Upgrades and Aftermarket - 6.0L EngineUpgrading and adding aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
Can the Head Studs be Installed without pulling the Engine??
I have a friend that is looking at buying a 6.0 and he was wondering if the Head Studs can be installed one at a time with the engine in the truck.
Thanks for the help...
Barry
If you live in AZ come join us at Arizona Powerstroke Group... Click here... http://www.azpsg.com/index.php?referrerid=6
99.5 F-350 PSD Lariat, 4x4 Off Road, CC, SB, 3.73's, NVK2, BTS Trans and T/C, V-10 and Tru-Cool Max Trans Cooler, Evans NPG Coolant, BTS 100 HP Chip, ART Cryogenically Treated & Slotted Rotors with Performance Friction Brake Pads, Dynatrac Spin Free HD Front Hubs, TAG I & II, Ford AIS Intake, 4 inch Stainless Exhaust from turbo to 5 inch chrome tip. Auto Meter Ultra Cobalt Gauges. 35X12.5 BFG KO's on 16x10 Rims, Bilstein Shocks.
Re: Can the Head Studs be Installed without pulling the Engine??
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: rubberducky</div><div class="ubbcode-body">It CAN be done, but its by no means easy </div></div>
Please elaborate. I have asked how, many, many times and no one has come forward to explain. They always say the heads have to be removed or the cab. I want to know how if it can be done with the heads on and cab on.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: weasel79</div><div class="ubbcode-body"><div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: rubberducky</div><div class="ubbcode-body">It CAN be done, but its by no means easy </div></div>
</div></div>
Hah, He just posted telling the whole thread NO, it can't be done. This guy post on topics he knows nothing about, oh except what he's read on the internet.
2001 F250 CC 4x4 (Blown motor @ 148k)
Garmon's Diesel Performance (bang bang bang)
01' F250 CC 7.3
6.5" ProComp on 35's Motometal 951's
03' headlights/corners, billet grill, Alpine/XM
16.5:1, Mahle's .0050 with harden forged
Comp 910's, 4130 pushrods, Mac/K&N
H11 studs, HT turbo, DP tuned,
Bean's singles/plentums, DI's fuel system
Mag-Hytec cover, Autometer gauges
Built trans with Red Altos/Mojo VB/PI triple disc.
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: weasel79</div><div class="ubbcode-body">Either cab off, or heads off. Possibly with the heater core/ac condensor out. Other than that no. </div></div>
Correct. My truck had headgaskets and studs put in without removing the cab. So did this guy:
(Just put in the diesel garage before the dot com)
If you want to do 1 for 1 you will have to pull the cab. If not you will have to replace headgaskets since you will be removing the heads in order to remove the rear passenger bolts, IIRC.
__________________ 2004 F250 CC FX4 / 46g Transfer Flow / ARP Studs
The original question is can they be changed one at a time cab on? NO
The bolts will not clear firewall on back lower corners and I think the back uppers too. Go look at the driver's side rear bottom bolt.
YES the heads can be removed with bolts held by rubber bands as heads are slid out and the heads with studs can be re-installed the same way and studs threaded in with heads in place. If you are doing head gaskets with cab on the bolts have to be retained in heads in order for them to be slid into place. Conceivably you could remove evap case and drill a few holes with a hole saw and change bolts and seal holes with rubber plugs. Anything is possible if you want it bad enough. The results may not be pretty....
I have not done this myself but a friend is a ford tech told me about the pains of this task and I visited him one day when they were doing cab off gaskets. He pointed out the trouble areas. Looking at my trucks, those rear bolts' clearance problem is obvious. Lower bolts are 6 inches or maybe more. There is not that kind of room to get them out with heads in place.
2006 F450 CC Hauler bed 4x2 6.0 L Pstroke/Torqshift, Lariat, 4.88 r/a.
2006 F350 Lariat CC Dually 4X2, 6.0 TQShift 4.10 LS, STOCK.
36 feet on the floor Elite/Outlaw LQ horse trailer. Sooner 6 horse large dressing/ mid tack.
15 horses with good balance from being hauled behind a P'stroke.
Thanks.... That is the answer I was looking for [img]/forums/images/%%GRAEMLIN_URL%%/smile.gif[/img]
If you want to put studs, its best that you go ahead and remove the heads inspect the pistons and cyl walls, install a new head gasket all at the same time. You have nothing to loose. By removing the cab its much easier and quicker to do. At that point you can choose to work on the EGR and rear fuel ports for more modifictaions.
They have removing the cab down to 45 minutes at Hagerstown Ford.
F250, 2005, 4x4, XLT, 6.0, 5 speed auto,
Tunes and tuner from Innovative Diesel of Elkton MD,
Accufab intake elbow.
Two speeding tickets.
Production date 12/04.
ARP head studs.
MBRP cat back exhaust.
K&N intake.
Bilsteins
New FICM 73K
Very happy with the whole deal.
