Re: Big tires, chips, etc.: new gears?
i am thinking that you are looking to do the same things that i did to my truck -- see my sig below...
reason i went with gears is because i tow a very heavy toyhauler. gears will get you near stock and that is important for shifting points for the tranny. you could always add a SCT that can be custom tuned for the new gears too, that will give you some more HP and torque. i would recommend either eric or tadd, as they both have some great tunes.
if you are not towing, then i would reconsider running 4.56s. if you do alot of freeway driving, then your RPMs will run you about 2200 at 70/75 mph -- and that means lots of fuel... so, if you feel the need to re-gear, then consider 4.30s.
let me know if you have any more questions...
2003 Ford F350 Crew Cab Long Bed 4x4, 6" Edge all spring lift with Adjustable Panrod Bar and Dual Steering Stabilizers, 37" BFG Mud Terrains, 4.56 Richmond Gears, DPPI Turbo Back Dual Exhaust, Autometer C2 Gauges on A Pillar, aFe Proguard 7 Intake, Reese Titan V Hitch, B&W Turnover Hitch, BrakeSmart controller, ORU Air Overload System
My truck pictures
