Upgrades and Aftermarket - 6.0L EngineUpgrading and adding aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
I just installed a Banks sixgun and a tb MBRP system. I know that everyone says that the SCT is the best for the trans shifting but I wanted something that I can change on the fly. The question is will the shifting get better? The instructions say that the trans learns to handle the power. Also this is the first aftermarket exhaust that I have put on a diesel. I am getting a little vibration when you take your foot off the accelerator when slowing. Is this usual and I have more in cab noise from the exhaust. Is that normal? Not talking about the louder muffler. Thanks for any input.
You cant have you're cake and eat it too. You had to pick, shifting or change on the fly, and you picked the change on the fly. The problem with that setup on the t-shift is that if you constantly change the powerlevel the tranny is constantly learning, all the while giving you crappy shifts. So no don't expect the shifting to get better if you plan on actually changing power levels on the fly. You could get a sct to program the tranny only though, that would be the best bet to get better trans control.
Justin
Current 2002 F-250 Crew Cab SB 7.3 Auto 4x4 White FX4 131k
2000 F-250 7.3 Auto Shorty Extended Cab 4x4. Bought brand Spankin new. Zoodad, Hypertech tuner, straightpipe. Sold @ 69k miles. Bought New in 2000 sold 07/03 to get a 2003 Crew Cab. Needed room for the baby.
03 F-250 Crew Shorty Torqueshift 4x4. Bought 05/03 brand spankin new, Traded in 10/06 As of 10/06 111k Tuned by Innovative, Mbrb Turbo back with extra whistle, Airraid intake, Guages. **Update** 10/06 Oil cooler sprung a leak and caused the entire cooling system to fill with oily water. Dealer quote -- 4900.00. Injectors were missing on cold start sometimes took as long as 5-10mins. for them all to start firing. Come on ford! Traded truck in one week later for 2007 Dmax/Allison LBZ
2007 Silverado Classic Duramax LBZ. Bought brand spankin new. 6 speed ally, crew, Longbed, 4x4 charcoal grey. Stock for reliablity. Sold (Crew Cab Long Bed is impossible to drive in town, and missed the fords. 7.3 here i come)
I would look closly at the downpipe where it passes the firewall.
Since it can get very close to the flange where the firewall is spotwelded to the underside of the cab, sometimes it will be hitting it.
If you find that might just be it, loosen the flange at the turbo outlet, and the clamp in the middle of the two piece downpipe and attempt to move it a little further to the right or left to see if you can't gain more room.
Thats where mine was rubbing.
Remember, Patience is a virtue.... [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]
All the luck but you bought one of the very best pipes available.
JR44
2003, F-250, 6.0L PSD, Torqueshift, CrewCab, XLT,FX4,Short Bed, All Black Sport Model, Sunroof, Line-X Bed Liner, AFE Stage1 Pro-Guard 7, DPPI/MBRP T-304 Stainless Turbo-Back Exhaust, complete with CNC machined collar!
Banks Tecni-Cooler, Front,Rear Diff & 5R110 Mag-Hytec Pans, AutoMeter Cobalt Boost,EGT,Trans Gauges on A-Pillar, Bridgestone 285 Revo's, Bilsteins,SSBC V8 BRAKE CALIPERS, POWERSLOT CRYO ROTORS, Lund Smoke Bug Shield and Weathertech's AeroVisors on all windows. 16YR N.R.A. member, 14YR D.U. member, 10YR N.W.T.F. member. 5YR Delta Waterfowl member. www.rntcalls.com
Thanks for the comments. The reason for changing on the fly is I do a lot of pulling and depending on on the situation I may need more power. I will give Mark a DPPI a call to see about the SCT.
The install went pretty flawlessly though. Would be a snap on a lift but on the ground not bad. Probally about one hour.
I did mine last week on the ground. Had the wife get on the creeper under the truck to hold the downpipe while i put the clamp on the turbo flange. All the local shops around here wanted $300 to do the job. It rattled on the trans crossmember before I finally got it right. Worth the hassle, yes.
2005 Lariat 6.0 LWB fourx4 3:73 Silver Metalic, Heated Captains chairs, Tow Command, Reverse Sensor, Intergrated Brake Control, Power Rear Window
MBRP Turbo back exhaust, Glasstite Canopy, billet grill,
Lucy - Wife
Charlie- Golden Retriever
2000 HD Road King
2008 HD Sportster 1200c
I started out with nothing and still have most of it left....
I cannot claim much credit for my install, I just conned a few Machinist buddies who like to work on this kinda stuff with some
extremely cold adult beverages and a crisp fifty each...
They told me to stay out of their way while they fought with the stock downpipe and cut the stock exhaust apart with a trusty sawzall!
They had it put in in less than 90 minutes!
All they let me do was final adjustments and tighten up the stainless band clamps that hold the sections together.
They were impressed with how well the kit fit together with NO additional fabrication of any kind.
In fact, another guy there had just installed another brand of exhaust and said the MBRP made his look like junk!
If I had to do it myself, I'd sit down to review the installation instructions and take my time with it.
If you are good with the common hand tools your over halfway there.
Don't foget to ice them down before you begin!! [img]/ubbthreads/images/graemlins/smirk.gif[/img]
Have a good weekend.
JR44
