Upgrades and Aftermarket - 6.0L EngineUpgrading or adding OEM or aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
I'm buying SCT X3 and would like to do my ARP stud changeover myself. I do not have any head gasket problems and would prefer not changing them since they are not leaking. I read one reply to an ARP and Head gasket job posting that if you do not have a leaking head gasket, you can just replace the head bolts one at a time with the ARP bolts. Assuming that everything is torqued up per ARP instructions does this sound correct? If it can be done this way what are the obstacles I need to be aware of?
I've seen a few people post that they've done this and it seemed to work ok. They just replaced one bolt at a time. The biggest problem is that it's a major pain to get at the heads/bolts with the cab on.
Justin
__________________ Justin
1997 F-250 Power Stroke - 230k 463 hp - 7-9-09
BDP/Casserly Stage 2's, Mod H2E, Stealth Stage 2, BDP fuel system, Comp 910s, 7.3 ic, BDP live tuned
2005 F-350 Power Stroke (work truck) - 220k
ARP Studs, PHP 40 hp flash
Is the changeover to the ARP studs initially suggested or required since I'm only planning on using the three SCT X3 stock tunes? Anyone know what the H.P. increases are on those three tunes?
The 6.0 is prone to blow gaskets while stock, so any power increase isn't going to help. It's not required, but eventually you will need them, it's more of a now or later thing.
Justin
Im going to chime in here im in the same boat as amish. I say im not going to race the truck but who knows whats goin to happen ive have no gasket problems YET. But i see someone chimed in and said w.o removing the cab? Is is possibile at all? If so then **** ill do the studs myself insted of paying someone 1600bucks to do it, thats what i was quoted. Sound like a decent price?
2011 F350 6.2 XLT Crew cab SRW 4x4 3:73 E-locker Sync 4.2lcd
- Banks Exhaust w/ custom extras
- 5600k Head Lamps
- 5600k Fog Lamps
- Blacked Out Cab lights
- Blacked Out Mirror lights
The only odd thing I've read was something about someone using rubber bands to keep the studs in the back from falling. Possibly when the head was slid into place? I'm not sure if that implies that they could not drop the studs in under the cowling region after the head was in position or what.
You can do it without removing the cab, but it's a major pain. Got to strip it underneath the hood. If you have the means to lift the cab, it is much easier.
Justin
You're not going to be able to replace the bolt with the studs on the back couple of bolts.
Some guys have done a stud job with out pulling the cab, but they always pull the heads and insert the ARP's (held in place with rubber bands) and then replace the heads with new gaskets.
You might be able to just lift the cab a little bit (about 10" or so)
It's only 6 bolts and a few other pieces (steering column, radiator hoses, etc...) The major stuff might be able to stay connected if you just lift a little (like the A/C, the wire harnesses, etc...)
The guy that just did my studs had the cab in the air in under an hour!
It sure looked easy by pulling the cab. I can't imagine doing it any other way!
2005 F250 CC 4X4 Lariet
16k Reese Slider FWH
SCT x3 W/eXtreme tunes from Innovative,
but staying stock for now!
ARP studs installed-and new heads
EGR cooler FIXED for good!
Sneaky sneaky!
Coolant Filter
MBRP 4" Turbo Back
Amsoil Bypass Oil Filter w/stainless lines
IssPro A-Pillar gages
Intercooler pipe bracket mod.
Viper remote start alarm
HFCM fuel filter drain mod!
FICM REPAIR MOD
Upfitters w/ high-idle mod
40 gal aux fuel tank
Kenwood DNX7120 Navigation/DVD/iPod/BU Camera/video sytem
Jimmi Jammers
10" flip-down rear LCD screen
18" Wheels from a 2008 F250
Grover Emergency Air Horns
Viair 200psi air system
Bed cover
