Bulletproof diesel EGR and oil cooler upgrades - Page 2 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Old 10-23-2009, 03:35 AM   #16 (permalink)
boomboom's Avatar
Originally Posted by mlwest View Post
It does appear to be a very pricey kit - especially when you consider that they appear to have done a great job in engineering the oil transfer block but then chose a terrible mounting location for the cooler. Not only is it vulnerable but I can't leave my front license plate installed (a requirement here in California), it doesn't appear that I can retain my very functional fog lights and I'd have to mount the oil filter in an area prone to accumulate lots of mud/dirt even with my 2WD truck.
My 04 is now experiencing the plugged oil cooler issue and so I've been researching the whole topic.
I've been looking over my truck trying to find a better location - I haven't seen any that jump out at me.
However, not being one to give up easily, my first alternative is to use a bit of technology from the off-road/buggy guys and use a remote mount, electric fan/thermostatically controlled oil cooler. I'm thinking of mounting it beside the rear of the tranny (auto) on the drivers side as close to the bottom of the cab as is possible with the fan pointing towards the rear of the truck pushing air through the cooler. I'd mount the oil filter nearby, probably in front of the cooler and again as close to the bottom of the cab as possible to keep it out of as much of harms way as is feasible.
Anyone got any better ideas?
Would it fit on top of factory tranny cooler ? Or get some HEAVY DUTY thick wire stainless steel mesh screen and cover the opening in the bumper in front of the cooler. I have some of this screen and it has 1/8" holes with 1/16" dia.SS wire wieve. IT would stop a brick doin 70mph REAL HARD to cut though.
boomboom is offline
Old 10-23-2009, 06:29 PM   #17 (permalink)
I have heard that they are working on a new mounting location - back behind the condensor and in front of the radiator......
ASE Master Tech
Diesel Shop Owner
2005 F350 4x4 Crew Cab 6.0L
Upgraded EGR Cooler
BulletProofDiesel Engine Oil Cooler
http://www.bulletproofdiesel.com
TorqueMasterG is offline
Old 10-24-2009, 01:37 AM   #18 (permalink)
Supporting Member
It's too bad there isn't a convenient place where you don't dump the heat right in front of some other heat exchanger trying to get rid of its heat.
I still haven't found a better place than under the drivers side cab/frame location.
mlwest is offline
Old 10-24-2009, 02:02 AM   #19 (permalink)
boomboom's Avatar
Well that would be right on top of the tranny cooler I guess. Did you put anything in front of YOUR cooler to protect it. That stainless steel screen is tough stuff. I thinking about covering that area plus behind the grille to protect the AC condensor.I've got some nasty dents in it already from rocks. I'm really shocked rocks haven't punctured a tube.
boomboom is offline
Old 10-24-2009, 04:53 PM   #20 (permalink)
Supporting Member
engine oil cooler location
yeah, putting another heat source on top of something trying to rid itself of heat just isn't a good thing.
I just took a look at how Ford fed incoming air to my existing heat exchangers and they seem to have done their homework. The really low coolers have air angled up at them from below and have no direct path to them for foreign objects and the big tranny cooler has only thin horizontal slots where something might pass through. Probably not enough for serious off road work but OK for the almost exclusively street miles I drive.
I'm headed out this afternoon to look at locally available aftermarket oil coolers with electric fans to see just what might be available.
mlwest is offline
Old 10-25-2009, 12:42 AM   #21 (permalink)
With my BulletProofCooler I have not had any real problems with debris, etc, hitting my cooler. I don't really lose sleep over it. I have had an occasional rock hit my windshield, but never break a headlight, hit my hood or even my grill for that matter. So maybe I don't think that its likely to have a rock hit my cooler.
The bumper DOES protect it fairly well. It would take a "unique" shot to hit the cooler. Not saying its impossible... just not probable for the way I drive and where I drive. Additionally, the cooler itself is VERY tough. Its the same cooler that is used on lots of trophy trucks in the baja 1000 race. Perhaps they are mounted differently, but the baja is no easy environment. Its a very thick, very rugged aluminum cooler.
If you want to go with some sort of wire mesh... its an interesting idea. The problem is that if you go with something "too protective", it actually will restrict the flow of air significantly. Something much more than chicken-wire or chain link fencing (as an illustration only) can drastically affect air flow. Not that chicken wire is going to win you any awards at the next truck show, but it would stop 99.9% (??) of any damaging rocks coming at your cooler.
ASE Master Tech
Diesel Shop Owner
Upgraded EGR Cooler
Old 10-25-2009, 02:05 AM   #22 (permalink)
Supporting Member
Good to hear about real experience with product
At least they seem to have chosen a stout cooler - a good thing.
My complaints are not only that I wish there was a better spot due to vulnerability but the kit has me hanging an oil filter right where lots of debris build up (not that it's something a garden hose wash down couldn't clean up most of the time) but I'd like to use a two filter arrangement.
I'd be stuck (because I live in a very warm climate) having to perform that strange mod to the A/C system - get a GM fitting and bump the amount of refrigerant up somewhat. Makes me believe that there's a whole bunch of heat being dumped right where not only the A/C is compromised but also my terrific automatic tranny cooler won't be as effective.
There's got to be a better location.
mlwest is offline
Old 10-25-2009, 10:39 PM   #23 (permalink)
Talking
The kit comes with the GM version of the orifice tube. Its not that "strange" of a mod, actually, but I understand where you are coming from. I live in Phoenix and I would consider that a warm climate, too. I installed the kit in August and the AC did not work well until I changed this orifice tube. I talked to the guys at BulletProofDiesel.com and asked what was going on.
They explained that the AC compressor was short cycling and this made the AC "not work" in its current configuration. They went on to explain that by making the o-tube a bit larger, it allowed the compressor to run longer and the freon to go through into the evaporator. Adding a bit more freon made the pressures and cycle times perfect. I did as they instructed and I was freezing myself out of my truck soon after.
ASE Master Tech
Diesel Shop Owner
Upgraded EGR Cooler
Old 10-25-2009, 10:52 PM   #24 (permalink)
In terms of "dumping heat right in front of a place also dumping heat" is true, but not wholly in this sense. The fact of the matter in this case is that you are simply trading heat from one heat exchanger and dumping out through a different one. Its a zero-sum game, but one with advantages.
Its similar to changing a $20 bill for a ten and 10 ones. The ten ones you can use to buy a soda from the machine, but you can't do that with a $20. The sum was the same, but the flexibility was an improvement.
So what does this have to do with heat transfer you may wonder? Well in the case of this BulletProofDiesel Oil Kit, by adding the engine oil cooler at the front of the truck, you aren't dumping "extra" heat (my word) onto another cooler in an additive sense. The heat coming out of the oil would have been in the coolant/radiator with the stock Ford engine oil cooler. So, in essence, the total number of BTU's being dumped into the air flow are the same, just like a 10 and ten singles is the same as a twenty.
Now, you might argue, that the sequence of heat exchangers is important... and I would agree. I can also tell you that from my experience with the kit, I have not had any heat related problems with regards to my other systems with the lone exception being the AC already mentioned.
If you do mount your cooler back on the frame, you could have issues there with regards to heat. I would expect that while its "not near" any other coolers, you are now downstream of ALL the other coolers, meaning that you aren't going to get nice, cool, clean ambient air going through your frame mounted cooler (even with elec fans) but, rather, you are going to get all the waste/dumped heat from the intercooler, radiator, etc now getting pulled into your frame mounted coolers. Perhaps that will still work well... I would love to see!
One person I did talk to had an interesting point: we were talking about frame mounted coolers, too. I suggested the electric fans and frame mounting (he had an ambulance chassis). He said "you must be from someplace warm!"... being from PHX I had to agree and ask him how he knew.... any one have an idea how he knew?
ASE Master Tech
Diesel Shop Owner
Upgraded EGR Cooler
Old 10-26-2009, 02:12 PM   #25 (permalink)
ridintall's Avatar
Originally Posted by teamroper60 View Post
I had my heads machined, headgaskets replaced, studs installed, some EGR work done, a new oil cooler (purchased separately from Ford for less than $600) installed, the coolant flushed/refilled, oil change and the A/C recharged for less than that.....
I paid appr. $4K for oil and EGR cooler replacement in my van and that was after they discounted a bunch of parts for me. (They took 10-20% off of some of the parts). I also put in a coolant filter afterwards.
Oogs
2004 6.0 E350 Quigley 4x4 w/ Sportsmobile Conversion.
285/75R16 BFG AT/KO. 3.73 Gears.
Dieselsite Coolant Filter.
Aluminess Front/Rear Bumpers.
125W Solar Panel.
Sportsmobile Trailer on 285/75R16 BFG AT/KO tires w/ dual deep cycle marine batteries, water pump, 10 gal water storage, air compressor, storage box & 15W Solar Panel.
Wiring Harness Recall - 15K miles
EGR Valve replaced @ 30K miles
Oil & EGR Coolers replaced @ 62K miles
Tank delamination - Reconditioned by Gas Tank Renu @ 62K miles
Vacuum Pump replaced 69K
SnowMan Mod / Door Seal Mod
ridintall is offline
Old 11-14-2009, 05:36 PM   #26 (permalink)
Supporting Member
OK, so now can anyone verify the claim that the 6.0L motor oil pump is capable of generating 16 GPM flow?
mlwest is offline
Old 11-18-2009, 11:28 PM   #27 (permalink)
Supporting Member
Actually I should have said 18.5 GPM - that seems like an awful lot of oil flow!
mlwest is offline
Old 12-31-2009, 02:03 AM   #28 (permalink)
I saw a Motocraft video that mentioned specifically the 18.5 gpm at peak loads.... that is a bunch of oil!
ASE Master Tech
Diesel Shop Owner
Upgraded EGR Cooler
Old 02-13-2010, 02:18 PM   #29 (permalink)
I just joined this forum today. I'm going to buy the Bulletproof EGR Cooler; 1) That is one of the big down falls of the 6.0, 2) Bulletproof seems to be the only aftermarket supplier for this. Has there been any issues with that upgrade (craftsmanship issues, welds leaking, etc). I haven't experienced any problems yet and don't want to. I am having a little pedal response issues but i'll clean up the top end when i get the EGR cooler.
koz-1978 is offline
Old 02-13-2010, 03:05 PM   #30 (permalink)
Supporting Member
Don't know if you have already done the oil cooler but if not then you've got a lot of research to do and you'll have to be more specific about pedal response issues.
Search this site for failed oil cooler and failed EGR cooler - there's a lot of information.
As for the quality of the parts from bulletproof - I just installed the new EGR cooler, oil cooler and oil transfer block. Expensive kit but all parts are of top quality and I believe both the oil transfer block and very stout oil cooler are actually made in this strange place called USA? Where the heck is that - LOL.
Good luck.
Just one more 2004 6.0L owner
Edge Insight display
bulletproofdiesel oil transfer block
bulletproofdiesel oil cooler
dieselsite coolant filter
mlwest is offline
