ARP Install - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Old 11-04-2009, 11:38 PM   #1 (permalink)
ARP Install
anyone done the ARP stud install themselves? I just got my truck and blowing a head gasket kind of scares of, so obviously i would like to be proactive. I have access to pretty much all the tools i would need, is this something I can do or do I just need to pass it on to someone else? (i assume the cab needs to come off?)
spacecwboy is offline
Old 11-05-2009, 12:23 AM   #2 (permalink)
l.gerard's Avatar
Yes the cab needs to come off so a lift is necessary but i would be somewhat cautious before tearing down 6.0 as they are a bit more complex than a 7.3 , but if you have worked on 7.3 engine internals you should be able to handle it. good luck
2002 F-350 Crew Cab, DRW to SRW conversion, 6spd, 5'' lift, 16x8 Ultra chrome wheels, 35'' nitto terra grapplers, Rough Country dual front shocks, Bully Dog air & pre filter, Autometer Cobalt pyro & boost gauges, 4'' downpipe with 5'' exhaust,
l.gerard is offline
Old 11-05-2009, 02:37 AM   #3 (permalink)
boomboom's Avatar
Look at this; go to 6.0 powerstroke engine & drivetrain section, look for "taking the cab off for head studs " page 12 ? , read reply# 5 the last post on this thread was 10/16/09
boomboom is offline
Old 11-05-2009, 09:15 PM   #4 (permalink)
crfishon's Avatar
My Photos: (12)
Send a message via Yahoo to crfishon
had mine done by ford under warrranty, i just had to supply the arp studs and they put them in, but yes they also removed my bed.
2005 F-250 CREW CAB 6' BED - 6" PRO COMP LIFT ON 22" DIESEL RIMS WITH NITTO GRAPPLER M/T 35'S - AIRID AIR FILTER - HIGH IDLE MOD - 4" EXHAUST - MAG HYTEC FRONT AND REAR DIFFERENTIAL AND TRANNY COVERS - ARP STUDS - SCT X3 - BULLY DOG PMT(for monitor only) - SMOKE SWITCH - RBP GRILL - RECON CAB, BRAKES, 3rd BRAKE LIGHT and EXTREAM TAILGATE BAR - HARLEY HEAD LIGHTS WITH HID'S - AMP POWER STEPS (the best) - AMP BED STEP - PIONEER Z110BT NAVIGATION - BACK-UP CAMERA - A5 ROOF MOUNT SAT W/AUTO TRACKING - 12" FLIP DOWN DVD - PLAYSTATION 2 - PUNCH 45 - PUNCH 150 - MTX10" THUNDERFORM SUB (now JL sub) - PYTHON AUTO START ALARM - SMARTSTART(for iphone control & notifications of alarms) - K5 TRAIN HORNS WITH 200psi DUAL COMPRESSORS(tied into alarm) ><))))*> Fish On
crfishon is offline
Old 11-05-2009, 10:44 PM   #5 (permalink)
unfortunately i am out of warranty (04 with 82K miles). so any changes will be done on my dime. I ordered a 4" turbo back exhaust today to help get the exhaust pressure and heat down. Im not doing a chip, so hopefully this help
Old 11-25-2009, 05:35 PM   #6 (permalink)
Spoolin'6.0's Avatar
Send a message via AIM to Spoolin'6.0
there are plenty of guys on here thaat have studded these truck cab on motor in and i personally am going to try it they say it isnt a piece of cake but it is much more convient for them as well it is me
D&W DIESEL PERFORMANCE
DIESEL TECH
ELITE DIESEL ENGINEERING
SCT
TS PERFORMANCE
MBRP
BULLY DOG
AIRAID
Spoolin'6.0 is offline
