Bought a used X3 with DJ's tunes. Was taken off of an 04 now put on 05. Anything I need to do? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Old 01-09-2008, 09:44 PM   #1 (permalink)
I bought a used X3 with DJ's tunes loaded on it. The X3 was taken off of an 04 6.0 and will now be put on my 05 6.0. I was wondering if there is anything I need to do or any changes to run it on the different year truck. Thanks
Can't wait to try it out. Was going to get an edge but heard way too many good things about the SCTs!!!
penglin is offline
Old 01-09-2008, 10:05 PM   #2 (permalink)
snoboy's Avatar
Re: Bought a used X3 with DJ's tunes. Was taken off of an 04 now put on 05. Anything I need to do?
Yea. You need to verify that the engine and transmission strategy that the tunes were written for is the same as the engine and transmission strategy thats in your truck.
-12/02 built 6.0
-FX4 Lariat supercab 4x4.
*Truck modifications*
-Banks turbo back exhaust
-DJs Fuel+ Intensifier fuel system
-SCT X3 DJs "tow w/ Jake brake"
-Dieselsite coolant filter
-4.30 gears
-CCV reroute
-Fumoto drain
-Autometer Cobalts in woodgrain pillars.
-Goodyear 19.5 G-124 14-ply on Vision wheels
-Concept Patterns "burnished" F/R diff. covers.
-Ride-rite airbags
-Rancho RS 9000XLs w/incab remote
-Torklift Superhitch
-Current oil: Cenex Maxtron 15w40 synthetic blend
snoboy is offline
Old 01-09-2008, 11:50 PM   #3 (permalink)
darsey715's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: penglin</div><div class="ubbcode-body">I bought a used X3 with DJ's tunes loaded on it. The X3 was taken off of an 04 6.0 and will now be put on my 05 6.0. I was wondering if there is anything I need to do or any changes to run it on the different year truck. Thanks
Can't wait to try it out. Was going to get an edge but heard way too many good things about the SCTs!!! </div></div>
Did the previous owner return their truck back to stock? If so and the strategies won't work together you'll have to unlock it but if they work then you should be set. call a tuner for the best answers.
darsey715 is offline
Old 01-10-2008, 11:22 PM   #4 (permalink)
You can check it to see if it was returned to stock. Also I would not load the programs on it. You will most likely need custom tunes for your PCM. Let me know if I can be of any help.
dfuser is offline
