Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - 6.0L Engine
Upgrades and Aftermarket - 6.0L Engine Upgrading and adding aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
Old 06-26-2008, 01:23 AM   #1 (permalink)
Question best air intake system
hey guys.. i have a 2006, 6.0, f250 super duty, 4-door, long bed, 4x2 , standard tranny.. i have put a 5" MBRP turbo-back system w/ cat delete and a six-gun Banks programmer..
i was wondering what is the best air intake brand and system would be for my truck... i'm considering an s&b but wanted to get some input before i buy...
-thanks
-2006, Black on tan, f250 SD, 6.0l, long bed, Frontier-Gear Bullnose Bumper Replac., crew-cab, 4x2 , manny tranny, 5" MBRP turbo-back, ARP Head studs to keep that power goin to the tires and not through my hood,
SCT from DP ....
azkcr is offline
Old 06-26-2008, 02:50 AM   #2 (permalink)
I did my research and had it confirmed today buy The Truck Stop. I am installing a K&N 63 series that will replace my horrble Visteon intake. The guy I talked to has same truck as me and says his works great plus adds 2 to 3 mpg. Hope I helped some.
PosterBoy is offline
Old 06-26-2008, 10:07 AM   #3 (permalink)
2-3 more mpg sounds pretty helpful to me!! haha.. i like K&N, it's what i used on my last truck (6.0 gas) and what i MADE my dad use on his 2000 7.3..
i havent ever heard of a visteon??
SCT from DP ....
azkcr is offline
Old 06-26-2008, 11:11 AM   #4 (permalink)
-thanks
"Best" how?
Best "filter" is a plank in front of the turbo.
Best "flow" is nothing in front of the turbo.
How to balance between the two & factor in cost is what engineers get the big bucks for and then the accountants tell them whether the company can afford it.
Until you stick bigger injectors and a different turbo on it, the stock Donaldson "intake" is the best balance of price, performance, and protection available. If you need more flow, you will loose protection. How much that matters to you is up to you.
OMC
OMCUSNR is offline
Old 06-26-2008, 11:55 AM   #5 (permalink)
fireguywtc's Avatar
I was wondering if anyone has any input on the true flow XDI air filter. I wanted to upgrade my intake also, but want to keep good filtration. I understand stock is best filtration but i want more performance too. The XDI is different in my research to the other filters since it uses foam type filter with a tacky oil. Same type of filter I had on all my motocross bikes. I figured if it works for dirt bikes, should be good for our trucks. however it's hard to find facts on this since it's a newer product.
07 F-350 xlt 6.0 PSD LB CC SRW 4x4, black on tan, A/T, 5" exhaust 4" downpipe, SCT livewire, S&B CAI, the rest is good from
fireguywtc is offline
Old 06-26-2008, 11:56 AM   #6 (permalink)
where i live the conditions aren't too harsh so protection isn't a factor... just as long as i'm not running straight air..
and it's 4x2 so it's not like it's going to be seeing any mud/sand/dirt etc..
i want the most air-flow.. period... and i know all about bigger injectors and turbo.. they will come later..
this is for mostly for MPG purposes because it has seen a lot of highway and will see tons more..
SCT from DP ....
azkcr is offline
Old 06-26-2008, 12:16 PM   #7 (permalink)
i've been looking at them all and XDI is one that i was considering.. but at $350+......
SCT from DP ....
azkcr is offline
Old 06-26-2008, 12:42 PM   #8 (permalink)
fireguywtc's Avatar
I have found the xdi for 299 on ebay new +15 S/H. and 339 on extrmedieselperformance.com free shipping. Other then that I have been seeing AFE with progaurd 7 alot. It's 275 on extremedieselperformance.com best price I can find again. Those are the 2 that I think im toying with. My only reservation is the light oil type filters seem to suck the oil up into the turbo and gunk it up.
Old 06-26-2008, 12:53 PM   #9 (permalink)
ya, about the oil getting in the turbo; that's why i was leaning towards s&b because they have somehow "formulated their design" (supposably) to keep oil from getting sucked into the turbo AND helps prevent the oil from messing with ur mass air sensor..
this is what i watched... truthaboutfilters
SCT from DP ....
azkcr is offline
Old 06-26-2008, 12:56 PM   #10 (permalink)
The S&B is also a significant amt. cheaper than most...... but i go by what u pay for is what u get...
but they actually go into detail about their filters unlike others.. Only experience i have with kits are K&N (and are good.. i could take it or leave it) but that was on gas and was wondering what was best for diesel
SCT from DP ....
azkcr is offline
Old 06-26-2008, 04:46 PM   #11 (permalink)
I've never seen any test numbers from K&N or XDI which is why I avoided them. You'll like the S&B. It's a very large filter and the whole setup looks impressive under the hood. It filters negligibly less than stock but flows quite a bit more.
2005 F-350 LARIAT 6.0 PSD SRW AUTO FX4 (removed) CC SB White, International emblems, Tow Command, Upfitters, Line-X, ScanGauge, Tomtom, XM, S&B w/Zoodad, Dieselsite coolant filter (w/RMI-25) and braided 4x4 lines, Mag-Hytec trans pan & diff covers, Fumoto oil valve (Rotella T), Knurled HFCM drain plug, Britebox, EZ-Down tailgate, BedStep, MBRP 5" cat-back (6" tip), Putnam class V hitch (Custom Texas star & horseshoe hitch cover), TransferFlow 30 gal toolbox tank + 46 gal midship tank = 76 gals. total with Stanadyne Performance additive... the rest is all stock you nig nogs. 41k miles.
Waiting for "BigTurbo" to help me install: Dieselsite Trans filter kit.
ljr869 is offline
Old 06-26-2008, 05:24 PM   #12 (permalink)
That is exactly what i thought.. sacrificing a little bit of filtration but you can't argue with the added flow.. and the price isn't bad...
thanks!!
PS- i noticed you have a zoodad mod.... is it worth the time? and i have no clue as to what it is except that it just seems like you make a hole in ur truck......
SCT from DP ....
azkcr is offline
Old 06-28-2008, 03:54 AM   #13 (permalink)
Noffense but been there tried that. ain't gonna happen. save your money sell the Banks and get an SCT X3 with custom tunes and keep the Donaldson filter. If you want something worth while under the hood put in a regulated return fuel system.
-12/02 built 6.0
-FX4 Lariat supercab 4x4.
*Truck modifications*
-Banks turbo back exhaust
-DJs Fuel+ Intensifier fuel system
-SCT X3 DJs "tow w/ Jake brake"
-Dieselsite coolant filter
-4.30 gears
-CCV reroute
-Fumoto drain
-Autometer Cobalts in woodgrain pillars.
-Goodyear 19.5 G-124 14-ply on Vision wheels
-Concept Patterns "burnished" F/R diff. covers.
-Ride-rite airbags
-Rancho RS 9000XLs w/incab remote
-Torklift Superhitch
-Current oil: Cenex Maxtron 15w40 synthetic blend
snoboy is offline
Old 06-29-2008, 05:55 PM   #14 (permalink)
GOT14U's Avatar
has anybody here actually done research on how much our engines (i.e. 7.3 or 6.0) need as in air flow. from my understanding you would need to do some OUT ragous mods to actually need more air flow then what stock delivers. and have you looked at how awful the filtering is on the k&n type filters. just my 2 cents but i think it is more then likely a waste of money. not to mention letting more junk in to your trucks engine.
02 EXCURSION (4" EXHUAST,DI CHIP, FS2500 FILTER, 4 GAUGE PILLAR, AUTOMETER PHANTOMSII,ALPINE DECK,BOSTON ACOUSTIC 12",1000 WATT AMP,COOLANT FILTER SYSTEM,TRANNY BYPASS FILTER,AMSOIL FLUIDS ALL AROUND, V10 TRANNY COOLER, CAI, 200AMP ALTERNATOR, DIESELSITE BILLET THERM HOUSING, DIESELSITE OVER BOOST RELEASE VALVE, BTS VALVE BODY)and still more coming
04.5 GMC DURAMAX.....i know...i know !!
07 28' WEEKEND WARRIOR(12,385 lbs gvwr)
07 DUCKS UNLIMITED RHINO
5 KIDS
1 WIFE
3 DOGS
THANKS TO SHAWN @ RAGIN FOR ALL HIS ADVICE AND HELP!! U NEED SOMETHIN GIVE THIS MAN A CALL.(NO BS, AND NO UP SALES)
GOT14U is offline
Old 06-29-2008, 06:06 PM   #15 (permalink)
correction, when i got down there the guy was pretty cool and informed me that he had ordered a Volant for another customer but never showed. Long story short, I went with the Volant for the same price as the K&N. Which he explained how it was better on performance and better for the turbo than K&N, which people buy because of the name. Not to mention I saved about 75$ that the Volant would have costed.
I have a Visteon intake for sale if your interested. Its not cold air but it is big as hell and will keep some flow and protect your turbo. PM me if interested.
2004 F-250 Turbo Diesel (Harley Davidson) Black on Grey, Banks Six Gun Bundle, 2 Gauge Pillar Mount, Volant Ram Air Intake....(to be continued)
» Site Navigation
» Home
