Bulletproof diesel EGR and oil cooler upgrades - Page 3 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Old 02-13-2010, 04:47 PM   #31 (permalink)
I haven't replaced anything yet. I know I have a lot of stuff to do. I've seen you post quite a few times with alot of insite and info which has been every useful. I'm going to start with the common cause. It hasn't affected me yet; in the same token i want to elimintate the engine killing problem first before it turns into a heart transplant. By replacing the EGR cooler along with the OEM oil cooler, it gives me somewhat of a clean plate. I have small things like fuel filter to replace (which I don't think have been replaced yet since I bought the truck used with 66000 on it), clean the EGR valve also. It is an 05 f-350. She use to be a work truck and a car hauler; but she is a weekend driver. I can sit here all day and pick your brain. As for the pedal response. From a dead stop, the truck doesn't have excelleration like it use to have. That is what i was trying to get across
koz-1978 is offline
Old 02-13-2010, 05:20 PM   #32 (permalink)
TousleyParts's Avatar
If your acceleration is starting to suffer, its possible that the veins in the turbo are sticking. You'll find a bunch of info on that subject also. It'll be off to do the cooler anyways; might as well take it apart and clean it. It may be fine, but it might be worth looking into if it has not been apart before.
We are Tousley Ford parts depot selling all OEM Ford and Ford Racing parts 10% over dealer cost. We sell heavy truck parts as well!
Please PM me for any price requests
Call us at 1-800-328-9552 ask for Gene or Mike R OR check out our website www.tousleyfordparts.com Be sure to mention this website for the good discount.
TousleyParts is offline
Old 02-13-2010, 05:32 PM   #33 (permalink)
The EGR cooler is going to be done no matter what.
koz-1978 is offline
Old 02-14-2010, 09:15 PM   #34 (permalink)
Supporting Member
Two methods
Be aware that if you are into the motor far enough to take care of the EGR cooler then taking care of the oil cooler is a no-brainer.
IMHO their are only two ways to approach this oil cooler problem of the 6.0Ls - either replace the OEM parts with the bulletproofdiesel gear and not have to ever think about that problem again or replace the OEM oil cooler, add the coolant filter and do LOTS of flushes with the Ford flush and change the coolant filter religiously.
I decided to just jump right into a change in design rather than a patch and hope for the best.
Just one more 2004 6.0L owner
Edge Insight display
bulletproofdiesel oil transfer block
bulletproofdiesel oil cooler
dieselsite coolant filter
mlwest is offline
