Upgrades and Aftermarket - 6.0L EngineUpgrading or adding OEM or aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
The OEM bolts are torque to spec and prone to stretch enough to let the heads lift in some cases. The ARP studs greatly minimize that chance. That's all they do.
__________________ 2004 EB Excursion, 4x4, 6.0, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto, V code front springs, Revo 285's and bubba lights
FamilyRide said what the studs them selves do as compared to the OEM bolts.
To answer your questions:
1. You can go well above the 425-450HP limit that the stock head studs tend to have.
2. If you are going to stay stock, or not push a high power program, you might not want to worry about studs unless you blow them. If you do blow your headgaskets stock or under a low-power program, you might have warped heads.
3. The odds of blowing a head gasket with studs installed is low...unless you have warped heads, in which case you could blow them again.
In all honesty, I wouldn't spend money on these unless you prove to have a need for them. Your engine should NOT need them if you are running stock programming, for the most part.
If I can blow my head gaskets stock at 18k miles, anyone can. If it was caused by warped heads, then anyone can get warped heads as mine were straight when the gaskets were replaced.
Let me answer your questions:
1-Run lots of power reliably
2-Put stock TTY bots back on.
3-Unlikely unless the dealer has no idea what they are doing or you decide to run boost pressures higher than 50psi.
__________________ 2004 F250 CC FX4 / 46g Transfer Flow / ARP Studs / Coolant Filter / CCV
Thanks, guys, for the helpful information. Guess if I find out next week if the head gasket(s) blew, I'll order the ARP studs and have them installed.
Is there a better set of head gaskets that should be used as well? Will the OEM gaskets be okay with the ARP studs? I mean, I know they will work, but is there something better? Do it once, not twice...
Hey John, are you saying that you do have a problem and that next week you might find out you need HG? If so, give us more info about what is happening...
There are a higher tensile strength stud from Elite called H-11's. Arp's are around 240,000 psi and H-11's are around 270,000psi tensile strengths. Do you need the higher for your application? No you do not. The H-11's are also about $220.00 more than the ARP's. I believe the stock bolts are around 165,000 if I remember correctly. I could be off some but it's pretty close for SOME info.
NEW TRUCK.... 2007 Jeep Grand Cherokee SRT8 Black, Magnaflow Exhaust, Volant Cold Air Intake, and a nice system....
GO GATORS!!! 2007 National Champs Baby!! Ummm... Football AND Basketball
04 Harley Edition Solid Black, 8" Fabtech shocks and hangers and ladder bars, Superlift Springs, 38x15.50x20 Toyo Open Country M/T's, Weld 20x12 Cheyanne 8 rims, Fabtech Ladder Bars, AFE Intake, straight exhaust, SCT with Extreme Street from Eric at Innovative, Full SunCoast setup, SPEARCO INTERCOOLER(Thanks BBunting), Mag Hytec Tranny Pan, GReddy Turbo Timer,Alpine IVAD300 Flip out DVD player, Alpine 5 channel amp, JL 6x8 Seperates, JL Audio 12W7 Sub., JL Audio 500.1 amp., ISSPRO triple guages, sunroof, diff covers powder coated comp. orange, 03 Turbo, and oh yeah... 2005 Harley Edition Headlights.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: JohnHagen</div><div class="ubbcode-body">Thanks, guys, for the helpful information. Guess if I find out next week if the head gasket(s) blew, I'll order the ARP studs and have them installed.
Thanks again.
John </div></div>
Make sure the dealer is willing to install the studs before you go spending that kind of money.
AFA headgaskets go, the stock gaskets are fine for stock and more than mild applications. If you are building a sled puller or race truck then I would suggest other gaskets.
Smiley, I pull a 11K pound 5er up and down passes like Raton. I need something that won't blow (again?) and is reliable. Can you recommend a brand of gaskets?
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: bogg</div><div class="ubbcode-body">Hey John, are you saying that you do have a problem and that next week you might find out you need HG? If so, give us more info about what is happening... </div></div>
Bogg, I have pretty well laid it out in a couple of posts within this thread. Right now, without the 5er hooked up, I get the hissing sound if I really romp on it (stock tune). Noise comes from drivers side, probably the gasser bottle, but not sure. Seems to turn on and off. I cleaned off the white mess on the underside of the hood above gasser and will see if it pukes any more before I have the mechanic looking at it on Monday (soonest I could get in).
so what gasket should you use if you plan on injector / turbo upgrades...
2003 F350 4X4 Long bed Charcoal Crewcab 6.0l Diesel, built 01/03, Sports Pkg, SCT XCal, Boost Trany EGT Pilar gauges, Airaid Cold air intake, MBRP 4'' Turbo Back Exhaust with 5'' Tip, Bed Line-X, Smoked tailights, Ford Idle Controller, Donahoe 10.5 Lift, Toyo 38's, Mag-Hytec Tranny + Front and rear diff covers, Banks Intercooler, Dieselsite Coolant Filter, and more to come.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: JohnHagen</div><div class="ubbcode-body">Smiley, I pull a 11K pound 5er up and down passes like Raton. I need something that won't blow (again?) and is reliable. Can you recommend a brand of gaskets?
John </div></div>
Gaskets are not the issue here, although they did upgrade them. Its the poor quality head bolts that stretch and alow gasses to seep out causing erosion of the gaskets themselves. ARP studs will solve this even with an 11k lb trailer.
If you want to go crazy, get fire ring gaskets. They are expensive and require machining of the heads. If you are only looking to go mildly overboard, there are wire ring gaskets, however, their site recommends the Ford stock head bolts only be used (I have no idea why...)
The stock gaskets and ARP's will hold extremely well if your diesel tech is compitent by checking flatness and performing a proper install.
Good luck.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: JohnHagen</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: bogg</div><div class="ubbcode-body">Hey John, are you saying that you do have a problem and that next week you might find out you need HG? If so, give us more info about what is happening... </div></div>
John </div></div>
Bogg, I apologize... It was in the other forum thread where I explained what happened. here is the link...
OK, Ford just put new heads and gaskets on my truck. I was running an extreme tune when they went. I am going to install ARP studs myself. The truck smoked a lot with this tune. I was thinking that I may be able to bring the boost up 15% and bring the fuel up 5% which will clean up some smoke and give me more power. Can I do this with studs? What do the tuners do different if you have studs and you are looking for more power.
