 auto, AIS, DPF5, FTVB, 4" Banks Monster SS Exhaust
blackout is online now
Old 08-20-2008, 04:37 PM   #6 (permalink)
Interesting thread thanks for the link, I believe we all want to save $ but with all the cost for an overdrive unit how many miles must you drive to break even?
2006 Lariat Chrome Edtion Red F350 CC 4X4 Dually w/4:10 Gears Born 04/26/06 w/ color matching speedliner, PCM Reprogramed to Level "L",@ 24,535 miles AMSOIL Front to Back, AMSOIL By Pass Filter BMK-11, Amsoil Coolant Nitrogen in all 6 tires @ 75 PSI W/ 34.2 x 102" wide Coachman Royal TT.
Gone but not forgotten 2001 “X” 7 years / 218K w7.3
Ken1 is offline
Old 08-20-2008, 11:12 PM   #7 (permalink)
My Photos: (13)
US Gear does not offer a Dual Range Aux tranny for the 6.0's....The 7.3 was the end of it for US gear. :-(
07 F350 CC King Ranch Auto 4x4 PHP H.O. FICM
06 F250 SC XLT Auto 4x4 LWB 3.55 gears Edge Juice/Att, PHP H.O. FICM, PHP Gryphon Custom tuner.
04 F350 CC King Ranch Auto 4x4 Edge Juice/Att, EGR delete, Cat Delete. Org. Program w/ real T/H and Quiet idle.
00 F350 CC Lariat PSD 4x4 (PHP Gryphon Custom Tuner) 6 speed, US Gear OD, 2 stage propane
94 F-Superduty PSD 5 Speed 12' flatbed
93 F-Superduty 7.3 IDI N/A 5 speed 12' Dump box 60,000 org. miles
Thanks to:
Power Hungry Performance
My photos
Jeremy is offline
