Ats 5r110 Trannie - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Old 10-20-2009, 04:15 AM   #1 (permalink)
Ats 5r110 Trannie
I just bought a new ATS Billet Trans with a 5 disk converter. Just wondering if the bad rep that ATS has had in the past has gotten any better? My 06 CC dually has 92k on it now and I tow most of the time with it. The only reason I bought the trans was the great price. I would think with a 5 year and 500k warranty they would go broke if past problems were not fixed. The truck has a 5 inch exhaust with an AFE intake and a SCT 2 tuner. I also just did head studs and an EGR delete. It runs great and is easy on fuel. The SCT has Inovation tunes and is set on a tow tune right now. HP and TQ should not be the issue with the trans, and I am easy on her as well.
2001 F350 CC LARIET LWB 3.73LS SRW 4X4,ARE CAP WITH FULL REAR DOOR, SOFTRIDE 4 INCH WITH RS9000'S ,MAG HYTEC REAR END COVER AND TRANS PAN,GULF COAST FILTER,AMSOIL THRU OUT,BANKS EXHAUST,TS CHIP,AFE STAGE 2,TRIPLE A PILLAR W/PHANTOM GAUGES,BTS TRANNIE AND BOBS REMOTE FILTER,6.0 TRANS COOLER,WELD VELOCITY 8'S W/ NITTO 325X18'S,KENWOOD 850 WATT SYSTEM W/CHANGER AND SIRIUS RECIEVER,POWER SLIDER,
2006 F350 CHASSIS SRW WITH WALK-IN SERVICE BODY, XLT,KENWOOD STEREO, QUADZILLIA, AFE, 5 INCH EXHAUST
2006 F350 CC Dually 4x2 SCT-2 W INOVATIVE CUSTOM TUNES, AFE, MBRP 5 inch stainless W/ SEWER PIPE TIP. RECON LED's TRIPLE A PILLAR W/ PHANTOM GAUGES
SUPER WONDER DAWG is offline
Old 10-20-2009, 06:07 PM   #2 (permalink)
lubbockguy1979's Avatar
Send a message via Yahoo to lubbockguy1979
ive never owned a ats product but from what i have heard they are hard to get the warranty honored. but like i said ive never dealt directly with them.
2006 f250 4x4
crewcab short bed
lariat 6.0psd
auto, electric tcase
soon to have isspro
fire/air/trans/fuel
stock suspension and
pretty much everything
else
lubbockguy1979 is offline
Old 10-20-2009, 06:23 PM   #3 (permalink)
aekrogh's Avatar
I have an ATS trans (4R100). it has been good to me.....But if it were to give me problems, then know that I know I would go to John Woods, just because he is close to me(SOCAL), and has a great Reputation. If I Lived up north then BTS would get my service.
The one thing I dislike about the ATS trans is that to keep it under warranty you must change the trans fluid ever 10,000 miles, which in my opinion is to frequent.
With the deep pan, double trans coolers my oil rarely gets to 160 degrees, most of the time it stays about 20 degrees over whatever the outside air is. My Trans fluid always looks great, bright red and no smell ever. I have had the trans going on 3 years and about 60k miles.
Hope this helps.
Late 99 SD PS CC SB 4x4 Lariat. 7.3l TS 6xchip Stock-140hp , Banks 6gun, Full Banks Gauges, 4"SS turbo back exhaust, UMP Intake w/ Donaldson Filter, Auburn posi F&R 3.73, ATS Trans W/ 5Star converter and CoPilot, 18k trans cooler, Dynatrac FreeSpin front hub kit, ITP oil X over, ITP boost regulator, Aero Fuel Tanks Replacement 55 Gallon tank, New timing cover,oil pan,oil cooler, water pump,turbo petastel, reman HPOP, new fuel filter housing, slotted brakes all 4 corners W/ Ceramic pads, Adjustable trac-bar, Front 1.5" level kit only. 226,000 miles 10/1/09 Best mpg 27.3..Norm city 15 mpg hwy 20+
Early 99 CC LB 2WD Manual 6....Stock 228k (11/09) and running strong, only repairs Clutch, water pump, alternator. K&N FIPK since 36k and loving it!
2006 CC LB 4WD Lariat 6.0l 5R110 Stock 178k (12/09) "Dad's" 3 injectors and GP harness(12/09) Dynatrac Ball Joints, New ERG and 2 injectors (6/10)
aekrogh is offline
Old 11-07-2009, 10:05 AM   #4 (permalink)
Just a quick update. The trans so far has been good as gold. I am getting ready for a complete service on the truck including a complete trans flush and new filter. I am going to drop the pan and clean it as well. I did go with factory ford fluid from the startup. It just keeps shifting better and better.
Be Safe
THE DAWG
