Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - 6.0L Engine
Upgrades and Aftermarket - 6.0L Engine Upgrading and adding aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
Old 03-13-2005, 11:36 AM   #1 (permalink)
william_04_X's Avatar
best location to mount thermocouple?
hey guys,
i'll be putting a turbo-back exhaust system on my X and want to install a thermocouple for pyrometer...is there a preferred location and any tricks from experience to make it easier...
thanks,
wiliam
04 EB X w/03 PSD
Southern Nevada Power Strokes.Org
william_04_X is offline
Old 03-13-2005, 12:31 PM   #2 (permalink)
Lightningfast01's Avatar
Re: best location to mount thermocouple?
My Banks Six Gun kit requires it in the manifold just off the #5 cylinder. I think anything after the turbo skews the readings.
Lightningfast01 is offline
Old 03-13-2005, 02:05 PM   #3 (permalink)
teamroper60's Avatar
Driver's side exhaust manifold, near the last cylinder. It's real easy to reach, drill and tap. I think this is the most common location and it's pre-turbo, so you will get more accurate readings from there.
2003 Toreador Red/Arizona Beige CC, DRW, Lariat, FX4, 6.0 PSD, Torqshift, born early Feb. 03, (still running the original flash!), AIC, MBRP turbo-back exhaust, Tuning by Total Diesel Performance, AFE PG7, Fumoto valve, B&W hitch, Di-Pricol gauges, Voyager brake controller, DIESELSITE Coolant filter, Timbrens, Rancho RSXs, Michelin XPS Traction's, a whole bunch of "bling", Connex 4300hp, JL Audio 275w amp w/ 12" sub, Alpine door and rear seat speakers. 376hp
pics
#43
SLAPS President and Webmaster
teamroper60 is offline
Old 03-13-2005, 03:41 PM   #4 (permalink)
FamilyRide's Avatar
And in my tradition, I have to also mention the clamp on style in the up-pipe as mine is done. [img]/ubbthreads/images/graemlins/laugh.gif[/img]
2004 EB Excursion, 4x4, 6.0, everything but step tubes and 2nd row chairs, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto sitting on V Codes and Revo 285's.
FamilyRide is offline
Old 03-13-2005, 05:02 PM   #5 (permalink)
[/ QUOTE ] This is where I mounted mine and I have noticed that letting the truck cool below 350 takes a while several minutes of idleing and to me it seems to rise and fall very quickly from 1000 to 450 in about 20 or so seconds is this normal? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Nick
2005 F-350 Lariat 6.0 PSD CC Dually 4x4
Big Black Beast
Born 2/14/05 delivered 2/28/05 Purchased 3/1/05
2000 X Limited PSD 4x2 Stock. SOLD
Nick_Kowal is offline
Old 03-13-2005, 06:48 PM   #6 (permalink)
hey guys,
you're talking like you drilled and tapped for the thermocouple with the ex. manifold on the truck...i'm too afraid of metal shavings going through the turbo if i left the manifold on....can you be a little more specific...
04 EB X w/03 PSD
Old 03-13-2005, 07:27 PM   #7 (permalink)
hey guys,
Yes, on the truck. Start with a very small pilot drill and slowly go up in drill sizes. After each drill bit size is used, stick a shop-vac hose over the hole to collect any shavings.
There are many guys here and do the above without the shop vac with no problems with shavings. Using the different size drill bits ensures that the shavings are small enough to pass through the turbo.
CMOS
2004 Ranger SCAB
Shopping for 99-2002 7.3 CREW
CMOS is offline
Old 03-13-2005, 08:40 PM   #8 (permalink)
CMOS
That is how I did mine. I did keep the vacuum running and next to the drill bit when I was making the hole.
Mark
2003 F350 6.0l PSD, Arizona Beige/Black, CC, Short Bed,Lariat FX4, AFE Magnum Force Pro-Guard 7, DPPI T-409 TB Dual Exhaust, ISSPRO Gauges, RoadArmor Fleet Series Bumper, MileMarker 12k winch, TAG, Westin Oval Tube Step, Pro-Flaps on rear, More to come as wife lets me! 27' Komfort 5er. My Photos
Oboy is offline
Old 03-14-2005, 10:33 AM   #9 (permalink)
I did the drill and tap but what I did was use a large magnet to collect the shavings before they fell in my face then I ran the magnet up and down the mainifold to pull all the shavings out. It worked really well for me. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
Nick
Big Black Beast
Old 03-14-2005, 02:50 PM   #10 (permalink)
jla
hey guys,
CMOS
This worked for me as well. 1st time it's fired up after the install, don't touch the throttle for a couple of minutes to let any fine shavings you didn't get with the vacuum get through the turbo at it's lowest speed.
Jay
2004 F250 SC 2WD Lariat
Ordered 17July03
6.0 PSD Build Date 1August03
Truck Born 4August03
Delivered 12August03
<font color="red">(06E17)</font>, Dark Toreador Red/Med. Flint leather, TorqShift, LWB, Adjustable Pedals, Heated TT Mirrors, Captain's Chairs, Bright Tubular Cab Steps, Clearance Lights, LineX, Weather Guard Chest, Reverse sensors, 3.73 LS, HD Hitch Receiver, Ventshades, 24" Silicones, Bullrings, Fumoto, Viper VX-791 w/Remote Start, DiPricol Gauges in under cubby mount, Garmin 2610 GPS, VT365 "Endless Road" Badges
<font color="blue">Average MPG (Mixed driving) 16.65@ 37,534 miles</font>
jla is offline
Old 03-14-2005, 06:47 PM   #11 (permalink)
i've been told to keep grease on the drill bit also...i'll use all three tricks and that shouldn't let a thing through...
thanks guys,
william
04 EB X w/03 PSD
Old 03-14-2005, 10:38 PM   #12 (permalink)
thanks guys,
william
[/ QUOTE ] Don't use grease It will cause the shavings to stick and they may stick in the manifold, I don't know who told you to use grease but I think they were wrong. All the directions I have read mention "not" to use grease.
Nick
Big Black Beast
Old 03-15-2005, 02:09 AM   #13 (permalink)
I pulled the manifold per Banks instructions a 10 minute job.
Old 03-15-2005, 02:31 AM   #14 (permalink)
With all the stuff under the hood and it's only a "10 minute job"? Doesn't seem possible.
2003 6.0L F250 XLT S-Cab 4x4 FX4 White/Black
my97TJ is offline
Old 03-15-2005, 10:45 AM   #15 (permalink)
You remove the wheel and fender liner it is right there naked and easy to get to.
