Upgrades and Aftermarket - 6.0L EngineUpgrading and adding aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
-2003, F-250 CC Auto 4x4, 6L, Charcoal Gray, 4" PC Lift, 315/75/R16 PC Mudders, Weld
Stone Crusher Wheels, AFE PG7, SCT X-Cal, 4" straight pipe, 3 guage pod White Night Backup Lights, Cobra 29 NW Classic CB and a couple other little goodies.
-16' enclosed trailer for my toys
-04'Honda CRF450
-04'Honda CRF50 for my girl
I had a torque lock on my 7.3 with the 4R100 and it worked great. The autolok is different in that it does not have manual switches to control the T/C lock up like the torque lock. I also have a 03 like you and can't stand the T/C lock up since the last flash. I am waiting for a manual override switch for the T/C to become available (like the torque lock). Going to call BD again and see. Quad is supposedly working on a stand alone tranny box, but no info available yet as to what it is going to do, or how it is going to control it, (I want manual) maybe in a month or two.
TWC88
2003.25 6.0, Born 2/03, 5R110W, XLT Dually Super Cab 4X4, 4:10LS, AIC, full set of gauges, Line-X Bedliner, Full MBRP exhaust, New turbo 5/3/05, 6 injectors (1,2,3,4,5,7,) 12/29/05, Inductive flash 3/8/07, .
2004 Titanium 5th 28E33, 2 Honda EU-2000's.
The benefit is that it will keep the T/C locked. The 03's (don't know about other years) after the december flash will unlock the T/C every time you let up on the go pedle. This is a big problem when towing, because it won't relock very easy (You need to be flat and level not acelerating). The problem with this is when towing on a hill and you let up for a second then get back in it, the T/C will stay unlocked for the rest of the hill. Or if going down hill and you let up to maintain speed it unlocks, (even in cruise) then if you roll right into another hill it won't relock. So when towing 10K lbs. at 65MPH I end up pulling a lot of hills at 3000 RPM or so. This was not like this when new, but only after the December flash. Also, it was not advertized this way, but it is what I got.
TWC88
