Upgrades and Aftermarket - 6.0L EngineUpgrading and adding aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
Let's beef up the 6.0 FAQ, stop before you move the post, the FAQ should be clean and concise, so the fact finding post should be here, and then condensed in FAQ.
I propose we have a Cheap/Free mods post, and Tech specs post (dimensions, weights, etc). I've seen this on jeep forums and its pretty cool.
What do you guys think?
2004 6.0 F250 CC shortbed 4x4, 3.73's, zoodad, steve racer mod, harpooned tank, 30% 3m on fronts, lineX bedliner, DR leveling, bilsteins, 315/75 nitto terra grapplers, navi, code reader from dfuser, on order: cryo'd rotors, hawk pads, snuglid sl, nchornet ccv, ate super blue fluid
fumoto w/ nipple
high idle mod
2Low mod
TC lockup, TC light mod
warn hubs
No takers huh? Well this is what I have so far. Obviously I'm missing a lot of links, and a lot of mods. C'mon guys add some links to cheap/free mods
Reason: duplicate
Foglight mod; S&S Diversified
How to control Mirror heat;Here are the directions for hooking up the mirror heat to an upfitter switch. It is easiest to remove the four bolts that hold in the fuse panel and pull it forward. The wire you want is on the middle connector, on the back of the fuse panel. It is on the left side of the connector, second from the bottom. It is green with a purple strip. You can double check by hooking up a test light or meter and turning the ignition on. It will then show hot(12v). Next remove the fuse for the mirror heat and retest. If it is cold you know you have the right one. Cut the wire about an 1 1/2 inches from the fuse panel and strip both ends. Put a connector(bullet or butt) on the end coming from the wire harness and attach the other end to the upfitter wire one or two. I then took the other end coming out of the fuse box and attached a female bullet connector. This gives me another fused ignition on power source.
Thanks ritschner ! I added both, and i added a link to the fumoto
Cheap Mods HFCM upgrade-HFCM upgrade maglite clips-Maglite Clips zoodad- longer wiper blades- 24" Wipers hibeam+fog (steve racer?)- Hibeam+Fog (Steve Racer) Foglight upgrade- Foglight 9005 upgrade harpoon-Harpoon fumoto w/ nipple- F-111N Fumoto oil drain valve F-111N tubing doors- excursion sound panel- Excursion Sound Panel excursion wheel well panel-Excursion Wheel Well Panel high idle mod-High Idle 2Low mod- TC lockup, TC light mod- warn hubs- 08 diff cover- front door marker-Front Door Marker marnico plug mod- Block heating cord instructions- Heater Cord Install AIC- AIC Acetone Badges- Apply acetone to remove the black paint on the factory badges and make them chrome. Snowman Mod- Backup Lights- Backup Lights How to Control Mirror Heat-How to control Mirror heat;Here are the directions for hooking up the mirror heat to an upfitter switch. It is easiest to remove the four bolts that hold in the fuse panel and pull it forward. The wire you want is on the middle connector, on the back of the fuse panel. It is on the left side of the connector, second from the bottom. It is green with a purple strip. You can double check by hooking up a test light or meter and turning the ignition on. It will then show hot(12v). Next remove the fuse for the mirror heat and retest. If it is cold you know you have the right one. Cut the wire about an 1 1/2 inches from the fuse panel and strip both ends. Put a connector(bullet or butt) on the end coming from the wire harness and attach the other end to the upfitter wire one or two. I then took the other end coming out of the fuse box and attached a female bullet connector. This gives me another fused ignition on power source.
