Blue Spring Kit Causes Pressure Drop - Page 2 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Old 01-16-2013, 03:47 PM   #16 (permalink)
tperk100's Avatar
Dealer
04 F350 Lariat, ExCab, SRW, 6.0, LOADED Shorty
SCT SF3, MBRP Turbo Back 409, Max AC Assist
DieselSite Coolant Filter, OilGuard Bypass Filter
Fumoto Drain Valve, HFCM Separator Drain Plug,
EGR Delete, 50 gal TransferFlow, Sliding Cargo Bed
ScanGauge II, GlowShift EGT, Boost, Fuel Pressure
Front Receiver, Warn 8000 lb (Draw Bar Mount)
WeatherGuard Lo-Siders, MacNeil Floor Liners
Galaxy DX95T 10 Meter w/ CB Mod, Wilson 5000
Kimber SS .45 cal UltraCarry w/ LaserMax!
Frame Mounted Safe,
Empty Weight with 80 Gal Fuel 8400 lbs
tperk100 is offline   Reply With Quote
Old 01-16-2013, 06:40 PM   #17 (permalink)
HeavyAssault's Avatar
My Photos: (6)
Any new info??
2006 F-350 CC PSD Lariat 4X4 LB 3.73 LS
Some stock stuff, some modded stuff, some deleted stuff.....
HeavyAssault is offline   Reply With Quote
Old 01-16-2013, 08:46 PM   #18 (permalink)
tperk100's Avatar
Still working on it. Should be able update tomorrow.
Frame Mounted Safe,
Old 01-17-2013, 08:02 AM   #19 (permalink)
Band_Member's Avatar
My Photos: (64)
Did you bleed the adaptor line to the fuel pressure gauge sender?
Also, when was the last time you changed your fuel filters.
Have you tried to remove and re-install sencondary fuel filter (possibly not seated correctly) and make sure the stem is not damaged or not seated correctly.
Any noticeable fuel leaking around the secondary housing?
So you still have old spring. New one should be about 3/16" longer than the old one.
When I swapped out my OEM spring for the factory upgrade almost 2 years and 24K miles ago my FP has been reading between 75-80Psi.
I wouldn't recommend driving it if your Fuel Psi is below 45.
2005 F250 XLT SC, LB
6.0 Torqueshift
3.73LS 4x4 ESOF
A/C, T/C
Trk Bld: 02/05/05 KY
Eng Bld: 02/03/05 Indianapolis
2450 Hrs +/-, 90K Miles - No Major Probs
ZOODAD, SEIC,
Atlas 40 FICM @ 90K
4" Banks Turbo-Back Duals
3.5" Ready Lift
Bilstein 5100's
315 - 70R17 Duratrac's
Bodiak Front Receiver
SG2
Coolant Filter
HFCM Plug Upgrade
Blue Spring Upgrade
FP Gauge
Zerex Red ELC
2 Stroke TC-3W Oil added 1oz/Gallon Fuel
~driver like ya stole er~
Band_Member is offline   Reply With Quote
Old 01-17-2013, 09:50 AM   #20 (permalink)
tperk100's Avatar
Band,
Do you think air in the adapter line would cause a low reading? If so, how would you recommend bleeding it?
Fuel filters are not issue. They are new and pressure was 45 before blue spring.
No leaking that I can see.
Frame Mounted Safe,
Old 01-17-2013, 11:20 AM   #21 (permalink)
ford_doctor's Avatar
Gauges don't requiring bleeding. Pressure should build up very quickly. Your pressure problem has to be related to the regulator. You either bent the spring, left out an o-ring or did not put the air bleed orifice back in. I have seen all three occurrences. When replacing the regulator the air bleeds out of the system quicker than when you replace the filters and since you cycled the ignition we can pretty much rule out air.
Ford Master Diesel Technician
Diesel Technician Society
Diesel Mentor Directory
ford_doctor is offline   Reply With Quote
Old 01-17-2013, 12:59 PM   #22 (permalink)
tperk100's Avatar
Thanks Ford Doc...guess I will be taking it apart again.
Frame Mounted Safe,
Old 01-17-2013, 01:45 PM   #23 (permalink)
tperk100's Avatar
UPDATE - I ohmed the gauge pressure sensor while running and compared it to what PSI the gauge should read. The gauge is working as intended.
This you will find to be "veddy intresting." I noticed the other day that the pressure seemed to be rising just a little bit each time I drove the truck for a few minutes. After first replacing spring, PSI was around 25-30. Now, after running some errands today, PSI at idle is up to 53!!
What SHOULD the PSI at idle be with the blue spring?
I have to wonder if I did not seat an O ring well enough, or maybe I did bend the spring and it whatever the problem is its working itself out!
Any thoughts?
Frame Mounted Safe,
Old 01-17-2013, 02:32 PM   #24 (permalink)
Did the black plastic insert go back in where the brass relief valve inserts?
Is it cracked? Not seated?
I'm assuming that truck has the black insert. My recollections is 03/04 have it and 05-07 do not.
2006 F450 CC Hauler bed 4x2 6.0 L Pstroke/Torqshift, Lariat, 4.30 r/a.
2006 F350 Lariat CC Dually 4X2, 6.0 TQShift 4.10 LS, STOCK.
36 foot double tandem axle flatbed trailer.
36 foot Sooner 6 horse large dressing/ mid tack.
15 horses with good balance from being hauled behind a P'stroke.
jimmy is online now   Reply With Quote
Old 01-17-2013, 03:21 PM   #25 (permalink)
My Photos: (64)
Originally Posted by tperk100 View Post
Band,
My Sinister FP gauge adaptor has a schrader valve to bleed the air right where the sensor screws on. From what I've read in the past people have had issues with a newly installed FP gauge that didn't bleed the air out of the adaptor line. Just a suggestion of things to check.
6.0 Torqueshift
3.73LS 4x4 ESOF
A/C, T/C
ZOODAD, SEIC,
Atlas 40 FICM @ 90K
3.5" Ready Lift
Bilstein 5100's
SG2
Coolant Filter
HFCM Plug Upgrade
Blue Spring Upgrade
FP Gauge
Zerex Red ELC
Old 01-18-2013, 02:46 PM   #26 (permalink)
tperk100's Avatar
Update...... After driving about 30 miles, and watching pressure gradually rise, pressure is now holding at 58-60 PSI. Go Figure!! I am going to leave it alone (never did take it apart again) as long as it reads and runs well.
BTW, I also upgraded my FICM with a programmed unit from FICMrepair.com. The truck runs like a bat out of h$%^! Turbo response time was cut dramatically.
Frame Mounted Safe,
