biggest tire size with a levelling kit???????? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Old 07-29-2008, 10:30 PM   #1 (permalink)
I have an 06 F-250, Crew Cab, 6.0, FX4, Lariat. I recently got a levelling kit of 2 1/2". Right now I have 285/65/18's on aftermarket wheels. Can I fit 325/65/18 or 325/70/18 with it the way it is? I knew a guy who had 325/60/18 on a stock truck, but it was a F-350. I have a front end replacement so I have a lot more clearance in the front than a stock bumper. What do you guys think? I have attached a photo of my truck, but it was before the levelling kit just to show the front clearance.
ccolley68 is offline
Old 07-31-2008, 07:14 PM   #2 (permalink)
Just FYI, I went by the tire shop yesterday. they had 2 325/65/18's that I put on to test fit. They fit fine other than a little bit of shaving on the bottom of the plastic in the wheel well. The owner of the shop has the same truck as I have with these same tires on a stock truck with 22" rims. He did a little shaving, the exact same as I did today, so if he can fit them with a stock truck, no problem with mine with the leveling kit.
Old 08-02-2008, 05:12 PM   #3 (permalink)
I ran 37X12.50R18's on my Stock Harly Wheels with a 3.5" leveling kit on my 04 F350 for 2 yrs befor I went to 22x11's (and 37x13.50R22's) and had to do more lift because of the wheel offset.
2004 F350 Harley CC 14.2@92mph
93 Dodge Stealth RT TT 8.81@166.7mph
95 3000gt VR-4 10.56@136mph
92 Dodge Stealth RT TT 10.69@133mph
95 Dodge Stealth RT TT 10.88@129mph
FastMatt is offline
Old 08-02-2008, 05:41 PM   #4 (permalink)
305/65/17s on aftermarket wheels with a 2.5 inch leveling kit, probably closer to 2 or 1.5 with the weight of the bumper and winch. Absolutely no rubbing.
07 F350 XL FX4 std cab 8' bed
4" MBRP turbo back straight piped
47 gal transfer tank
Warn 16.5 ti 16,500 lb winch, semi hidden winch mount
Skyjacker 2.5 inch level + 305/65/17 BFG AT on black 17x9 ProComp 7005
Recon White Lighting
Alpine head unit, 4 channel MTX Blue Thunder amp, Polk component MOMOs up front, Infinity Refrence in back, Alpine MRP450 + 10" Kicker CompVR
COMING SOON: 2 DD 1508s in 1.9 cubes @ 38 Hz + AQ1200D
FarmF350 is offline
